6280 SECxxxxxxxxxETA Unlock fail. Please try again Please help 6280 SECxxxxxxxxxETA Unlock fail. Please try again Please help Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.10_21-12-06_RM-78_(c)_Nokia IMEI: 357926003058398 SP LOCK status: Config Key: 5050600042465540 Block 1: CLOSED Type 5 Data: 50506F Block 2: CLOSED Type 5 Data: 50599F Block 3: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_357926003058398_Locked_Keycnt_3_Fbuscnt_0__V_06 .10_21-12-06_RM-78_(c)_Nokia.bin already exist Checking if model ersion is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. |
2 Attachment(s) Same Problem Me Too I Have With Same Flash But In Spansion 1 Time Unlocked,i Think The Problem Is Gnd But Where I Can Put Gnd Bcoz I Try All The Place But Not Successfully? Here Is Flash Chip; |
dis 6280 secxxxxxx eta flash ic cannot unlock got problem must waiting new version bb5 box..... |
try to upgrade or downgrade your pfone many times it works for me |
Upgrade to 6.43 and be very extra carefull with TP contact... specially Data TP. Use thiner needle so you know you'r not also touching a nearby track. They are very close to another. BR |
Keyboard wrong codes counter: 3 wrong tries from max. 3 tries write backup pm and try br burhan barq |
No need to Write Backup Because Cable wrong codes counter: 0 wrong tries from max. 10 tries He should use Spansion and then try to unlock again :D Best Regards. |
write pm back and and upgeaed v6.43 and try tu unlock again :cool: Best Regards. |
same problem, after few unlock failed phone is dead 6280 SECxxxxxxxxxETA 6.10 version when i check the phone in jaf it show " unknown flash chip " but in spansion no hussle Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.10_21-12-06_RM-78_(c)_Nokia IMEI: 35raezak370988 SP LOCK status: Config Key: 2229raezak72790 Block 1: CLOSED Type 5 Data: 22299F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 4096 bytes Saving autobackup to file: RM-78_35raezak0988_Locked_Keycnt_0_Fbuscnt_0__V_06.10 _21-12-06_RM-78_(c)_Nokia.bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. |
wrong tp connect gnd to vibrator and ty again 1 connect pin 17 2 press bonton data and c onnect tp 24 post resulta |
Thinking that there might be an issue with 6.10. I upgrade to 6.41 and don't seem to have any problems any more. |
Today i got 5 pice 6280 with this SECxxxxxxxxxETA chip. Normaly unlock not work! Have select Eta and Spansion chip. No chance. Than i flash each phone many times up and down, and finaly to version 3.81. And voilla, Unlock work. This is only for information for people who have problems with this phones! No extra gnd, no extra power. Only flash phones! |
