11-22-2007, 23:45 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: unknow location... still seek Age: 43
Member: 178450 Status: Offline Thanks Meter: 54 | 6280 spansion chip not supported i have one 6280 whith spansion chip and say version not supported here is the log: Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.10_21-12-06_RM-78_(c)_Nokia IMEI: 3576030060xxxxx SP LOCK status: Config Key: 2229900093172790 Block 1: CLOSED Type 5 Data: 22299F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Model/version NOT supported for unlock. Please upgrade or downgrade! how can i unlock this model coz in the manual this sw is supported . regards |
11-23-2007, 07:41 | #3 (permalink) |
Insane Poster Join Date: Dec 2005 Location: Afganixtan
Member: 208759 Status: Offline Thanks Meter: 6 | Restart or change other PC, 6280 BB5Box supported all versionm and flash Spansion good work with BB5Box but with flash ATD => not work. We hope so Raskal will be Fix bug. Thank |
11-23-2007, 13:33 | #4 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: Near the sea... Portugal Age: 48
Member: 120120 Status: Offline Sonork: 100.1592092 Thanks Meter: 234 | Quote:
Use JAF, tick downgrade and after flash try again. I have done lotīs of 6280 with spansion chip with no problem. | |
11-24-2007, 03:10 | #6 (permalink) |
Member: 178450 Status: Offline Thanks Meter: 54 | thanks @ all for your replyes . the problem wasn't whith phone , my box wasn't activated so the old firmware can't supported that version . here is the log after box was activated: Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.10_21-12-06_RM-78_(c)_Nokia IMEI: 3576030060xxxxx SP LOCK status: Config Key: 2229900093172790 Block 1: CLOSED Type 5 Data: 22299F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_3576030060xxxxx_Locked_Keycnt_0_Fbuscnt_0__V_06 .10_21-12-06_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2229900093172790 Block 1: OPEN Type 5 Data: 22299F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull ps : i used tp whith 2 GND locations regards |
6280 Spansion Chip problems... | Phone Stock | BB5BOX | 3 | 01-05-2008 12:26 |
can't unlock 6280 spansion chip 3.81 | msdgsm | BB5BOX | 3 | 12-03-2007 12:53 |
NOKIA 6280 Spansion Chip Unlocked Successfully | .::BHATTI::. | UID - Box | 20 | 12-03-2007 11:59 |
6280 Spansion Chips Unlocked | ehd0429 | BB5BOX | 0 | 10-30-2007 14:39 |
