01-04-2008, 21:25 | #1 (permalink) |
Major Poster Join Date: Dec 2004 Age: 48
Member: 100365 Status: Offline Thanks Meter: 3 | 6280 Spansion Chip problems... But then i search the forums for any way to fix the problem. But i found nothing usefull. But now i´m sure it´s a testpoint cable problem. Because i have extended the orginal cables. For some Phones my modded cable works fine. 6280 SECXXXX and N73 and many other Phones no problem. At last i used a new testpoint cable, not modded one. One try... One Unlock !!! The Manufactorer of BB5Box know why they have make the cables so short. Try out your self and wonder. |
01-05-2008, 01:53 | #2 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: -worldwide-
Member: 592460 Status: Offline Thanks Meter: 110 | Quote:
01-05-2008, 12:26 | #4 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Tunisia Age: 54
Member: 240499 Status: Offline Thanks Meter: 151 | there is no problem to unlock Nokia 6280 with Spansion Chip - V3 Look: ------ Operation: UNLOCK Date: 04-01-2008 Time: 10:13:41 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.81_09-05-06_RM-78_(c)_Nokia IMEI: 352265015757xxx SP LOCK status: Config Key: 2081000000000000 Block 1: CLOSED Type 5 Data: 20810F Block 2: CLOSED Type 5 Data: 64710F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_352265015757xxx_Locked_Keycnt_0_Fbuscnt_0__V_03 .81_09-05-06_RM-78_(c)_Nokia.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-78_352265015757xxx_Locked_Keycnt_0_Fbuscnt_0__V_03 .81_09-05-06_RM-78_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2081000000000000 Block 1: CLOSED Type 5 Data: 20810F Block 2: CLOSED Type 5 Data: 64710F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2081000000000000 Block 1: OPEN Type 5 Data: 20810F Block 2: OPEN Type 5 Data: 64710F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
can't unlock 6280 spansion chip 3.81 | msdgsm | BB5BOX | 3 | 12-03-2007 12:53 |
NOKIA 6280 Spansion Chip Unlocked Successfully | .::BHATTI::. | UID - Box | 20 | 12-03-2007 11:59 |
6280 spansion chip not supported | the sorrow | BB5BOX | 5 | 11-24-2007 03:10 |
6280 Spansion Chips Unlocked | ehd0429 | BB5BOX | 0 | 10-30-2007 14:39 |
My first 6280 globe locked spansion chip unlocked in 60 min. realtime all setup | cetech | BB5BOX | 0 | 10-20-2007 11:12 |
