Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5BOX
Old 11-10-2008, 23:11   #1 (permalink)
Member: 16943
Thanks Meter: 35
n95 unlock help
hi
i have one n95 (my first one) for unlocking but allways i have this error:
Connecting to BB5 Box ...
Searching for phone ...
ERROR: Cannot detect phone on FBUS interface
i have tested the cable in one 5200 and is working perfect, the miniusb phone conector is good, i don't know what to do, can anybody help me?
thanks
Old 11-10-2008, 23:34   #2 (permalink)
drgmobile's Avatar
Member: 48886
Thanks Meter: 97
Originally Posted by jak2812 View Post
hi
thanks
Do full factory reset on phone and try again. If this doesn't work, try flashing the phone to 30.0.016 and try again.
Old 11-11-2008, 09:47   #3 (permalink)
Member: 420137
do u have the nokia charger plugged in your bb5 box
n95 is 1 of the phones that needs additional power
Old 11-11-2008, 12:56   #4 (permalink)
boucettay's Avatar
Member: 148814
Sonork: 100.1576882
Thanks Meter: 5,012
after u push switch on botton, wait a little till phone enter in test mode, this take sometime, and soft will not detect phone
just wait ~8 sec and click phone info.
Do not forget to disconnect lcd and camera.
I unlocked today 2 pcs, and 100/100
Reset phone ...
PM Field 308 Subfield 1 written OK
Reading SP Locks after Auto Write PM 308 ...
SP LOCK status:
Config Key: 2140100000000000
Block 1: CLOSED Type 5 Data: 21401F
Block 2: CLOSED Type 5 Data: 21401F
Keyboard wrong codes counter: 0 wrong tries from max. 3 tries
Cable wrong codes counter: 0 wrong tries from max. 10 tries
Checking if model/version is supported for unlock ...
Please connect testpoints
Testpoints connected OK
Keep Testpoints connected until unlock finish!
Unlocking phone ...
Delaying unlock procedure with 500 miliseconds
Try unlocking using keyboard codes ...
Try number (Keyboard): 1
Sending SP code: #pw+012345678901234+7#
Response byte: 00
Reading again SP Locks ...
SP LOCK status:
Block 1: OPEN Type 5 Data: 21401F
Block 2: OPEN Type 5 Data: 21401F
Phone unlocked succesfull
BR,
Old 11-11-2008, 19:46   #5 (permalink)
Member: 16943
Thanks Meter: 35
hi
i'll try the different options.
thanks
Old 11-12-2008, 20:23   #6 (permalink)
simlock's Avatar
Member: 14047
Thanks Meter: 166
make shore you cable correctly connected to fone with red vcc and yellow bsi on righ batt connectors and if fone is now detected as said by dust4dust use nokia charger or you may loose coneection
The Following User Says Thank You to simlock For This Useful Post:
Old 11-12-2008, 20:51   #7 (permalink)
Member: 16943
Thanks Meter: 35
hi
the problem was the cable.
thanks
The Following User Says Thank You to jak2812 For This Useful Post:
n95 unlock help.... .:Gsm-Nikki:. Nokia Base Band 5 ( BB-5 ) 2 05-02-2009 19:59
Nokia N95 unlocking... help me make a great christmas present please! Richdog Phone Unlocking Codes & Maps 4 12-11-2007 19:11
n95 urgnt help need to unlock great4nara MT-BOX 11 07-30-2007 08:10
my n95 unlock plz help amar181 Nokia Base Band 5 ( BB-5 ) 1 07-29-2007 16:49
N95 unlock by imei!HELP ME !! nazarevich Nokia Base Band 5 ( BB-5 ) 12 07-14-2007 13:37
Page generated in 0.24511 seconds with 9 queries
