6300 can't connect with bb5 box getting errors with 4 phones log Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface |
check your cable mate may be cable problem .......... |
@mc_denz Forgive .... check that this well-connected power hooks and turn it .... If you want, just to prove, put it on display for you to see if they test mode |
tried power up blue light flash but nothing on screen i read all about user code but there is no user code when i boot normsll it ask me start up without sim? cable is brand new used twice been working fine |
make shore red vcc is right and bsi yellow is right also to try to read without vcc and bsi put battery in fone and just use cable to botton i mean test point cable and press info see if the fone reads if the fone reads cheack vcc and bsi clips on cable to make shore its still connected ok |
Also, Make sure USB cable is shorter than 1~meter. Make sure there is no Grit on System connector and Red is to + and Yellow is to Data terminal NOT negative. I find using an elastic band to hold the RJ45 connector to the box helps, cause it does slide around a bit. |
