10-24-2008, 16:43 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Türkiye [☾✫ ]
Member: 687932 Status: Offline Sonork: 100.1619892 Thanks Meter: 110 | 6300 unlock failed pls need fridens ım not to open 6300 unlock plz help Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_06.60_21-05-08_RM-217_(c)_Nokia. IMEI: 3564360153377** SP LOCK status: Config Key: FFFFFFFFFFFFFFFF Block 1: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-217_356436015337***_Locked_Keycnt_0_Fbuscnt_0__V_0 6.60_21-05-08_RM-217_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-217_356436015337***_Locked_Keycnt_0_Fbuscnt_0__V_0 6.60_21-05-08_RM-217_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes ERROR: 11210001 ERROR: 30020041 |
10-24-2008, 16:53 | #3 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: EDSELLULAR
Member: 236564 Status: Offline Sonork: 100.1667122 Thanks Meter: 816 | if you recieved this phone with this status Quote:
you need rpl first before you can unlock | |
The Following User Says Thank You to rea1One For This Useful Post: |
10-25-2008, 16:23 | #6 (permalink) |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | wait 3/10/2008, and your bb5box will be able to repair config key :FFFFFFFFFF and unlock your phone without TP, or use RPL service is custumer hurry. BR, |
The Following User Says Thank You to boucettay For This Useful Post: |
6300 contact service pls need help! | ReyTech | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 18 | 02-18-2010 16:52 |
6300 contact service pls need help | denny86 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-18-2010 16:16 |
still --> 6300 unlock fail with spansion flash chip | nikkomusa | BB5BOX | 2 | 02-27-2008 22:42 |
6300 unlock fail with spansion flash chip | fastgsm | BB5BOX | 12 | 02-27-2008 16:30 |
6300 unlock failed | ZEBUN | BB5BOX | 10 | 02-08-2008 23:39 |
