11-24-2007, 18:55 | #1 (permalink) |
Junior Member Join Date: Nov 2007
Member: 622558 Status: Offline Thanks Meter: 0 | N73 Unlock Problem Maybe I need to Flash phone for right version to unlock don’t know?? Any ideas whats wrong, confused Thanks Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v38.1_19-01-07_RM-133_(c)_Nokia. IMEI: 359568010298316 SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F Block 2: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-133_359568010298316_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v38.1_19-01-07_RM-133_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-133_359568010298316_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v38.1_19-01-07_RM-133_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343000000000000 Block 1: CLOSED Type 5 Data: 23430F Block 2: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. |
11-24-2007, 21:05 | #3 (permalink) | |
Freak Poster Join Date: Mar 2004 Location: Czech republic Age: 54
Member: 56634 Status: Offline Thanks Meter: 71 | Quote:
Quote: Originally Posted by kadekrudi View Post Try to unlock 3 pcs N73 , result :unlock fail, try again . something wrong with me? all flash chip is SAMSUNG K5G2829ATC-DF75 Phone#1Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v38.1_19-01-07_RM-133_(c)_Nokia. IMEI: 356260010737674 SP LOCK status: Block 1: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-133_356260010737674_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v38.1_19-01-07_RM-133_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 07 Unlock fail. Please try again. PHONE#2 Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v38.1_19-01-07_RM-133_(c)_Nokia. IMEI: 351851016735392 SP LOCK status: Block 1: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-133_351851016735392_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v38.1_19-01-07_RM-133_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 07 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 07 Unlock fail. Please try again. PHONE#3 Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v38.1_19-01-07_RM-133_(c)_Nokia. IMEI: 353640018707915 SP LOCK status: Block 1: CLOSED Type 5 Data: 23820F Block 2: CLOSED Type 5 Data: 23830F Block 3: CLOSED Type 5 Data: 23820F Block 4: CLOSED Type 5 Data: 23830F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-133_353640018707915_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v38.1_19-01-07_RM-133_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. need help to solve problem BR CHECK TESTPOINT & GROUND | |
11-24-2007, 22:31 | #4 (permalink) |
Freak Poster Join Date: Aug 2006 Location: SR
Member: 325357 Status: Offline Thanks Meter: 6 | i have today unlocked 5 units of n73, in one of them i have faced this problem that response byte equals 08, this error was caused because my ground was not corectly placed and clk testpoint was touching another ball. So check ground and also check TP especialy clk BR |
11-25-2007, 12:30 | #6 (permalink) |
Insane Poster Join Date: Mar 2004 Location: w.yorkshire Age: 52
Member: 57802 Status: Offline Thanks Meter: 4 | on n73 you need to file down testpoint needles. the clk needle is too fat to touch ball correctly. i used a fingernail emery board and once it was FINE enough it unlocked 1st go. box supporters have posted here that it is not possible to unlock n73 without modifying testpoint needles, br torbay |
11-25-2007, 21:35 | #9 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 42
Member: 136598 Status: Offline Thanks Meter: 3 | dead well, i killed the n73 trying to use the testpoint it comes with i wish they would have given a warning to say you cant unlock it with the testpoints they give you. Has anyone actually did it without modifying the exisiting testpoint. |
11-28-2007, 09:09 | #13 (permalink) |
Member: 56634 Status: Offline Thanks Meter: 71 | unlock n73 I today unlock N73 for bb5box and from bb5 027 and good woork but you use external power an work OK log: Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2310200000000000 Block 1: CLOSED Type 5 Data: 23102F Block 2: CLOSED Type 5 Data: 23102F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2310200000000000 Block 1: OPEN Type 5 Data: 23102F Block 2: OPEN Type 5 Data: 23102F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
12-03-2007, 10:27 | #14 (permalink) |
Member: 622558 Status: Offline Thanks Meter: 0 | Yes, guys just come back from holiday and unlocked that N73 because attached ground cable closest to TP ding..ding..DONE.So what follows from this that BB5Box working fine just need little bit attention. Regards |
N73 Unlocking problem! | Gsm-W | UID - Box | 97 | 10-06-2007 15:25 |
n73 unlock problem | bronks | MT-BOX | 2 | 09-18-2007 14:16 |
n73 unlock problem | aligsmpak | MT-BOX | 2 | 08-01-2007 22:57 |
n73 unlocking problem | EFOKORKU | MT-BOX | 4 | 07-26-2007 12:49 |
N73 Unlock Problem | Nasmi | MT-BOX | 1 | 07-21-2007 09:01 |
