Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5BOX
Old 11-25-2007, 22:20   #16 (permalink)
Member: 4527
Thanks Meter: 40
1 flash type maybe supported
Old 11-26-2007, 15:58   #17 (permalink)
Member: 59746
Thanks Meter: 5
7390 SEC716 KG75 4 me not working try about 10 times, wait 4 update, my customer patient too
Old 11-28-2007, 18:44   #18 (permalink)
Member: 59746
Thanks Meter: 5
7390 SEC716 KG75
not working
response byte (50) (55) ...
ERROR: Connection with phone was lost!
ERROR: 11140002
here is 1 log
Connecting to BB5 Box ...
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-140
Version: V_03.84_23-10-06_RM-140_(c)_Nokia
IMEI: xxxxxxxxxxxxxxxxxxxxxx
SP LOCK status:
Config Key: 2191000000000000
Block 1: CLOSED Type 5 Data: 21910F
Keyboard wrong codes counter: 0 wrong tries from max. 3 tries
Cable wrong codes counter: 0 wrong tries from max. 10 tries
Reset phone in TEST mode ...
Set Full Factory Defaults ...
Reset phone ...
Full Factory Defaults set OK
Skip autobackup of PM 308
Autobackup file:
RM-140_xxxxxxxxxxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_0__ V_03.84_23-10-06_RM-140_(c)_Nokia.bin
already exist
Auto Write PM 308 procedure started
Searching for backup file with lowest FBUS count ...
Finded backup file:
Writting PM Field 308 Subfield 1 with length 8192 bytes
Reset phone ...
PM Field 308 Subfield 1 written OK
Reading SP Locks after Auto Write PM 308 ...
SP LOCK status:
Checking if model/version is supported for unlock ...
Please connect testpoints
Testpoints connected OK
Keep Testpoints connected until unlock finish!
Unlocking phone ...
Try number: 1
Sending SP code: #pw+012345678901234+7#
Response byte: 55
Try number: 2
Response byte: 55
Try number: 3
Response byte: 55
Try number: 4
Response byte: 55
Try number: 5
Response byte: 55
Try number: 6
Response byte: 14
Try number: 7
Response byte: 08
Try number: 8
Response byte: 08
Try number: 9
Response byte: 08
Try number: 10
Response byte: 08
Unlock fail. Please try again.
Old 11-28-2007, 23:03   #19 (permalink)
masterunlocking's Avatar
Member: 488825
Thanks Meter: 365
Originally Posted by gsm-hanky View Post
7390 SEC716 KG75
not working
ERROR: 11140002
here is 1 log
Type: RM-140
SP LOCK status:
Reset phone ...
Autobackup file:
already exist
Finded backup file:
Reset phone ...
SP LOCK status:
Unlocking phone ...
Try number: 1
Response byte: 55
Try number: 2
Response byte: 55
Try number: 3
Response byte: 55
Try number: 4
Response byte: 55
Try number: 5
Response byte: 55
Try number: 6
Response byte: 14
Try number: 7
Response byte: 08
Try number: 8
Response byte: 08
Try number: 9
Response byte: 08
Try number: 10
Response byte: 08
Im getting same problem, what the f*** is this problem???
Type: RM-146
Version: V_03.92_13-10-06_RM-146_(c)_Nokia.
IMEI: 356964010193982
SP LOCK status:
Config Key: 3102000000000000
Block 1: CLOSED Type 5 Data: 310160
Block 2: CLOSED Type 5 Data: 310200
Block 3: CLOSED Type 5 Data: 310210
Block 4: CLOSED Type 5 Data: 310220
Block 5: CLOSED Type 5 Data: 310230
Block 6: CLOSED Type 5 Data: 310240
Block 7: CLOSED Type 5 Data: 310250
Block 8: CLOSED Type 5 Data: 310260
Block 9: CLOSED Type 5 Data: 310270
Block 10: CLOSED Type 5 Data: 310300
Block 11: CLOSED Type 5 Data: 310310
Block 12: CLOSED Type 5 Data: 310490
Block 13: CLOSED Type 5 Data: 310530
Block 14: CLOSED Type 5 Data: 310580
Block 15: CLOSED Type 5 Data: 310590
Block 16: CLOSED Type 5 Data: 310640
Block 17: CLOSED Type 5 Data: 310660
Block 18: CLOSED Type 5 Data: 310800
Reset phone ...
Autobackup file:
RM-146_356964010193982_Locked_Keycnt_0_Fbuscnt_0__V_0 3.92_13-10-06_RM-146_(c)_Nokia..bin
already exist
Finded backup file: RM-146_356964010193982_Locked_Keycnt_0_Fbuscnt_0__V_0 3.92_13-10-06_RM-146_(c)_Nokia..bin
Reset phone ...
SP LOCK status:
Unlocking phone ...
Try number: 1
Response byte: 08
Try number: 2
Response byte: 08
Try number: 3
Response byte: 08
Try number: 4
Response byte: 08
Try number: 5
Response byte: 08
Try number: 6
Response byte: 08
Try number: 7
Response byte: 08
Try number: 8
Response byte: 08
Try number: 9
Response byte: 08
Try number: 10
Response byte: 08
Old 11-30-2007, 02:07   #20 (permalink)
Member: 588059
Thanks Meter: 47
Update flash to 04.51 and use v0.0.2.8 for unlock (update also box firmware).
More details here:
http://forum.gsmhosting.com/vbb/show...9&postcount=12
Old 12-01-2007, 21:08   #21 (permalink)
Member: 59746
Thanks Meter: 5
4.51 v137 from jaf support corupted
waiting 4.51 v137 & v138 from torent
3.84 and v0.0.2.8 same problem I will try with 4.51
Old 12-02-2007, 14:31   #22 (permalink)
Member: 588059
Thanks Meter: 47
Is time to get another flasher. JAF is falling down .... trust me.
Old 12-02-2007, 15:04   #23 (permalink)
Member: 488825
Thanks Meter: 365
Wich flasher do you recommend so???
Old 12-02-2007, 18:01   #24 (permalink)
Deimantas's Avatar
Member: 132757
Originally Posted by audi_tt View Post
hahahah. plug in charger and will be possibility to have dead phone Deimantas have you unlocked any 7390 using this box?
Just measure the voltage of your charger and you wont kill any phone.
It just allows you not to loose connection with the phone when unlocking.
Tried different 4 pics of 7390, but without the succes, easy unlocked them using other box from the first try.
Tried to upgrade/downgrade the versions, but unlock unsuccsesfull. I think its problem of the different flash chips in the phones.
Old 12-02-2007, 18:37   #25 (permalink)
Member: 59746
Thanks Meter: 5
no way
Type: RM-140
Version: V_04.51_29-11-06_RM-140_(c)_Nokia
SP LOCK status:
Reset phone ...
Autobackup file:
RM-140_xxxxxxxxxxxxxxxxxxxxxxxxx_Locked_Keycnt_0_Fbus cnt_0__V_04.51_29-11-06_RM-140_(c)_Nokia.bin
already exist
Finded backup file: RM-140_xxxxxxxxxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_0__V _04.51_29-11-06_RM-140_(c)_Nokia.bin
Reset phone ...
SP LOCK status:
Unlocking phone ...
Try number: 1
Response byte: 55
Try number: 2
Response byte: 55
Try number: 3
Response byte: 55
Try number: 4
Response byte: 55
Try number: 5
Response byte: 55
Try number: 6
Response byte: 55
Try number: 7
Response byte: 55
Try number: 8
Response byte: 55
Try number: 9
Response byte: 14
Try number: 10
Response byte: 08
Old 12-03-2007, 00:16   #26 (permalink)
the new's Avatar
Member: 36653
Thanks Meter: 325
Lightbulb lol
lol you are a supporter for BB5 box that is producted from Raskal and Jaf is producted and supported by Raskal lol and you tell that Jaf is falling
Old 12-03-2007, 06:08   #27 (permalink)
Member: 588059
Thanks Meter: 47
Of course. And I know EXACTLY what I tell here. Just watch the future ...
Old 12-03-2007, 06:09   #28 (permalink)
Member: 588059
Thanks Meter: 47
Right now we have not any recommendation. If you are in hurry just buy another one who is on the market. If not in so hurry, just wait and you wil have a better BB5 flasher ...
Old 12-03-2007, 06:10   #29 (permalink)
Member: 588059
Thanks Meter: 47
You are loosing connection with phone (Respones byte 55).
Check GND connection and right testpoints!
no way
Type: RM-140
SP LOCK status:
Reset phone ...
Autobackup file:
already exist
Reset phone ...
SP LOCK status:
Unlocking phone ...
Try number: 1
Response byte: 55
Try number: 2
Response byte: 55
Try number: 3
Response byte: 55
Try number: 4
Response byte: 55
Try number: 5
Response byte: 55
Try number: 6
Response byte: 55
Try number: 7
Response byte: 55
Try number: 8
Response byte: 55
Try number: 9
Response byte: 14
Try number: 10
Response byte: 08
Old 12-03-2007, 09:57   #30 (permalink)
Member: 59746
Thanks Meter: 5
I understand see this and sugest gnd
7390/unlock error with thomas unlocker kaiserstumm BB5 No TP By Jafsupport 3 11-26-2008 15:30
7390 Unlock waleedkhalid MT-BOX 0 10-23-2007 20:19
Is 7390 unlock tested already? tomaszwl MT-BOX 13 10-17-2007 21:09
7390 unlock succesful!! tiri piri MT-BOX 2 08-23-2007 10:43
7390 Unlock. Medved MT-BOX 12 08-04-2007 02:02
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.39615 seconds with 9 queries
