10-02-2007, 02:17 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: On Roads... Age: 43
Member: 107839 Status: Offline Sonork: 100.1592822 Thanks Meter: 70 | Box - Power from USB nokia charger(pic inside) i've just added LM7805 stabilizer IC and tried to use with USB power: No external charger. Tested unlock N95+N73 all OK B.R ZACHI |
10-02-2007, 05:37 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Age: 45
Member: 49581 Status: Offline Thanks Meter: 73 | it is useless man .... the need of charger is to provide enough voltage/amp to the phone when it needs more than the power from USB port of ur computer ... and as in ur picture, you just drain more power from ur PC though ONE usb port, and it is dangerous ... of course u have chnace to unlock phones like this .... like for me, i NEVER use a charger to unlock every phones with BB5Box so far ..... if u want, use another USB to connect the USB charger u have to provide power to ur BB5Box ... but, as the supporter said, use ONLY Nokia ACP-12x charger, to have STEADY and SMOOTH power supply ... otherwise, why they have to make it sticky to tell u NOT TO USE any other power supply?! |
Combo + USB power + TX2 Line Cable Powered by USB and TX2 Enabled Compatible For NK 6 | IPMART | ipmart WebShop | 0 | 06-15-2009 07:40 |
Combo + USB power + TX2 Line Cable Powered by USB and TX2 Enabled Compatible For NK 5 | IPMART | ipmart WebShop | 0 | 06-15-2009 07:40 |
Why doesn't twister work when powered from external USB-hub? | James_S | Twisterflasher | 0 | 06-07-2005 17:37 |
