09-28-2007, 20:36 | #1 (permalink) |
Junior Member Join Date: Apr 2007
Member: 487937 Status: Offline Thanks Meter: 1 | bb5-box kill my nokia 5300 i was unlocking one nokia 5300 with my bb5-box: During the process, it ask to Write PM308, i select the correct PM308 and now the phone it`s dead. I was trying to flash on with my JAF and UFS3 and says NOT BOOTING FILE. |
09-28-2007, 20:46 | #2 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Netherlands
Member: 193781 Status: Offline Thanks Meter: 18 | Just unlocked one 5300 with ATB chip with BB5 box without problem. @Emely, program does not ask to write PM308 field during unlock proces. It is an optional function which you need after 10 wrong tries. Best regards |
09-28-2007, 21:05 | #3 (permalink) |
No Life Poster Join Date: Jun 2003 Location: EGYPT Age: 44
Member: 31027 Status: Offline Thanks Meter: 179 | sir after use this box box work ok and can not kill any phone the problem is you need orginal nokia jarcher acp-12x or see here http://forum.gsmhosting.com/vbb/showthread.php?t=448562 that is all |
09-28-2007, 21:27 | #4 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | 5300b unlocked without acp-12 since i forget to connect but still ok: Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-147 Version: V_04.51_11-01-07_RM-147_(c)_Nokia. IMEI: 354823011677124 SP LOCK status: Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310300 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-147_354823011677124_Locked_Keycnt_0_Fbuscnt_0__V_0 4.51_11-01-07_RM-147_(c)_Nokia..bin Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Block 1: OPEN Type 5 Data: 310160 Block 2: OPEN Type 5 Data: 310200 Block 3: OPEN Type 5 Data: 310210 Block 4: OPEN Type 5 Data: 310220 Block 5: OPEN Type 5 Data: 310230 Block 6: OPEN Type 5 Data: 310240 Block 7: OPEN Type 5 Data: 310250 Block 8: OPEN Type 5 Data: 310260 Block 9: OPEN Type 5 Data: 310270 Block 10: OPEN Type 5 Data: 310300 Block 11: OPEN Type 5 Data: 310310 Block 12: OPEN Type 5 Data: 310490 Block 13: OPEN Type 5 Data: 310530 Block 14: OPEN Type 5 Data: 310580 Block 15: OPEN Type 5 Data: 310590 Block 16: OPEN Type 5 Data: 310640 Block 17: OPEN Type 5 Data: 310660 Block 18: OPEN Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
09-29-2007, 19:58 | #5 (permalink) | |
Freak Poster Join Date: Nov 2006 Location: Santo domingo norte villa mell
Member: 398011 Status: Offline Thanks Meter: 25 | Quote:
I tried what you says and says asking me to write PM308. and doesn`t unlock. | |
09-29-2007, 19:59 | #6 (permalink) | |
09-30-2007, 21:32 | #10 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | @emicabher just unlocked a 5300 black xpress music without problems. Did you use ACP-12 as already said? There is no need to use a charger on this one. If it wont power up its probably a dead Tahvo power ic . Try to flash it to see if there is still life in it. However very strange cause this model is quite safe and easy to unlock since its without charger. N73 is quite a bastard. g luck |
help plz vygis box killed my phone? | deemonh1157 | VygisToolbox | 12 | 10-20-2009 13:08 |
Universal box killed my e65 | sajidmirza | Universalbox | 8 | 08-15-2009 06:43 |
BB5 box kill N73 after read | glontz | BB5BOX | 11 | 01-21-2008 21:12 |
nddongle box killed my d500 | 1taz | NSPRO | 4 | 01-30-2006 10:30 |
dejan box killed my 3210,,,help! | hanoon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-03-2002 14:35 |
