11-02-2007, 14:50 | #1 (permalink) |
Junior Member Join Date: Oct 2007
Member: 617890 Status: Offline Thanks Meter: 0 | Prob Unlocking Handsets Have just bought a new BB5 Box, First the box had to go back b/c it was dead, then i had to get new cables and now i am getting the following when i try to unlock handsets. I have tried this with a 6280, 6288, 5200 and N73 and all give me the same error. Have checked testpoints, am using the right onces, have followed the instruction manual and still the same... anyone got any ideas? Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_05.00_27-04-07_RM-174_(c)_Nokia. IMEI: SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-174_357672015113587_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-174_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. |
11-02-2007, 14:55 | #2 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 37
Member: 138877 Status: Offline Thanks Meter: 0 | You are not making correct tp, this error comes when you do not make correct test points. Check your test points again, make sure you have good ground aswel. Personally i find this happen when i make good Data, but CLK is off a bit, or when i move while i press the data button. Keep steady hand, try again, after you get your first one done, you will do many with ease. |
make list of unlockable handsets | aman khatri | ULT PRO | 0 | 03-28-2008 07:57 |
unlock handset code P910i | zadops | Sony Ericsson | 0 | 11-10-2006 04:44 |
Unlock handset code for GX 27? | stlan88 | Sharp | 0 | 07-05-2005 22:42 |
Does Uni-server unlock handset code ??? | lypen17 | NEC | 3 | 02-18-2005 02:49 |
