** BB5BOX Updates Only Here - BB5 v0.0.4.1 - 3/3 10/10 FBUS counter reset ** Supported Versions for BB5 Box with Firmware version 1 http://www.bb5box.org/Supported_Versions_v1.html http://www.bb5box.org/Supported_Versions_v1.pdf |
Supported Versions for BB5 Box with Firmware version 2 http://www.bb5box.org/Supported_Versions_v2.html http://www.bb5box.org/Supported_Versions_v2.pdf |
Supported Versions for BB5 Box with Firmware version 3 http://www.bb5box.org/Supported_Versions_v3.html http://www.bb5box.org/Supported_Versions_v3.pdf |
Supported Versions for BB5 Box with Firmware version 4 http://www.bb5box.org/Supported_Versions_v4.html http://www.bb5box.org/Supported_Versions_v4.pdf |
Supported Versions for BB5 Box with Firmware version 5 http://www.bb5box.org/Supported_Versions_v5.html http://www.bb5box.org/Supported_Versions_v5.pdf |
Software BB5 Box v0.0.2.2: - Added automatic write backup when perform Unlocking (file with lowest FBUS counter is auto selected) - Added option to enable/disable automatic write of PM 308 when perform Unlocking - Added option to enable/disable Full Factory Settings when perform Unlock - Added filtered selection when Write PM 308 (allow select only files for current connected phone) - All current settings is saved in configuration file - Switch phone in Test Mode when perform Full Factory Settings and Unlocking (in case if phone is in Local Mode) - All messages are saved in log file (BB5_Box_log.txt in current directory) - Removed Win-XP not allowed characters from saved file names ( e.g. phones with IMEI 123...?? ) Supported Versions for BB5 Box with Firmware version 6 http://www.bb5box.org/Supported_Versions_v6.html http://www.bb5box.org/Supported_Versions_v6.pdf |
Software BB5 Box v0.0.2.3: - Added progress bar for Read PM 308, Autobackup and BOX Firmware Update - Added "phone ping" when waiting for testpoints connections - Improved error handling when sending SP Code for unlock |
Software BB5 Box v0.0.2.4: - Added option to enable/disable "phone ping" when waiting for testpoints connections Supported Versions for BB5 Box with Firmware version 7 http://66.199.236.202/bb5box/index.p...d=18&Itemid=35 http://www.bb5box.org/Supported_Versions_v7.html http://www.bb5box.org/Supported_Versions_v7.pdf |
Software BB5 Box v0.0.2.5: - Added automatic frame with testpoint details for connected phone when unlocking (new window popup when software ask to connect testpoints and disapear when testpoint are connected) - Corrected bug from v0.0.2.4 when read version from some models and report "Not supported model/version" (e.g. N73) Direct download links: Software BB5 Box v0.0.2.5 with HIGH resolution testpoint images (83 MB): BB5_v025_HiRes.zip - Server 1 (USA) BB5_v025_HiRes.zip - Server 2 (USA) Software BB5 Box v0.0.2.5 with LOW resolution testpoint images (6 MB): BB5_v025_LowRes.zip - Server 1 (USA) BB5_v025_LowRes.zip - Server 2 (USA) |
Software BB5 Box v0.0.2.6: Direct download links: Software BB5 Box v0.0.2.6 with HIGH resolution testpoint images (83 MB): BB5_v026_HiRes.zip - Server 1 (USA) BB5_v026_HiRes.zip - Server 2 (USA) Software BB5 Box v0.0.2.6 with LOW resolution testpoint images (6 MB): BB5_v026_LowRes.zip - Server 1 (USA) BB5_v026_LowRes.zip - Server 2 (USA) Supported Versions for BB5 Box with Firmware version 8 http://66.199.236.202/bb5box/index.p...d=18&Itemid=35 http://www.bb5box.org/Supported_Versions_v8.html http://www.bb5box.org/Supported_Versions_v8.pdf |
Software BB5 Box v0.0.2.7: - Improved unlock procedure agains wrong testpoint location touch - Added model/version unlock support check when Read Info - Integrated USB microscope popup watch window - Added enable/disable option for popup window with testpoints details - Added enable/disable option for microscope view popup window - Save testpoints details popoup window position and size - Save microscope view popoup window position and size - Save current microscope USB device selection Software BB5 Box v0.0.2.7 - EXE file only: BB5_v027_EXE_Only.zip - Server 1 (USA) BB5_v027_EXE_Only.zip - Server 2 (USA) |
Software BB5 Box v0.0.2.8: - Added Full Factory function even for unlocked phones - Added selection of flash type (when phone model require this) when Read Info - Removed a bug who not allow start software when card usage reached 100% Software BB5 Box v0.0.2.8 - EXE file only: BB5_v028_EXE_Only.zip - Server 1 (USA) BB5_v028_EXE_Only.zip - Server 2 (USA) Supported Versions for BB5 Box with Firmware version 9 http://www.bb5box.org/Supported_Versions_v9.html http://www.bb5box.org/Supported_Versions_v9.pdf |
Software BB5 Box v0.0.2.9: - Unlock procedure reverted as in version v0.0.2.6 - Default settings changed to no use microscope and not ping mobile Software BB5 Box v0.0.2.9 - EXE file only: BB5_v029_EXE_Only.zip - Server 1 (USA) BB5_v029_EXE_Only.zip - Server 2 (USA) Supported Versions for BB5 Box with Firmware version 10 http://www.bb5box.org/Supported_Versions_v10.html http://www.bb5box.org/Supported_Versions_v10.pdf |
Software BB5 Box v0.0.3.0: Software BB5 Box v0.0.3.0 - EXE file only: BB5_v030_EXE_Only.zip - Server 1 (USA) BB5_v030_EXE_Only.zip - Server 2 (USA) Supported Versions for BB5 Box with Firmware version 11 http://www.bb5box.org/Supported_Versions_v11.html http://www.bb5box.org/Supported_Versions_v11.pdf |
Software BB5 Box Updater: - Allow to update any firmware version (older or newer) on box - Use this soft before you want to use any older BB5 Box software - All older software versions are available for download on our page (http://www.bb5box.org or http://www.bb5box.hk) - In same Download page is specified each BB5 software what firmware require inside box Software BB5 Box Updater: BB5_Updater.zip - Server 1 BB5_Updater.zip - Server 2 |
