12-24-2007, 10:13 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: U-A-E Dubai---->Pak
Member: 315789 Status: Offline Thanks Meter: 3,428 | E61 always response byte: 08 with v0.0.3.0 other models working fine. ------ Operation: UNLOCK Date: 24-12-2007 Time: 01:52:53 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-89 Version: V_3.0533.6_31-10-06_RM-89_(c)_Nokia. IMEI: 356211000964802 SP LOCK status: Config Key: 2140100000000000 Block 1: CLOSED Type 5 Data: 21401F Block 2: CLOSED Type 5 Data: 21401F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-89_356211000964802_Locked_Keycnt_0_Fbuscnt_10__V_3 .0533.6_31-10-06_RM-89_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-89_356211000964802_Locked_Keycnt_0_Fbuscnt_0__V_3. 0533.6_31-10-06_RM-89_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2140100000000000 Block 1: CLOSED Type 5 Data: 21401F Block 2: CLOSED Type 5 Data: 21401F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. ------ Operation: UNLOCK Date: 24-12-2007 Time: 01:53:23 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-89 Version: V_3.0533.6_31-10-06_RM-89_(c)_Nokia. IMEI: 356211000964802 SP LOCK status: Config Key: 2140100000000000 Block 1: CLOSED Type 5 Data: 21401F Block 2: CLOSED Type 5 Data: 21401F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-89_356211000964802_Locked_Keycnt_0_Fbuscnt_10__V_3 .0533.6_31-10-06_RM-89_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-89_356211000964802_Locked_Keycnt_0_Fbuscnt_0__V_3. 0533.6_31-10-06_RM-89_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2140100000000000 Block 1: CLOSED Type 5 Data: 21401F Block 2: CLOSED Type 5 Data: 21401F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. plzzzzzzzzz help |
01-13-2014, 17:35 | #2 (permalink) |
Junior Member Join Date: Aug 2007
Member: 559962 Status: Offline Thanks Meter: 0 | can somebodey help......i found one E61 in perfect shape but locked on Austria a1 network and i am from serbia..... if somebodey would be kind enough to calculate me the unlock codes that would be perfect ime :356211/00/143053/0 code:0536327 rm89 model e61-1 fccidyarm-89 ic:661v-rm89 |
can't unlock 6131 !!!! always Response byte: 55 | AjeeB | BB5BOX | 17 | 04-18-2008 19:48 |
What is the difference between Response byte: 08 AND Response byte: 55 ? | wadalhag | BB5BOX | 9 | 11-20-2007 00:16 |
Response byte: 08 Unlock fail. Please try again. | carlosdamian | BB5BOX | 34 | 11-10-2007 15:59 |
N73 - problem unlock, Response byte: 08 | Dmitry Erokhin | BB5BOX | 5 | 11-01-2007 22:05 |
Response byte: 08 or 55 or 00 | nykocam | BB5BOX | 2 | 10-12-2007 15:36 |
