01-07-2008, 00:13 | #1 (permalink) |
No Life Poster Join Date: Jan 2002 Location: Jordan Age: 46
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | E62 rm-88 died after restoring backup please see log>> ------ Operation: UNLOCK Date: 06-01-2008 Time: 23:45:22 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-88 Version: Vp_2.0618.06.17_10-08-06_RM-88_(c)_Nokia._ IMEI: 357951006125572 SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310150 Block 3: CLOSED Type 5 Data: 310170 Block 4: CLOSED Type 5 Data: 310170 Block 5: CLOSED Type 5 Data: 310410 Block 6: CLOSED Type 5 Data: 310410 Block 7: CLOSED Type 5 Data: 311180 Block 8: CLOSED Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-88_357951006125572_Locked_Keycnt_0_Fbuscnt_0__Vp_2 .0618.06.17_10-08-06_RM-88_(c)_Nokia._.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 1000 miliseconds Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. ------ Operation: UNLOCK Date: 06-01-2008 Time: 23:47:28 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-88 Version: Vp_2.0618.06.17_10-08-06_RM-88_(c)_Nokia._ IMEI: 357951006125572 SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310150 Block 3: CLOSED Type 5 Data: 310170 Block 4: CLOSED Type 5 Data: 310170 Block 5: CLOSED Type 5 Data: 310410 Block 6: CLOSED Type 5 Data: 310410 Block 7: CLOSED Type 5 Data: 311180 Block 8: CLOSED Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-88_357951006125572_Locked_Keycnt_0_Fbuscnt_10__Vp_ 2.0618.06.17_10-08-06_RM-88_(c)_Nokia._.bin already exist Counter limit reached. Please write PM 308 backup. ------ Operation: WRITE PM 308 Date: 06-01-2008 Time: 23:47:42 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-88 Version: Vp_2.0618.06.17_10-08-06_RM-88_(c)_Nokia._ IMEI: 357951006125572 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: UNLOCK Date: 06-01-2008 Time: 23:47:52 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface what to do??? Thanks in advance BR Mansi |
E62 RM-88 dead after flash | .:==di@bila==:. | Nokia Base Band 5 ( BB-5 ) | 13 | 12-20-2012 15:01 |
update requist for E62 RM-88 unlock | mansi | J.A.F. Plus | 4 | 03-09-2008 19:38 |
finally unlock e62 rm-88 | ahmertelecom | MT-BOX | 3 | 11-16-2007 15:24 |
e62 rm-88 dead | ahmertelecom | MT-BOX | 0 | 10-28-2007 21:05 |
Unlock E62 RM-88 | KHJAMAL | UID - Box | 0 | 10-12-2007 20:14 |
