12-21-2007, 01:12 | #1 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Paris Age: 47
Member: 82980 Status: Offline Thanks Meter: 23 | now box is Ok:):) and v0.0.2.8 all ok THANKS 6288 SPANSION XXXXX ----------------------------------------------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_06.43_30-03-07_RM-78_(c)_Nokia IMEI: 358669013768999 SP LOCK status: Config Key: 2680100000000000 Block 1: CLOSED Type 5 Data: 26801F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 4096 bytes Saving autobackup to file: RM-78_358669013768999_Locked_Keycnt_0_Fbuscnt_0__V_06 .43_30-03-07_RM-78_(c)_Nokia.bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-78_358669013768999_Locked_Keycnt_0_Fbuscnt_0__V_06 .43_30-03-07_RM-78_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2680100000000000 Block 1: CLOSED Type 5 Data: 26801F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2680100000000000 Block 1: OPEN Type 5 Data: 26801F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
12-21-2007, 02:04 | #3 (permalink) |
Member: 82980 Status: Offline Thanks Meter: 23 | http://www.bb5box.org/ DOWNLOAD BB5 UPDATER,and slect the ver. |
12-21-2007, 03:36 | #5 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: .:Planet Namek:.
Member: 189984 Status: Offline Thanks Meter: 112 | Quote:
12-21-2007, 05:34 | #7 (permalink) |
Member: 189984 Status: Offline Thanks Meter: 112 | thz so much, unlocked 3 N73.... 1000% downgrade fw version 11 to fw version 7, here is the log,,, Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v48.3_02-07-07_RM-133_(c)_Nokia. IMEI: 354804xxxxxxxxxxxxxxx SP LOCK status: Config Key: 7321010000000000 Block 1: CLOSED Type 5 Data: 732101 Block 2: CLOSED Type 5 Data: 732101 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-133_35480401xxxxxxxxxxxxxxx_Locked_Keycnt_0_Fbuscn t_0__V_05wk47v48.3_02-07-07_RM-133_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-133_354804xxxxxxxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_ 0__V_05wk47v48.3_02-07-07_RM-133_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 7321010000000000 Block 1: CLOSED Type 5 Data: 732101 Block 2: CLOSED Type 5 Data: 732101 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 7321010000000000 Block 1: OPEN Type 5 Data: 732101 Block 2: OPEN Type 5 Data: 732101 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull when try to unlock with sw 0.0.3.0, given error BYTE 08, 55, ...... support correct this bug.... thz in advance |
Great box is now end now. | Vijendra Saini | BB5BOX | 2 | 02-05-2010 21:55 |
Now Cyclone Box is Best box | Kethey | Cyclonebox | 47 | 10-11-2009 20:34 |
help my smartclip is box is dead now huhuhuhu | atoxpert | Smart-Clip | 1 | 05-11-2009 11:57 |
Now that Jaf is dead, wich box is the best to get | jdwe | Nokia Base Band 5 ( BB-5 ) | 5 | 03-20-2009 13:43 |
SO Now it is oficial: THIS SagMaster LOOK IS ALSO ORIGINAL BOX | Gobi | SagMaster Team OLD Products | 3 | 06-22-2004 22:28 |
