Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5BOX
Old 04-21-2008, 07:49   #1 (permalink)
WinD_VteC's Avatar
Member: 647414
Thanks Meter: 127
Help me raskal.......My phone Cannot Unlocking
My phone is 5200 I tired Unlocking But Failed Unlocking I try downgrade&upgrade oso Cannot Unlocking ... Wat is my phone Problem....pls help me.....urgent
this the Log
Connecting to BB5 Box ...
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-174
Version: V_05.51_05-09-07_RM-174_(c)_Nokia.
IMEI: 35984
SP LOCK status:
Config Key: 234330
Block 1: CLOSED Type 5 Data: 23433F
Block 2: CLOSED Type 5 Data: 23486F
Keyboard wrong codes counter: 0 wrong tries from max. 3 tries
Cable wrong codes counter: 4 wrong tries from max. 10 tries
Set Full Factory Defaults ...
Reset phone ...
Full Factory Defaults set OK
Skip autobackup of PM 308
Autobackup file:
RM-174_35984_Locked_Keycnt_0_Fbuscnt_4__V_05.51_0 5-09-07_RM-174_(c)_Nokia..bin
already exist
Checking if model/version is supported for unlock ...
Please connect testpoints
Testpoints connected OK
Keep Testpoints connected until unlock finish!
Unlocking phone ...
Try unlocking using keyboard codes ...
Try number (Keyboard): 1
Sending SP code: #pw+012345678901234+7#
Response byte: 08
Try number (Keyboard): 2
Response byte: 08
Try number (Keyboard): 3
Response byte: 08
Unlock using keyboard codes fail.
Try unlocking using cable codes ...
Try number (Cable): 5
Response byte: 08
Try number (Cable): 6
Response byte: 08
Try number (Cable): 7
Response byte: 08
Try number (Cable): 8
Response byte: 08
Try number (Cable): 9
Response byte: 08
Try number (Cable): 10
Response byte: 08
Unlock using cable codes fail.
Reading again SP Locks ...
SP LOCK status:
Config Key: 23433000000
Keyboard wrong codes counter: 3 wrong tries from max. 3 tries
Cable wrong codes counter: 10 wrong tries from max. 10 tries
Unlock fail. Please try again.
Best Regard
WinD
Old 04-21-2008, 10:00   #2 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
Thanks Meter: 719
iTS GROUND PROBLEM.......PLz be sure that the black crocodile clip is attached with phone ground welll....For best results attach it to viberator or nearer to the cpu....If still same then flash it with another supported ver and then try....Always read the manuall for best results!
Old 04-21-2008, 12:26   #3 (permalink)
unlocknas's Avatar
Member: 391805
Thanks Meter: 29
i have unlock 100 piece 5200 iwth bb5box no problem.
Old 04-21-2008, 12:40   #4 (permalink)
Ionel's Avatar
Member: 81232
Thanks Meter: 196
Try to flash phone with a new version of flash or same ver. after that try tu unlock phone.
Old 04-22-2008, 05:13   #5 (permalink)
WinD_VteC's Avatar
Member: 647414
Thanks Meter: 127
thanks For ur information But cannot use it.... But problem soft by me (crazy Unlocking)
Best Regard
WinD
Please help me turn my phone ON........see my LOG praveen5344 Sony Ericsson Hardware Repair 5 06-24-2009 16:57
help me now my phone n90 can't boot up after flash the flsh complete but the phone no dvdaio Nokia Base Band 5 ( BB-5 ) 2 05-24-2007 14:59
[T809]help me unlockin my phone!! samoelito Samsung Flashers, Software, Firmware. 3 08-03-2006 23:39
HELP ME please, my phone is dead! danny36 E-Gold Based Phones 3 08-12-2004 09:39
help me unblock my phone geMz Sony 1 11-22-2003 11:10
Page generated in 0.20432 seconds with 9 queries
