![]() | #137 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: maldives
Member: 389862 Status: Offline Sonork: guy_askali Thanks Meter: 54 | 55 pcs unlcked but yester day 6234 is canat unlcked when iam keep the test point onle sound caming after raiting 10 counter what canay do ser pls help me |
![]() | #140 (permalink) |
Banned ![]() ![]() ![]() ![]() ![]() ![]() Thanks Meter: 346 | one more successful unlock ------ Operation: READ PHONE INFO Date: 16-01-2008 Time: 11:21:22 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.00_27-04-07_RM-217_(c)_Nokia. IMEI: 359538012104226 SP LOCK status: Config Key: 2341000000000000 Block 1: CLOSED Type 5 Data: 23410F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 16-01-2008 Time: 11:21:30 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.00_27-04-07_RM-217_(c)_Nokia. IMEI: 359538012104226 SP LOCK status: Config Key: 2341000000000000 Block 1: CLOSED Type 5 Data: 23410F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-217_359538012104226_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-217_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2341000000000000 Block 1: OPEN Type 5 Data: 23410F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull thanku bb5 team. |
![]() | #143 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2006 Location: near by ur heart
Member: 254016 Status: Offline Sonork: principal(1576919) Thanks Meter: 13 | hi mates ![]() i have damaged my mobile ic balls may b ic plz tell me what i ll do ! thanks in advance ![]() |
![]() | #145 (permalink) |
Banned ![]() ![]() ![]() ![]() ![]() ![]() Thanks Meter: 346 | again one sucess unlock ------ Operation: READ PHONE INFO Date: 21-01-2008 Time: 11:19:15 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.50_14-08-07_RM-217_(c)_Nokia. IMEI: 359809012516382 SP LOCK status: Config Key: 2341000000000000 Block 1: CLOSED Type 5 Data: 23410F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 21-01-2008 Time: 11:19:23 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.50_14-08-07_RM-217_(c)_Nokia. IMEI: 359809012516382 SP LOCK status: Config Key: 2341000000000000 Block 1: CLOSED Type 5 Data: 23410F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-217_359809012516382_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_14-08-07_RM-217_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2341000000000000 Block 1: OPEN Type 5 Data: 23410F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull thanku bb5 team. |
![]() | #146 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2004 Location: gsm-land Age: 45
Member: 67419 Status: Offline Thanks Meter: 237 | Over 200 unlocks 2 apairs killed and revived . @Palica01 this is like ur 6280 . i have just finished . Try with the teory that other can do it ! why i not ? And you can be 100% correct unlocking this ones without killing .. ![]() ------ Operation: UNLOCK Date: 23-01-2008 Time: 08:59:30 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.40_20-12-05_RM-78_(c)_Nokia IMEI: 357603003719598 SP LOCK status: Config Key: 2229900093172790 Block 1: CLOSED Type 5 Data: 22299F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_357603003719598_Locked_Keycnt_0_Fbuscnt_0__V_03 .40_20-12-05_RM-78_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2229900093172790 Block 1: OPEN Type 5 Data: 22299F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
![]() | #149 (permalink) |
Banned ![]() ![]() ![]() ![]() ![]() ![]() Thanks Meter: 346 | ![]() again one sucessful unlock ------ Operation: READ PHONE INFO Date: 31-01-2008 Time: 11:05:22 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_03.92_13-10-06_RM-174_(c)_Nokia. IMEI: 354565019615669 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 31-01-2008 Time: 11:05:36 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_03.92_13-10-06_RM-174_(c)_Nokia. IMEI: 354565019615669 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-174_354565019615669_Locked_Keycnt_0_Fbuscnt_0__V_0 3.92_13-10-06_RM-174_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2343300000000000 Block 1: OPEN Type 5 Data: 23433F Block 2: OPEN Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull. thanku bb5 team. |
![]() | #150 (permalink) |
Banned ![]() ![]() ![]() ![]() ![]() ![]() Thanks Meter: 346 | ![]() and again ------ Operation: READ PHONE INFO Date: 01-02-2008 Time: 17:37:13 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_03.92_13-10-06_RM-174_(c)_Nokia. IMEI: 354565012600940 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 01-02-2008 Time: 17:37:21 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_03.92_13-10-06_RM-174_(c)_Nokia. IMEI: 354565012600940 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-174_354565012600940_Locked_Keycnt_0_Fbuscnt_0__V_0 3.92_13-10-06_RM-174_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2343300000000000 Block 1: OPEN Type 5 Data: 23433F Block 2: OPEN Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull thanku bb5 team. |
how to joined the many ring as one ringtone | PARMATMA | Nokia Multimedia | 15 | 06-17-2008 11:55 |
*** How many done?? How many killed?? *** | MatadorEngine.com | FMA clip | 4 | 02-03-2008 12:42 |
How many done? How many kill? :D | HatNet | BB5BOX | 0 | 10-17-2007 15:01 |
RPL logs from where, how many & how much | davesmobiles | MT-BOX | 1 | 10-09-2007 08:31 |
how reset v51 to many wrong entered nck | unlocktel | Motorola Old Legacy (EMMI) | 0 | 04-22-2003 17:59 |
