Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5BOX
Old 10-29-2007, 20:54   #76 (permalink)
Member: 159411
Thanks Meter: 8
ı kill one phone 6131 --- 0 done after try to unlock
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-115
Version: V_05.50_20-09-06_RM-115_(c)_Nokia.
IMEI: 354566018896953
SP LOCK status:
Config Key: 2620100000000000
Block 1: CLOSED Type 5 Data: 26201F
Keyboard wrong codes counter: 0 wrong tries from max. 3 tries
Cable wrong codes counter: 0 wrong tries from max. 10 tries
Set Full Factory Defaults ...
Reset phone ...
Full Factory Defaults set OK
Skip autobackup of PM 308
Autobackup file:
RM-115_354566018896953_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_20-09-06_RM-115_(c)_Nokia..bin
already exist
Auto Write PM 308 procedure started
Searching for backup file with lowest FBUS count ...
Finded backup file: RM-115_354566018896953_Locked_Keycnt_0_Fbuscnt_0__V_0 5.50_20-09-06_RM-115_(c)_Nokia..bin
Writting PM Field 308 Subfield 1 with length 8192 bytes
Reset phone ...
PM Field 308 Subfield 1 written OK
Reading SP Locks after Auto Write PM 308 ...
SP LOCK status:
Reset phone in TEST mode ...
Checking if model/version is supported for unlock ...
Please connect testpoints
Testpoints connected OK
Keep Testpoints connected until unlock finish!
Unlocking phone ...
Try number: 1
Sending SP code: #pw+012345678901234+7#
Response byte: 55
Try number: 2
Response byte: 55
Try number: 3
Response byte: 55
Try number: 4
Response byte: 55
Try number: 5
Response byte: 55
Try number: 6
Response byte: 55
Try number: 7
Response byte: 55
Try number: 8
Response byte: 55
Try number: 9
Response byte: 55
Try number: 10
Response byte: 55
Unlock fail. Please try again.
after phone not working anymore flash procesor is dead now
Old 10-30-2007, 00:55   #77 (permalink)
S.O.S.G.S.M's Avatar
Member: 114675
Sonork: 100.1609922
Thanks Meter: 126
23 >>>> 6085 unlocked
12 >>>> 5200 unlocked
18 >>>> 6280 unlocked
06 >>>> 6131 unlocked
04 >>>> 6300 unlocked
01 >>>> 6086 unlocked
03 >>>> 6234 unlocked
05 >>>> 5300 unlocked
01 >>>> n80 unlocked
01 >>>> 6085 killed don't know why
Old 10-31-2007, 15:25   #78 (permalink)
Member: 363420
Red face 0 unlock and 3phones Killed
0 unlock and 3phones Killed( 6280, 6300, E65)
Old 10-31-2007, 15:50   #79 (permalink)
abumu3ed's Avatar
Member: 462224
Sonork: 100.1586374
Thanks Meter: 103
02>>>>> succsessfull 5200 ATB/ATD
01>>>>> failed E65
00>>>>> KILLED (thank G_O_D)
Old 10-31-2007, 18:37   #80 (permalink)
Singh05's Avatar
Member: 69293
Thanks Meter: 19
unlocked more than 300,
0 killed
Happy with BB5box
Old 10-31-2007, 19:38   #81 (permalink)
Member: 297936
Thanks Meter: 201
I think u should wait for non-tp solution...
Old 10-31-2007, 19:43   #82 (permalink)
Ionel's Avatar
Member: 81232
Thanks Meter: 196
First phone , 6280 unlocked ok .
Old 10-31-2007, 19:46   #83 (permalink)
Member: 144428
6280 - 5 done, 2 - killed, my mistake ( no microscope, only a magnifying lamp, too much coffee and short nights)
6233 - 2 done, 0 - killed
6234 - 2 done, 0 - killed
N73 - 1 done, 0 - killed
6288 - 1 not done (don't know why)
Old 11-01-2007, 12:20   #84 (permalink)
Member: 94038
just buy another bb5box
Hi everybody
I'm a BB5 Box user.
I read many time the BB5BOX manual and follow carefully its instructions.
But unsuccessfully I killed all phones I try to unlock with this Box.
I Killed Nokia 6280, E65, 6300. All of the phones are getting Hot flash IC.
I try to unlock these phones with original Nokia charger.
Please Does anyone Know what to do to revive this phones.
Awaiting for your urgent attention on this matter.
With regards.
some bb5box kill phones, i have two bb5box, the fist one is a frying box, with original nokia charger, with adaptor/regulated power supply, without any external power supply at all, it was killing phones. whether 4.2,4.7,5.0 voltage(8phones 5200,5300,7373,6234,6300) this did not stop untill a friend who has the same box came to my shop witnessed the last one killed advised me to buy from another supplier. Since i bought the second bb5box, without any external power supply, now i have unlocked more than 60 different phones successfully, none killed. bb5box is the best out there now but pray not to buy the fryer.
Old 11-02-2007, 09:09   #85 (permalink)
imd
Member: 226909
Thanks Meter: 4
over 250 pieces done 0 dead
done over 250 pieces mixed nokia 6280-88 n73 6300-6085 none dead i dont know how you guys are killing them but i must say i have modified my cable abit being to short thats why and got small testpoint pins for example n73 touch solder ball 14 is very difficult be persisatnt and you will succeed
raskal you and the boyz are the bomb keep up the good work can we ad flashing maybe to the bb5 box so we can maybe upgrade and downgrade version for unlock just a thought
Old 11-02-2007, 09:20   #86 (permalink)
Member: 619908
Thanks Meter: 2
i kill one phone 6280
Old 11-02-2007, 18:55   #87 (permalink)
Member: 95684
done 10 killed none realy good box
Old 11-05-2007, 15:46   #88 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
6131 - ok
N95 - ok
2x6280 (spansion flash) - killed (I cannot write the flash anymore)
Old 11-08-2007, 15:28   #89 (permalink)
Member: 608022
Thanks Meter: 3
more and more
i do manys phones but now in just one day
hey i kill 2
1= 6280 spancion, i don't know how but is dead
1= 5300b what hapen with this one when i conect the tp it just made a errol and that it a dead one
i think the box is good but why kills those phone was me or box so i ask mr raskal tell me how i can fix the pics if that posible?/
Old 11-09-2007, 02:33   #90 (permalink)
Member: 297936
Thanks Meter: 201
20- units unlocked
0- killed
how to joined the many ring as one ringtone PARMATMA Nokia Multimedia 15 06-17-2008 11:55
*** How many done?? How many killed?? *** MatadorEngine.com FMA clip 4 02-03-2008 12:42
How many done? How many kill? :D HatNet BB5BOX 0 10-17-2007 15:01
RPL logs from where, how many & how much davesmobiles MT-BOX 1 10-09-2007 08:31
how reset v51 to many wrong entered nck unlocktel Motorola Old Legacy (EMMI) 0 04-22-2003 17:59
Page generated in 0.21981 seconds with 9 queries
