11-11-2007, 17:00 | #94 (permalink) |
Freak Poster Join Date: Feb 2002 Location: Portugal / Lisboa Age: 50
Member: 9368 Status: Offline Thanks Meter: 1 | 6085 Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-198 Version: V_04.26_16-03-07_RM-198_(c)_Nokia. IMEI: 354845019019041 SP LOCK status: Config Key: 2680600000000000 Block 1: CLOSED Type 5 Data: 26806F Keyboard wrong codes counter: 1 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-198_354845019019041_Locked_Keycnt_1_Fbuscnt_0__V_0 4.26_16-03-07_RM-198_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-198_354845019019041_Locked_Keycnt_1_Fbuscnt_0__V_0 4.26_16-03-07_RM-198_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2680600000000000 Block 1: CLOSED Type 5 Data: 26806F Keyboard wrong codes counter: 1 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2680600000000000 Block 1: OPEN Type 5 Data: 26806F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
11-12-2007, 16:18 | #95 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: Phnom Penh(CAMBODIA)
Member: 447590 Status: Offline Thanks Meter: 378 | how to unlock 6085 Quote:
HOW TO UNLOCK 6085 WITH SPANSION CHIP?PLS HELP. | |
11-13-2007, 23:30 | #97 (permalink) |
Crazy Poster Join Date: Jul 2005 Location: Colombia Age: 44
Member: 160485 Status: Offline Thanks Meter: 12 | bb5 box kill 2 5200 & 6131 result dead 5200 bb5 box ------ Operation: UNLOCK Date: 13-11-2007 Time: 13:02:37 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-181 Version: V_03.92_13-10-06_RM-181_(c)_Nokia. IMEI: 356439011119724 SP LOCK status: Config Key: 7321230140723740 Block 1: CLOSED Type 5 Data: 732123 Block 2: CLOSED Type 5 Data: 74000F Block 3: CLOSED Type 5 Data: 21407F Block 4: CLOSED Type 5 Data: 21402F Block 5: CLOSED Type 5 Data: 33403F Block 6: CLOSED Type 5 Data: 70403F Block 7: CLOSED Type 5 Data: 70604F Block 8: CLOSED Type 5 Data: 71030F Block 9: CLOSED Type 5 Data: 71402F Block 10: CLOSED Type 5 Data: 71606F Block 11: CLOSED Type 5 Data: 73002F Block 12: CLOSED Type 5 Data: 72207F Block 13: CLOSED Type 5 Data: 74807F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-174_356439011119724_Locked_Keycnt_0_Fbuscnt_0__V_0 3.92_13-10-06_RM-181_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-174_356439011119724_Locked_Keycnt_0_Fbuscnt_0__V_0 3.92_13-10-06_RM-181_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 7321230140723740 Block 1: CLOSED Type 5 Data: 732123 Block 2: CLOSED Type 5 Data: 74000F Block 3: CLOSED Type 5 Data: 21407F Block 4: CLOSED Type 5 Data: 21402F Block 5: CLOSED Type 5 Data: 33403F Block 6: CLOSED Type 5 Data: 70403F Block 7: CLOSED Type 5 Data: 70604F Block 8: CLOSED Type 5 Data: 71030F Block 9: CLOSED Type 5 Data: 71402F Block 10: CLOSED Type 5 Data: 71606F Block 11: CLOSED Type 5 Data: 73002F Block 12: CLOSED Type 5 Data: 72207F Block 13: CLOSED Type 5 Data: 74807F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... ERROR: 11160001 ERROR: 30020091 |
11-14-2007, 14:43 | #98 (permalink) |
No Life Poster Join Date: Jul 2006 Location: ghana
Member: 320120 Status: Offline Thanks Meter: 98 | mistakes are bound to happen. freinds should also try and tell others their aided materials. eg. may be magnifying glasses or microscope. tell what people should gather before unlocking bb5 fones. testpoint of 6280 is crazy, i have them plenty. please help others with your ideas. thx |
11-15-2007, 14:08 | #100 (permalink) |
Member: 320120 Status: Offline Thanks Meter: 98 | after killing, any solution??? get solution to this problem b4 is too late for users big men do something i unlock 2 6300 1 6085 and killed 1 6085. testpoint is clear but what is the problem?? any advice or solution |
11-16-2007, 13:29 | #102 (permalink) |
Junior Member Join Date: Jun 2003 Location: Canary Islands Age: 45
Member: 31721 Status: Offline Thanks Meter: 2 | 6280 3 Done (Spansion) / 1 kill (Spansion) (I think too much trys, maybe i broken the tp) 6125 2 Done 5200 7 Done 6234 2 Done (ETM) / 1 cant unlock (Spansion) 6300 3 Done 6085 0 Done / 1 Kill (Dont know why, easy tp but the same like 6280, show nokia and go off) |
11-18-2007, 13:16 | #105 (permalink) |
Freak Poster Join Date: Nov 2007 Location: btw testpoint and cpu
Member: 634275 Status: Offline Sonork: 100.1619208 Thanks Meter: 27 | 5200 v 4.71 unlock ok Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_04.71_28-02-07_RM-174_(c)_Nokia. IMEI: 354565017853874 SP LOCK status: Config Key: 2080100000000000 Block 1: CLOSED Type 5 Data: 20801F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-174_354565017853874_Locked_Keycnt_0_Fbuscnt_10__V_ 04.71_28-02-07_RM-174_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-174_354565017853874_Locked_Keycnt_0_Fbuscnt_0__V_0 4.71_28-02-07_RM-174_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2080100000000000 Block 1: CLOSED Type 5 Data: 20801F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2080100000000000 Block 1: OPEN Type 5 Data: 20801F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlockedsuccesfull |
how to joined the many ring as one ringtone | PARMATMA | Nokia Multimedia | 15 | 06-17-2008 11:55 |
*** How many done?? How many killed?? *** | MatadorEngine.com | FMA clip | 4 | 02-03-2008 12:42 |
How many done? How many kill? :D | HatNet | BB5BOX | 0 | 10-17-2007 15:01 |
RPL logs from where, how many & how much | davesmobiles | MT-BOX | 1 | 10-09-2007 08:31 |
how reset v51 to many wrong entered nck | unlocktel | Motorola Old Legacy (EMMI) | 0 | 04-22-2003 17:59 |
