11-18-2007, 13:19 | #106 (permalink) |
Freak Poster Join Date: Nov 2007 Location: btw testpoint and cpu
Member: 634275 Status: Offline Sonork: 100.1619208 Thanks Meter: 27 | Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-78 Version: V_03.60_10-02-06_RM-78_(c)_Nokia IMEI: 359382003612685 SP LOCK status: Config Key: 2620100000000000 Block 1: CLOSED Type 5 Data: 26201F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-78_359382003612685_Locked_Keycnt_0_Fbuscnt_0__V_03 .60_10-02-06_RM-78_(c)_Nokia.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-78_359382003612685_Locked_Keycnt_0_Fbuscnt_0__V_03 .60_10-02-06_RM-78_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2620100000000000 Block 1: CLOSED Type 5 Data: 26201F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 02 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 0000000000000000 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
11-23-2007, 19:04 | #112 (permalink) | |
Freak Poster Join Date: Feb 2007 Location: Cellphone world
Member: 445380 Status: Offline Thanks Meter: 6 | Quote:
regards | |
11-30-2007, 15:01 | #113 (permalink) |
Crazy Poster Join Date: Feb 2006
Member: 228551 Status: Offline Thanks Meter: 3 | Ok... bought box last week. The mini usb cable was faulty, I killed three phones before it worked... The phones would not read, i connected yellow cable to - pin, instead of VBAT - my eyes are not good and i thought manual meant - pin... Anyway, the red pin cable was broke, so i bought new cable and ACP-12X charger, since i have unlocked 10 perfect - no problems now. Anyone know how to fix dead phone, caused by yellow to - instead of vbat. |
12-02-2007, 16:55 | #114 (permalink) |
Junior Member Join Date: Feb 2007
Member: 450731 Status: Offline Thanks Meter: 0 | 120 Done 3 Killed Specialy 5300 When I Connect The Positive And Bsi And Usb Conector If Will Not Read Info After That Phone Is No Power I Always Me Used Charger Adaptor Now Same With E62 Dead Pls Give Advice Whatwill Happen |
12-09-2007, 20:21 | #118 (permalink) |
Freak Poster Join Date: Apr 2004 Location: guinea conakry Age: 44
Member: 63749 Status: Offline Thanks Meter: 14 | 1killed 6085 and 6131 few unlocked mostly them u can unlock wilthout microscope.let try to find a way to revive the killed with bb5box please |
how to joined the many ring as one ringtone | PARMATMA | Nokia Multimedia | 15 | 06-17-2008 11:55 |
*** How many done?? How many killed?? *** | MatadorEngine.com | FMA clip | 4 | 02-03-2008 12:42 |
How many done? How many kill? :D | HatNet | BB5BOX | 0 | 10-17-2007 15:01 |
RPL logs from where, how many & how much | davesmobiles | MT-BOX | 1 | 10-09-2007 08:31 |
how reset v51 to many wrong entered nck | unlocktel | Motorola Old Legacy (EMMI) | 0 | 04-22-2003 17:59 |
