12-12-2007, 15:36 | #121 (permalink) |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,013 | killed 1 5200 even i did the same way ?? don't know if was my fault in tp or box pb... could,t do 6280 and 6151 error 05 error 55 think need more practice hope new tp will be released soon |
12-24-2007, 15:11 | #126 (permalink) |
Banned Thanks Meter: 346 | my successful unlock ------ Operation: READ PHONE INFO Date: 24-12-2007 Time: 19:23:06 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-43 Version: V_w33_06w16v2_20-04-06_RM-43_(c)_Nokia. IMEI: 358391000980939 SP LOCK status: Config Key: 5050600042465540 Block 1: CLOSED Type 5 Data: 50506F Block 2: CLOSED Type 5 Data: 50599F Block 3: CLOSED Type 5 Data: 50506F Block 4: CLOSED Type 5 Data: 50599F Block 5: CLOSED Type 5 Data: 00101F Block 6: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 24-12-2007 Time: 19:23:16 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-43 Version: V_w33_06w16v2_20-04-06_RM-43_(c)_Nokia. IMEI: 358391000980939 SP LOCK status: Config Key: 5050600042465540 Block 1: CLOSED Type 5 Data: 50506F Block 2: CLOSED Type 5 Data: 50599F Block 3: CLOSED Type 5 Data: 50506F Block 4: CLOSED Type 5 Data: 50599F Block 5: CLOSED Type 5 Data: 00101F Block 6: CLOSED Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-43_358391000980939_Locked_Keycnt_0_Fbuscnt_0__V_w3 3_06w16v2_20-04-06_RM-43_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 5050600042465540 Block 1: OPEN Type 5 Data: 50506F Block 2: OPEN Type 5 Data: 50599F Block 3: OPEN Type 5 Data: 50506F Block 4: OPEN Type 5 Data: 50599F Block 5: OPEN Type 5 Data: 00101F Block 6: OPEN Type 5 Data: 00101F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull thanks bb5 team. |
12-26-2007, 08:28 | #127 (permalink) |
Banned Thanks Meter: 346 | one more successful unlock Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.00_27-04-07_RM-217_(c)_Nokia. IMEI: 359538012152019 SP LOCK status: Config Key: 2341000000000000 Block 1: CLOSED Type 5 Data: 23410F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-217_359538012152019_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-217_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2341000000000000 Block 1: OPEN Type 5 Data: 23410F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull thanks bb5 team. |
12-30-2007, 17:01 | #130 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 532172 Status: Offline Thanks Meter: 2 | hi, I HAVE DONE 14 AND KILLED 3. BB5 BOX WORKS FINE. WITH PHONES THAT HAVE SIMPLE TP'S BUT WITH TP'S LIKE 6280 THE RISK IS VERY HIGH. MY ADVICE IS FOR OUR SENIOURS TO HELP US WITH A SOLFWARE THAT CAN REVIVE THE DEAD PHONES. THEN IT WILL BE THE PERFECT BOX. BR |
01-04-2008, 16:07 | #134 (permalink) |
Banned Thanks Meter: 346 | one more sucessful unlock Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_04.51_11-01-07_RM-146_(c)_Nokia. IMEI: 354567012868758 SP LOCK status: Config Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310300 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 6 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-146_354567012868758_Locked_Keycnt_3_Fbuscnt_6__V_0 4.51_11-01-07_RM-146_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 3102000000000000 Block 1: OPEN Type 5 Data: 310160 Block 2: OPEN Type 5 Data: 310200 Block 3: OPEN Type 5 Data: 310210 Block 4: OPEN Type 5 Data: 310220 Block 5: OPEN Type 5 Data: 310230 Block 6: OPEN Type 5 Data: 310240 Block 7: OPEN Type 5 Data: 310250 Block 8: OPEN Type 5 Data: 310260 Block 9: OPEN Type 5 Data: 310270 Block 10: OPEN Type 5 Data: 310300 Block 11: OPEN Type 5 Data: 310310 Block 12: OPEN Type 5 Data: 310490 Block 13: OPEN Type 5 Data: 310530 Block 14: OPEN Type 5 Data: 310580 Block 15: OPEN Type 5 Data: 310590 Block 16: OPEN Type 5 Data: 310640 Block 17: OPEN Type 5 Data: 310660 Block 18: OPEN Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull thanku bb5 team |
01-04-2008, 16:08 | #135 (permalink) |
Banned Thanks Meter: 346 | one more sucessful unlock Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-146 Version: V_04.51_11-01-07_RM-146_(c)_Nokia. IMEI: 354567012868758 SP LOCK status: Config Key: 3102000000000000 Block 1: CLOSED Type 5 Data: 310160 Block 2: CLOSED Type 5 Data: 310200 Block 3: CLOSED Type 5 Data: 310210 Block 4: CLOSED Type 5 Data: 310220 Block 5: CLOSED Type 5 Data: 310230 Block 6: CLOSED Type 5 Data: 310240 Block 7: CLOSED Type 5 Data: 310250 Block 8: CLOSED Type 5 Data: 310260 Block 9: CLOSED Type 5 Data: 310270 Block 10: CLOSED Type 5 Data: 310300 Block 11: CLOSED Type 5 Data: 310310 Block 12: CLOSED Type 5 Data: 310490 Block 13: CLOSED Type 5 Data: 310530 Block 14: CLOSED Type 5 Data: 310580 Block 15: CLOSED Type 5 Data: 310590 Block 16: CLOSED Type 5 Data: 310640 Block 17: CLOSED Type 5 Data: 310660 Block 18: CLOSED Type 5 Data: 310800 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 6 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-146_354567012868758_Locked_Keycnt_3_Fbuscnt_6__V_0 4.51_11-01-07_RM-146_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 3102000000000000 Block 1: OPEN Type 5 Data: 310160 Block 2: OPEN Type 5 Data: 310200 Block 3: OPEN Type 5 Data: 310210 Block 4: OPEN Type 5 Data: 310220 Block 5: OPEN Type 5 Data: 310230 Block 6: OPEN Type 5 Data: 310240 Block 7: OPEN Type 5 Data: 310250 Block 8: OPEN Type 5 Data: 310260 Block 9: OPEN Type 5 Data: 310270 Block 10: OPEN Type 5 Data: 310300 Block 11: OPEN Type 5 Data: 310310 Block 12: OPEN Type 5 Data: 310490 Block 13: OPEN Type 5 Data: 310530 Block 14: OPEN Type 5 Data: 310580 Block 15: OPEN Type 5 Data: 310590 Block 16: OPEN Type 5 Data: 310640 Block 17: OPEN Type 5 Data: 310660 Block 18: OPEN Type 5 Data: 310800 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull thanku bb5 team. |
how to joined the many ring as one ringtone | PARMATMA | Nokia Multimedia | 15 | 06-17-2008 11:55 |
*** How many done?? How many killed?? *** | MatadorEngine.com | FMA clip | 4 | 02-03-2008 12:42 |
How many done? How many kill? :D | HatNet | BB5BOX | 0 | 10-17-2007 15:01 |
RPL logs from where, how many & how much | davesmobiles | MT-BOX | 1 | 10-09-2007 08:31 |
how reset v51 to many wrong entered nck | unlocktel | Motorola Old Legacy (EMMI) | 0 | 04-22-2003 17:59 |
