01-08-2008, 02:38 | #1 (permalink) |
Junior Member Join Date: Aug 2004 Location: poland Age: 46
Member: 76232 Status: Offline Thanks Meter: 0 | "Keyboard wrong codes counter: 3 wrong tries from max. 3 tries" - But unlocked succ here is log of this operation: ------ Operation: READ PHONE INFO Date: 08-01-2008 Time: 02:05:04 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-145 Version: V_04.91_25-09-06_RM-145_(c)_Nokia IMEI: 3527490xxxxxxxx SP LOCK status: Config Key: 2420100000000000 Block 1: CLOSED Type 5 Data: 24201F Block 2: CLOSED Type 5 Data: 24201F Block 3: CLOSED Type 5 Data: 24201F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 08-01-2008 Time: 02:05:26 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-145 Version: V_04.91_25-09-06_RM-145_(c)_Nokia IMEI: 3527490xxxxxxxx SP LOCK status: Config Key: 2420100000000000 Block 1: CLOSED Type 5 Data: 24201F Block 2: CLOSED Type 5 Data: 24201F Block 3: CLOSED Type 5 Data: 24201F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-145_352749012495913_Locked_Keycnt_3_Fbuscnt_0__V_0 4.91_25-09-06_RM-145_(c)_Nokia.bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock fail. Please try again. ------ Operation: READ PHONE INFO Date: 08-01-2008 Time: 02:06:59 ------- Connecting to BB5 Box ... Searching for phone ... ERROR: Cannot detect phone on FBUS interface ------ Operation: READ PHONE INFO Date: 08-01-2008 Time: 02:07:07 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-145 Version: V_04.91_25-09-06_RM-145_(c)_Nokia IMEI: 3527490xxxxxxxx SP LOCK status: Config Key: 2420100000000000 Block 1: CLOSED Type 5 Data: 24201F Block 2: CLOSED Type 5 Data: 24201F Block 3: CLOSED Type 5 Data: 24201F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... This model/version IS SUPPORTED for unlock. ------ Operation: UNLOCK Date: 08-01-2008 Time: 02:07:19 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-145 Version: V_04.91_25-09-06_RM-145_(c)_Nokia IMEI: 3527490xxxxxxxx SP LOCK status: Config Key: 2420100000000000 Block 1: CLOSED Type 5 Data: 24201F Block 2: CLOSED Type 5 Data: 24201F Block 3: CLOSED Type 5 Data: 24201F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-145_352749012495913_Locked_Keycnt_3_Fbuscnt_0__V_0 4.91_25-09-06_RM-145_(c)_Nokia.bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2420100000000000 Block 1: OPEN Type 5 Data: 24201F Block 2: OPEN Type 5 Data: 24201F Block 3: OPEN Type 5 Data: 24201F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
01-08-2008, 05:03 | #3 (permalink) |
No Life Poster Join Date: Aug 2007 Location: inside the pcb board
Member: 568876 Status: Offline Thanks Meter: 99 | Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries IF GOES LIKE THIS......CO'Z I'VE ENCOUNTERED THIS PROBLEM... I CAN'T UNLOCKED IT.....???? WHAT IS THE SOLUTION FOR THIS PROBLEM????? |
01-08-2008, 05:18 | #5 (permalink) |
Freak Poster Join Date: May 2007
Member: 518708 Status: Offline Thanks Meter: 67 | hy! did your phone already came with 10/10 cable counter? if you have backup of field pm308 just write the backup with 0/10... if you dont have this backup the only way for you is to calculate rpl (but ask to rpl calculation is down at this time and i dont know if and when it will be available again)... br |
Cable wrong codes counter: 10 wrong tries from max. 10 tries | sggp | BB5BOX | 5 | 03-28-2008 17:42 |
Keyboard wrong codes counter: 3 wrong tries from max. 3 tries | ronkiton | BB5BOX | 0 | 12-10-2007 07:48 |
Keyboard wrong codes counter: 3 wrong tries ---- can we unlock this without RPL? | wadalhag | BB5BOX | 4 | 11-26-2007 16:04 |
E65 with 10 wrong tries from max. 10 tries?? | HaNiNi Gsm | BB5BOX | 4 | 10-19-2007 18:38 |
Cable wrong codes counter: 10 wrong tries from max. 10 tries | fone_fusion | BB5BOX | 5 | 10-19-2007 06:33 |
