N73 unlocked well without microscope!! N73 unlocked well without microscope just need to open your eyes ;) HERE İS LOG: Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v28.1_22-06-06_RM-133_(c)_Nokia. IMEI: 3597380XXXXXXX SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Block 2: CLOSED Type 5 Data: 23420F Block 3: CLOSED Type 5 Data: 23594F Block 4: CLOSED Type 5 Data: 23594F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-133_359738XXXXXXX_Locked_Keycnt_0_Fbuscnt_0__V_05w k47v28.1_22-06-06_RM-133_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-133_359738XXXXXXX_Locked_Keycnt_0_Fbuscnt_0__V_05w k47v28.1_22-06-06_RM-133_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Block 2: CLOSED Type 5 Data: 23420F Block 3: CLOSED Type 5 Data: 23594F Block 4: CLOSED Type 5 Data: 23594F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2342000000000000 Block 1: OPEN Type 5 Data: 23420F Block 2: OPEN Type 5 Data: 23420F Block 3: OPEN Type 5 Data: 23594F Block 4: OPEN Type 5 Data: 23594F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
nice job sir,..we unlock also n80 without microscope hehehehe very difficult but we did at the 5th times.... |
i never use microscope for bb5 phones |
THANK U 4 thise good update |
WTF :eek::eek::eek::eek::eek: update wath??/ |
Nothing New !!! Allmost peoples doing N73 with out microscop, i did 1st n73 in 2nd try( with out microscop) so nothing new in this thread..anyway maybe helpful for some peoples |
HOW ?????????????????? man some people have good eye sight ....................... |
I always do it with my eyes closed, and one arm behind my back. Its working well if you practice. regards Sjakie |
maybe you closed your eyes after connecting tp and another hand helping you while holding the board heheh :-) |
video? Quote:
without microscope only small needle superr UNLOCK n73 unlock n73-Nokia 6233 Nokia 6131 ok best box bb5 ----------------------------------------------------------------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v46.3_04-06-07_RM-133_(c)_Nokia. IMEI: 35275701xxxxxxxxx SP LOCK status: Config Key: 2620100000000000 Block 1: CLOSED Type 5 Data: 26201F Block 2: CLOSED Type 5 Data: 26201F ------------------------------------------------------------------ SP LOCK status: Config Key: 2620100000000000 Block 1: OPEN Type 5 Data: 26201F Block 2: OPEN Type 5 Data: 26201F without microscope only small needle superr UNLOCK n73 |
Connecting to BB5 Box ...Searching for phone ...Phone found on FBUS interfaceReading phone info ...Type: RM-133Version: V_05wk47v28.1_22-06-06_RM-133_(c)_Nokia.IMEI: 352757010706512SP LOCK status: Config Key: 2382000000000000 Block 1: CLOSED Type 5 Data: 23820F Block 2: CLOSED Type 5 Data: 23830F Block 3: CLOSED Type 5 Data: 23820F Block 4: CLOSED Type 5 Data: 23830FKeyboard wrong codes counter: 0 wrong tries from max. 3 triesCable wrong codes counter: 0 wrong tries from max. 10 triesChecking if model/version is supported for unlock ...Model/version NOT supported for unlock. Please upgrade or downgrade! |
------ Operation: UNLOCK Date: 26-11-2007 Time: 15:23:24 ------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v28.1_22-06-06_RM-133_(c)_Nokia. IMEI: 35xxxxxxxxxxxxx SP LOCK status: Config Key: 2382000000000000 Block 1: CLOSED Type 5 Data: 23820F Block 2: CLOSED Type 5 Data: 23830F Block 3: CLOSED Type 5 Data: 23820F Block 4: CLOSED Type 5 Data: 23830F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-133_35xxxxxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_10__V_ 05wk47v28.1_22-06-06_RM-133_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-133_35xxxxxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v28.1_22-06-06_RM-133_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2382000000000000 Block 1: CLOSED Type 5 Data: 23820F Block 2: CLOSED Type 5 Data: 23830F Block 3: CLOSED Type 5 Data: 23820F Block 4: CLOSED Type 5 Data: 23830F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2382000000000000 Block 1: OPEN Type 5 Data: 23820F Block 2: OPEN Type 5 Data: 23830F Block 3: OPEN Type 5 Data: 23820F Block 4: OPEN Type 5 Data: 23830F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull <<flashed with the same file and the phone was supported>>:confused::confused: |
The n73 is very easy unlock without microscope, With the new adaptador is very very easy. Nokia127 |
