10-06-2007, 19:44 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Age: 45
Member: 49581 Status: Offline Thanks Meter: 73 | 023 cannot do 5200b v5.0 ... i unlocked this model with older version of BB5Box software b4, without any poroblem.. only the 023 giving me problem after update it is an ATD chip ..... finally i switch to another box and unlock at the 1st try .... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-181 Version: V_05.00_27-04-07_RM-181_(c)_Nokia. IMEI: 3564390xxxxxx06 SP LOCK status: Config Key: 3027200000000000 Block 1: CLOSED Type 5 Data: 302370 Block 2: CLOSED Type 5 Data: 302720 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-181_3564390xxxxxx06_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-181_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-181_3564390xxxxxx06_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-181_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 3027200000000000 Block 1: CLOSED Type 5 Data: 302370 Block 2: CLOSED Type 5 Data: 302720 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. ------ Operation: WRITE PM 308 Date: 06-10-2007 Time: 11:32:33 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-181 Version: V_05.00_27-04-07_RM-181_(c)_Nokia. IMEI: 3564390xxxxxx06 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK ------ Operation: READ PHONE INFO Date: 06-10-2007 Time: 11:32:50 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-181 Version: V_05.00_27-04-07_RM-181_(c)_Nokia. IMEI: 3564390xxxxxx06 SP LOCK status: Config Key: 3027200000000000 Block 1: CLOSED Type 5 Data: 302370 Block 2: CLOSED Type 5 Data: 302720 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries ------ Operation: UNLOCK Date: 06-10-2007 Time: 11:32:54 ------- Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-181 Version: V_05.00_27-04-07_RM-181_(c)_Nokia. IMEI: 3564390xxxxxx06 SP LOCK status: Config Key: 3027200000000000 Block 1: CLOSED Type 5 Data: 302370 Block 2: CLOSED Type 5 Data: 302720 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Skip autobackup of PM 308 Autobackup file: RM-181_3564390xxxxxx06_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-181_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-181_3564390xxxxxx06_Locked_Keycnt_0_Fbuscnt_0__V_0 5.00_27-04-07_RM-181_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... User cancel, exit procedure |
5200b v5.00 unlocked but abnormal... | gsmdoctorca | BB5BOX | 1 | 10-01-2007 10:02 |
V5.0 & V5.1 Working Now! Problem Solved! | RoDNoc | Motorola P2K (USB-Smart) | 20 | 07-16-2006 19:13 |
couldnīt find ver v5.0.0.67 | opelastra16i | Trisha & Matrix Flasher | 2 | 10-17-2004 21:48 |
When DCT-3 support in v5.0.0.56? | king180579 | Trisha & Matrix Flasher | 2 | 06-28-2004 23:33 |
