12-13-2007, 08:45 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Pakistan
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | E61 Successfull Unlock Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-89 Version: V_3.0533.6_31-10-06_RM-89_(c)_Nokia. IMEI: xxxxxxxxxxxxxxx SP LOCK status: Config Key: 2140100000000000 Block 1: CLOSED Type 5 Data: 21401F Block 2: CLOSED Type 5 Data: 21401F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-89_xxxxxxxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_0__V_3. 0533.6_31-10-06_RM-89_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-89_xxxxxxxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_0__V_3. 0533.6_31-10-06_RM-89_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2140100000000000 Block 1: CLOSED Type 5 Data: 21401F Block 2: CLOSED Type 5 Data: 21401F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2140100000000000 Block 1: OPEN Type 5 Data: 21401F Block 2: OPEN Type 5 Data: 21401F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
01-06-2008, 20:44 | #4 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: The pub
Member: 236929 Status: Offline Thanks Meter: 12 | e61 Quote:
Also for future reference, I only removed the one cap(red one in attachment) and did not put it back on after unlock and the phone seems to work fine . Reading phone info ... Type: RM-89 Version: V_3.0533.6_31-10-06_RM-89_(c)_Nokia. IMEI: 3562110010997-- SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Block 2: CLOSED Type 5 Data: 23420F Block 3: CLOSED Type 5 Data: 23594F Block 4: CLOSED Type 5 Data: 23594F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Skip autobackup of PM 308 Autobackup file: RM-89_356211001099772_Locked_Keycnt_0_Fbuscnt_0__V_3. 0533.6_31-10-06_RM-89_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2342000000000000 Block 1: OPEN Type 5 Data: 23420F Block 2: OPEN Type 5 Data: 23420F Block 3: OPEN Type 5 Data: 23594F Block 4: OPEN Type 5 Data: 23594F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull | |
01-13-2014, 17:34 | #5 (permalink) |
Junior Member Join Date: Aug 2007
Member: 559962 Status: Offline Thanks Meter: 0 | can somebodey help......i found one E61 in perfect shape but locked on Austria a1 network and i am from serbia..... if somebodey would be kind enough to calculate me the unlock codes that would be perfect ime :356211/00/143053/0 code:0536327 rm89 model e61-1 fccidyarm-89 ic:661v-rm89 |
Successfull Unlock SE W395 With SE Full Unlocker 2.40 | vlady | Cruiser Suite | 0 | 08-10-2009 18:11 |
KU250 successfull unlock with new unlock database update | markali2006 | Z3X-Team Products | 2 | 06-09-2009 05:43 |
C902 Successfull Unlock with SE Ultimate Unlocker v1.01 by Cruiser Team | Anees-ur-rehman | Cruiser Suite | 0 | 09-29-2008 11:41 |
successfull unlock 1110i without credits | ikhlaq | Universalbox | 2 | 01-21-2007 23:06 |
another v3i successfull unlock | tolski | Smart-Clip | 0 | 08-10-2006 17:16 |
