03-24-2008, 21:04 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Fast-Code™ MBKPHONE Ltd Age: 38
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | 5300b V_05.51_05-09-07_RM-147 cant be unlock by bb5 box its my 1st phone that cant be unlock wiz bb5box... any 1 can help me to solve this......... phone version was v 5.10 (not support) i upgrade to 5.51. thnx bb5box team Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-147 Version: V_05.51_05-09-07_RM-147_(c)_Nokia. IMEI: 352732017719461 SP LOCK status: Config Key: 3027200000000000 Block 1: CLOSED Type 5 Data: 302720 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-147_352732017719461_Locked_Keycnt_3_Fbuscnt_10__V_ 05.51_05-09-07_RM-147_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-147_352732017719461_Locked_Keycnt_0_Fbuscnt_0__V_0 5.51_05-09-07_RM-147_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 3027200000000000 Block 1: CLOSED Type 5 Data: 302720 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 1000 miliseconds Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 3027200000000000 Block 1: CLOSED Type 5 Data: 302720 Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again. |
03-24-2008, 21:38 | #3 (permalink) |
No Life Poster Join Date: Jan 2006 Location: THE GREAT :::LOVELY:::PAKISTAN
Member: 226363 Status: Offline Sonork: 03--4899925 Thanks Meter: 569 | Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries ur all counters is full u cannot rest counter in bb5box use other box for reset |
04-04-2008, 00:03 | #6 (permalink) |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | try change connection of clk and data...some cables come with reversed colors...that if u r not sure where is data and clk if u already used this cable and unlocked before other phone than change gnd place try to connect data and gnd...press unlock and when asked to connect test point connect clk |
04-09-2008, 14:35 | #7 (permalink) |
Insane Poster Join Date: Apr 2007 Location: Bulgaria Age: 46
Member: 481337 Status: Offline Thanks Meter: 6 | Just move the GND on the opposite side than shown on the TP picture. I failed to unlock 5300b 10 times with the GND shown on the picture, but after moving it to the opposite side it unlocked immediately. Good luck! |
04-09-2008, 18:00 | #8 (permalink) |
No Life Poster Join Date: Apr 2005 Location: lebanon Age: 49
Member: 141363 Status: Offline Sonork: 100.1594362 Thanks Meter: 148 | Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries u need to right bkup |
04-09-2008, 18:06 | #9 (permalink) |
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | right backup ok, but in vain i upgrade and unlock it on 1st try how to xplain this Mr raskal why i can see this version supported on ur page, but i need to upgrade |
04-09-2008, 18:48 | #10 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Nigeria, Oyo state Age: 48
Member: 180091 Status: Offline Thanks Meter: 62 | this is very simple my friend ,i have the same problem before but was solved.this is the solution, on the GUI option, change it from windows to orange and the phone will unlock on first atempt. Good Luck Adebam |
04-10-2008, 15:08 | #11 (permalink) | |
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | Quote:
it s not becoz ver not supported but becoz of sp area hav to be rebuilt. | |
nokia 6124c-1 rm-422 by vodafone cant be unlocked by mxkey (ANSWERED) | med26 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 07-17-2011 21:37 |
X650 Cant Be Unlock By Hwk Why? | denard | HWK | 3 | 10-10-2009 05:14 |
5300b t-mobile success unlock by bb5 box | GUDO-GSM | BB5BOX | 0 | 10-24-2007 11:06 |
6085 can't be unlock by BB5 box ! | hatali | BB5BOX | 4 | 10-12-2007 11:59 |
V220 cant be unlocked by v2.09? | a4tech | Smart-Clip | 9 | 04-12-2005 17:30 |
