04-10-2008, 09:09 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: india
Member: 135945 Status: Offline Thanks Meter: 85 | 6234 ver 4.52 spansion chip! all the time byte 55 error??? Hi! i hve some 6234 phnes with spansion chips which came with 5.43 and i downgraded them to 4.52! ive soldered GND and connected the crocodile connctr as well to GND2 and testpoints connected as well! but always the same error! Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-123 Version: V_04.52_06-07-06_RM-123_(c)_Nokia IMEI: 359395009090001 SP LOCK status: Config Key: 2720100000000000 Block 1: CLOSED Type 5 Data: 27201F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-123_359395009090001_Locked_Keycnt_0_Fbuscnt_0__V_0 4.52_06-07-06_RM-123_(c)_Nokia.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-123_359395009090001_Locked_Keycnt_0_Fbuscnt_0__V_0 4.52_06-07-06_RM-123_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2720100000000000 Block 1: CLOSED Type 5 Data: 27201F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 1000 miliseconds Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using cable codes fail. Reading again SP Locks ... ERROR: 11160001 ERROR: 30020111 can u please inform me which versin of the software is best to unlock these phones! as ive tried about 20pcs and all the same error! ive tried using the UNLOCK1 & UNLOCK2 as well but both give the same error! so pls help? WBR ReyTech. |
MT-box lite supports unlocking 6234 ver 4.52! succesfully???? | ReyTech | MT-BOX | 1 | 04-15-2008 14:37 |
@uid Users U Can Unlock Ur 6233 By Selcting 6234 Ver [4.91] | chiragp | UID - Box | 5 | 09-29-2007 17:03 |
rsa error 0002 all the time | luckycool | MT-BOX | 1 | 03-07-2007 15:37 |
Extract error all the time | Lovelysupercat | powerflasher | 1 | 06-20-2005 20:10 |
I can't repear M35, Barter flashed said to me ERROR! when finish all the time... HELP | alruus | x1x to x45/x50 | 6 | 12-07-2001 02:24 |
