Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5BOX
Old 04-09-2008, 21:59   #1 (permalink)
Gabiunlock's Avatar
Member: 710759
Sonork: No
Thanks Meter: 324
Shame on me - I not know how to find and use automaticaly made backup file
In the second attempt to unlock a nokia 5200 I get the counter 3 / 3 10/10
Old 04-10-2008, 00:00   #2 (permalink)
Member: 181453
Thanks Meter: 7
So..................is the problem in a update...or the problem is in you?
I unlocked several pieces without any problem.
If you know how to work with bb5 box,then you have to read 308 field before any attempt of the unlock becouse with that backup you can repair 3/3,10/10 counter problem.
Old 04-10-2008, 01:23   #3 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 184
that's it.............
Old 04-10-2008, 03:27   #4 (permalink)
Member: 588059
Thanks Meter: 47
BB5 Box software ALLWAYS make a backup with 0/0 counters BEFORE start unlocking, so just check your logs for the file name and use this. You will save a lot of troubles if you will READ AND UNDERSTAND the manual!
P.S. I also changed thread title to reflect the reality.
Old 04-10-2008, 04:19   #5 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 184
he must be sleeping, tomorow he will find another problem, not find his own thread cause he haven't make a thread backup
Old 04-10-2008, 13:05   #6 (permalink)
Gabiunlock's Avatar
Member: 710759
Sonork: No
Thanks Meter: 324
arrogant
There are all living here and I the only turkey..., stop backup dammit I did not believe how it works are all about arrogant and you change the title that I do not feel venguenza ... and provide a solution not a mockery .. ...
Old 04-10-2008, 13:26   #7 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 184
hi, take it easy man, what about your phone?
search for backup in your bb5box folder, then write it, your problem will be solved.
br
Old 04-10-2008, 13:29   #8 (permalink)
Gabiunlock's Avatar
Member: 710759
Sonork: No
Thanks Meter: 324
br
Thanks friend, forgive my ignorance, as well as apologize to the ignorant ...
Old 04-10-2008, 13:54   #9 (permalink)
Member: 81501
Thanks Meter: 41
read first carefully manual before unlocking.......................................ok ?
Old 04-10-2008, 14:30   #10 (permalink)
Gabiunlock's Avatar
Member: 710759
Sonork: No
Thanks Meter: 324
Connecting to BB5 Box ...
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-174
Version: V_05.51_05-09-07_RM-174_(c)_Nokia.
IMEI: 35*********xx04
SP LOCK status:
Config Key: 7223100000000000
Block 1: CLOSED Type 5 Data: 722310
Block 2: CLOSED Type 5 Data: 74810F
Block 3: CLOSED Type 5 Data: 74402F
Block 4: CLOSED Type 5 Data: 722310
Block 5: CLOSED Type 5 Data: 74810F
Block 6: CLOSED Type 5 Data: 74402F
Keyboard wrong codes counter: 0 wrong tries from max. 3 tries
Cable wrong codes counter: 0 wrong tries from max. 10 tries
Set Full Factory Defaults ...
Reset phone ...
Full Factory Defaults set OK
Skip autobackup of PM 308
Autobackup file:
RM-174_35*********904_Locked_Keycnt_0_Fbuscnt_0__V_05 .51_05-09-07_RM-174_(c)_Nokia..bin
already exist
Checking if model/version is supported for unlock ...
Please connect testpoints
Testpoints connected OK
Keep Testpoints connected until unlock finish!
Unlocking phone ...
Try unlocking using keyboard codes ...
Try number (Keyboard): 1
Sending SP code: #pw+012345678901234+7#
Response byte: 08
Try number (Keyboard): 2
Response byte: 08
Try number (Keyboard): 3
Response byte: 08
Unlock using keyboard codes fail.
Try unlocking using cable codes ...
Try number (Cable): 1
Response byte: 08
Try number (Cable): 2
Response byte: 08
Try number (Cable): 3
Response byte: 08
Try number (Cable): 4
Response byte: 08
Try number (Cable): 5
Response byte: 08
Try number (Cable): 6
Response byte: 08
Try number (Cable): 7
Response byte: 08
Try number (Cable): 8
Response byte: 08
Try number (Cable): 9
Response byte: 08
Try number (Cable): 10
Response byte: 08
Unlock using cable codes fail.
Reading again SP Locks ...
SP LOCK status:
Keyboard wrong codes counter: 3 wrong tries from max. 3 tries
Cable wrong codes counter: 10 wrong tries from max. 10 tries
Unlock fail. Please try again.......wat is problem????????
Old 04-10-2008, 14:51   #11 (permalink)
Member: 123924
Sonork: 100.1576204
Thanks Meter: 25
Bro
Please check your testpoint, cable, and ground connection, and try to change the ground position as well, also try without ground
Old 04-10-2008, 15:03   #12 (permalink)
boucettay's Avatar
Member: 148814
Sonork: 100.1576882
Thanks Meter: 5,012
search on youtube and u'll find whole unlock operation hosted video
just search : bb5box unlock or have a look on bb5box.org videos
These are instructions on how to install and use iBlueNova, FILE TRANSFER IN IPHONE malikzahidawan iPhone 2 / iPhone 3G / iPhone 3GS 0 02-16-2010 22:59
how to find and edit the backup of ifone from itunes Sonu Jawed iPhone 2 / iPhone 3G / iPhone 3GS 9 03-13-2009 11:55
I not know how to work with sagdd box . mileta5 SAGEM JTAG UNLOCKER 8 02-20-2009 11:49
help me!may i know how to use v3xx testpoint? wew Smart-Clip 1 10-07-2008 08:48
Any one know how to find the V60i Flex file??? wiky Motorola P2k 0 06-04-2004 13:49
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.27693 seconds with 8 queries
