04-09-2008, 21:59 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Misiones
Member: 710759 Status: Offline Sonork: No Thanks Meter: 329 | Shame on me - I not know how to find and use automaticaly made backup file |
04-10-2008, 00:00 | #2 (permalink) |
Junior Member Join Date: Sep 2005 Location: Croatia,Kaštela Age: 40
Member: 181453 Status: Offline Thanks Meter: 7 | So..................is the problem in a update...or the problem is in you? I unlocked several pieces without any problem. If you know how to work with bb5 box,then you have to read 308 field before any attempt of the unlock becouse with that backup you can repair 3/3,10/10 counter problem. |
04-10-2008, 03:27 | #4 (permalink) |
Product Manager Join Date: Sep 2007
Member: 588059 Status: Offline Thanks Meter: 47 | BB5 Box software ALLWAYS make a backup with 0/0 counters BEFORE start unlocking, so just check your logs for the file name and use this. You will save a lot of troubles if you will READ AND UNDERSTAND the manual! P.S. I also changed thread title to reflect the reality. |
04-10-2008, 13:05 | #6 (permalink) |
Member: 710759 Status: Offline Sonork: No Thanks Meter: 329 | arrogant There are all living here and I the only turkey..., stop backup dammit I did not believe how it works are all about arrogant and you change the title that I do not feel venguenza ... and provide a solution not a mockery .. ... Last edited by Gabiunlock; 04-10-2008 at 13:10. |
04-10-2008, 13:26 | #7 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | Quote:
search for backup in your bb5box folder, then write it, your problem will be solved. br | |
04-10-2008, 14:30 | #10 (permalink) |
Member: 710759 Status: Offline Sonork: No Thanks Meter: 329 | Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_05.51_05-09-07_RM-174_(c)_Nokia. IMEI: 35*********xx04 SP LOCK status: Config Key: 7223100000000000 Block 1: CLOSED Type 5 Data: 722310 Block 2: CLOSED Type 5 Data: 74810F Block 3: CLOSED Type 5 Data: 74402F Block 4: CLOSED Type 5 Data: 722310 Block 5: CLOSED Type 5 Data: 74810F Block 6: CLOSED Type 5 Data: 74402F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-174_35*********904_Locked_Keycnt_0_Fbuscnt_0__V_05 .51_05-09-07_RM-174_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock using cable codes fail. Reading again SP Locks ... SP LOCK status: Config Key: 7223100000000000 Block 1: CLOSED Type 5 Data: 722310 Block 2: CLOSED Type 5 Data: 74810F Block 3: CLOSED Type 5 Data: 74402F Block 4: CLOSED Type 5 Data: 722310 Block 5: CLOSED Type 5 Data: 74810F Block 6: CLOSED Type 5 Data: 74402F Keyboard wrong codes counter: 3 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Unlock fail. Please try again.......wat is problem???????? |
04-10-2008, 14:51 | #11 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Dubai Age: 42
Member: 123924 Status: Offline Sonork: 100.1576204 Thanks Meter: 25 | Bro Please check your testpoint, cable, and ground connection, and try to change the ground position as well, also try without ground BR |
04-10-2008, 15:03 | #12 (permalink) |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | search on youtube and u'll find whole unlock operation hosted video just search : bb5box unlock or have a look on bb5box.org videos |
These are instructions on how to install and use iBlueNova, FILE TRANSFER IN IPHONE | malikzahidawan | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 02-16-2010 22:59 |
how to find and edit the backup of ifone from itunes | Sonu Jawed | iPhone 2 / iPhone 3G / iPhone 3GS | 9 | 03-13-2009 11:55 |
I not know how to work with sagdd box . | mileta5 | SAGEM JTAG UNLOCKER | 8 | 02-20-2009 11:49 |
help me!may i know how to use v3xx testpoint? | wew | Smart-Clip | 1 | 10-07-2008 08:48 |
Any one know how to find the V60i Flex file??? | wiky | Motorola P2k | 0 | 06-04-2004 13:49 |
