Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5BOX
Old 02-27-2008, 22:14   #1 (permalink)
Crazy Poster
Member: 194676
Thanks Meter: 2
still --> 6300 unlock fail with spansion flash chip
i am using version 0.0.38 and still unlock faill
Connecting to BB5 Box ...
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-217
Version: V_04.20_05-12-06_RM-217_(c)_Nokia.
IMEI: 354827011559448
SP LOCK status:
Config Key: 7223400000000000
Block 1: CLOSED Type 5 Data: 72234F
Block 2: CLOSED Type 5 Data: 72234F
Keyboard wrong codes counter: 0 wrong tries from max. 3 tries
Cable wrong codes counter: 0 wrong tries from max. 10 tries
Checking if model/version is supported for unlock ...
This model/version IS SUPPORTED for unlock.
Type: RM-217
SP LOCK status:
Set Full Factory Defaults ...
Reset phone ...
Reset phone in TEST mode ...
Full Factory Defaults set OK
Create autobackup of PM 308
Reading PM Field 308 Subfield 1 with length 8192 bytes
Saving autobackup to file: RM-217_354827011559448_Locked_Keycnt_0_Fbuscnt_0__V_0 4.20_05-12-06_RM-217_(c)_Nokia..bin
Please connect testpoints
Testpoints connected OK
Keep Testpoints connected until unlock finish!
Unlocking phone ...
Try unlocking using keyboard codes ...
Try number (Keyboard): 1
Sending SP code: #pw+012345678901234+7#
Response byte: 08
Try number (Keyboard): 2
Response byte: 08
Try number (Keyboard): 3
Response byte: 08
Unlock using keyboard codes fail.
Try unlocking using cable codes ...
Try number (Cable): 1
Response byte: 55
Try number (Cable): 2
Response byte: 14
Try number (Cable): 3
Response byte: 14
Try number (Cable): 4
Response byte: 14
Try number (Cable): 5
Response byte: 08
Try number (Cable): 6
Response byte: 08
Try number (Cable): 7
Response byte: 08
Try number (Cable): 8
Response byte: 08
Try number (Cable): 9
Response byte: 08
Try number (Cable): 10
Response byte: 08
Unlock using cable codes fail.
Reading again SP Locks ...
SP LOCK status:
Keyboard wrong codes counter: 3 wrong tries from max. 3 tries
Cable wrong codes counter: 6 wrong tries from max. 10 tries
Unlock fail. Please try again.
and again
Type: RM-217
Writting PM Field 308 Subfield 1 with length 8192 bytes
Reset phone ...
PM Field 308 Subfield 1 written OK
Type: RM-217
SP LOCK status:
Reset phone ...
Skip autobackup of PM 308
Autobackup file:
already exist
Unlocking phone ...
Response byte: 55
Response byte: 55
Response byte: 55
Response byte: 55
Response byte: 55
Response byte: 55
Response byte: 55
Response byte: 55
Response byte: 55
Response byte: 55
Response byte: 55
Response byte: 55
Response byte: 55
ERROR: 11160001
ERROR: 30020091
and again
Type: RM-217
SP LOCK status:
Type: RM-217
SP LOCK status:
Reset phone ...
Autobackup file:
already exist
Unlocking phone ...
Response byte: 55
Response byte: 55
Response byte: 55
Response byte: 55
Response byte: 55
Response byte: 55
Response byte: 55
Response byte: 55
Response byte: 55
Response byte: 55
Response byte: 55
Response byte: 55
Response byte: 55
ERROR: 11160001
ERROR: 30020091
Which may be the problem??? any idea???
Best Regards.
Old 02-27-2008, 22:28   #2 (permalink)
Member: 137474
Sonork: 100.109924
Thanks Meter: 471
To low version of firmware some phone with spanision flash ic can't unlock with too low version you need flash to higher verson 5.0 or more and you can unlock your phone without problems. bye
Old 02-27-2008, 22:42   #3 (permalink)
LordMen007's Avatar
Member: 184793
Sonork: 100.1574609
Thanks Meter: 45
Type: RM-217
SP LOCK status:
ERROR: 11160001
ERROR: 30020091
Best Regards.
this mean that gnd wire touch worng place in the board & the fone poweroff
but for u r problem try to make upgrade to v5.00 then make unlock tested on over 100 pcs
good luck
LordMen007
6300 unlock fail with spansion flash chip fastgsm BB5BOX 12 02-27-2008 16:30
6300 Spansion flash chip...unable to unlock :( XtremeGG MT-BOX 16 12-24-2007 04:11
Problem unlock A31 with ST flash chip goro_bg DreamBox 10 09-25-2006 08:41
I have some idea how to unlock Siemens with new flash chip ! mr_x4you x1x to x45/x50 3 08-14-2002 14:39
Page generated in 0.15639 seconds with 9 queries
