10-18-2007, 09:57 | #46 (permalink) |
Junior Member Join Date: Dec 2006
Member: 420137 Status: Offline Thanks Meter: 1 | as soon as i attach testpiont with button on lost connection solution wires in testpiont/button cable were correct but when case put on wires were shorting desoldered wires trimmed(no need for 1/2 cm solder on each wire) resoldered |
10-18-2007, 21:05 | #47 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Portugal Age: 51
Member: 90668 Status: Offline Thanks Meter: 57 | I think the positive fuse is ****n!... I can mesure current up to the fuse start but no current passes to the tweeser. Are these fuses really necessary or can I simply make a "direct connection"? If I can't make this connection, where can I find similar fuses? BR P.S. Or should I simply ask my reseller for a new cable since I bought the box less than a week ago? |
10-22-2007, 14:32 | #50 (permalink) | |
Freak Poster Join Date: Aug 2005
Member: 170728 Status: Offline Thanks Meter: 3 | Quote:
10-24-2007, 01:33 | #53 (permalink) |
No Life Poster Join Date: Aug 2005
Member: 167420 Status: Offline Thanks Meter: 19 | Checking if model/version is supported for unlock ... Please connect testpoints ERROR: Connection with phone was lost! pleaseeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeee i am frustraed with the b5box |
10-24-2007, 02:59 | #54 (permalink) | |
Product Manager Join Date: Sep 2007
Member: 588059 Status: Offline Thanks Meter: 47 | Quote:
Next time use search or read more this forum. | |
10-28-2007, 17:52 | #57 (permalink) |
Freak Poster Join Date: Oct 2005
Member: 194849 Status: Offline Thanks Meter: 11 | test points I understand that when you connect test points correctly and press little button sw should start unlocking process. If that is true why after pressing button I have error 08, the one that point to TP problem. I tried, just to be sure, to press button without connecting TP, sound for connecting TP is still on. That means, if TP is not connected correctly nothing happens. Why then ERROR? anybody TNX |
10-29-2007, 15:46 | #58 (permalink) | |
Freak Poster Join Date: Mar 2004 Location: Czech republic Age: 54
Member: 56634 Status: Offline Thanks Meter: 71 | Quote:
http: not work help me | |
10-30-2007, 16:20 | #60 (permalink) | |
Guest
Posts: n/a
Member: | Quote:
This was tested with few phone models and working good. http://www.ipmart.com/main/browse.php?&&cat=2471 BR, Manole | |
Refill problems? Please post here the ASK REFILL [PLEASE POST ONLY HERE!] | FTEAM_MODERATOR | FuriousGold | 111 | 01-09-2010 11:26 |
Phones which have problems with JAF No Tp By Cinek, please post here | defa | JAF No Tp Unlocker by Cinek | 65 | 04-07-2009 00:38 |
Easy Tp for 6280,,,please check here!!! | Ron2pet | AdvanceUFS | 21 | 01-24-2008 01:42 |
Connection error problems - how to solve - PLEASE read here | zulea | Motorola P2K (USB-Smart) | 0 | 02-22-2006 15:29 |
For the ones with cable problems, please read !! | Raskal | Blazer | 13 | 10-18-2004 20:34 |
