when 7390 unlock bug will be corrected Since last two hours trying to unlock 7390 but always response byte :08. When this bug will be fixed coz none of our members say that this phone is unlocked successfully :confused: and forum is filled with unlock problem but no solution yet :rolleyes: Need urgent update !!! BR |
Hapened to me too. Always response 08 (when test connection with phone is disabled) or always error lost connection with phone (when test connection with phone is enabled). |
Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-140 Version: V_03.84_23-10-06_RM-140_(c)_Nokia IMEI: 353639014353187 SP LOCK status: Config Key: 2140700000000000 Block 1: CLOSED Type 5 Data: 21407F Block 2: CLOSED Type 5 Data: 21402F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-140_353639014353187_Locked_Keycnt_0_Fbuscnt_10__V_ 03.84_23-10-06_RM-140_(c)_Nokia.bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-140_353639014353187_Locked_Keycnt_0_Fbuscnt_0__V_0 3.84_23-10-06_RM-140_(c)_Nokia.bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2140700000000000 Block 1: CLOSED Type 5 Data: 21407F Block 2: CLOSED Type 5 Data: 21402F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. . Tried with other box and phone unlocked successfuly in first try. |
We will check where is problem, but at that time when we added this model all worked well. Maybe something wrong due to new updates of box firmware. |
I have too problem unlock next 7390 ,pls resolve this bug ,thx |
