Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5BOX
Old 11-21-2007, 10:38   #1 (permalink)
G*Mughal*G's Avatar
Member: 133099
Sonork: 100.1582860
Thanks Meter: 18
when 7390 unlock bug will be corrected
Since last two hours trying to unlock 7390 but always response byte :08.
When this bug will be fixed coz none of our members say that this phone is unlocked successfully and forum is filled with unlock problem but no solution yet
Need urgent update !!!
Old 11-21-2007, 13:37   #2 (permalink)
Deimantas's Avatar
Member: 132757
Hapened to me too. Always response 08 (when test connection with phone is disabled) or always error lost connection with phone (when test connection with phone is enabled).
Old 11-22-2007, 11:02   #3 (permalink)
mughalG's Avatar
Member: 315789
Thanks Meter: 3,428
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-140
Version: V_03.84_23-10-06_RM-140_(c)_Nokia
IMEI: 353639014353187
SP LOCK status:
Config Key: 2140700000000000
Block 1: CLOSED Type 5 Data: 21407F
Block 2: CLOSED Type 5 Data: 21402F
Keyboard wrong codes counter: 0 wrong tries from max. 3 tries
Cable wrong codes counter: 10 wrong tries from max. 10 tries
Skip autobackup of PM 308
Autobackup file:
RM-140_353639014353187_Locked_Keycnt_0_Fbuscnt_10__V_ 03.84_23-10-06_RM-140_(c)_Nokia.bin
already exist
Auto Write PM 308 procedure started
Searching for backup file with lowest FBUS count ...
Finded backup file: RM-140_353639014353187_Locked_Keycnt_0_Fbuscnt_0__V_0 3.84_23-10-06_RM-140_(c)_Nokia.bin
Writting PM Field 308 Subfield 1 with length 8192 bytes
Reset phone ...
PM Field 308 Subfield 1 written OK
Reading SP Locks after Auto Write PM 308 ...
SP LOCK status:
Cable wrong codes counter: 0 wrong tries from max. 10 tries
Reset phone in TEST mode ...
Checking if model/version is supported for unlock ...
Please connect testpoints
Testpoints connected OK
Keep Testpoints connected until unlock finish!
Unlocking phone ...
Try number: 1
Sending SP code: #pw+012345678901234+7#
Response byte: 08
Try number: 2
Response byte: 08
Try number: 3
Response byte: 08
Try number: 4
Response byte: 08
Try number: 5
Response byte: 08
Try number: 6
Response byte: 08
Try number: 7
Response byte: 08
Try number: 8
Response byte: 08
Try number: 9
Response byte: 08
Try number: 10
Response byte: 08
Unlock fail. Please try again.
Tried with other box and phone unlocked successfuly in first try.
Old 11-22-2007, 13:19   #4 (permalink)
Member: 588059
Thanks Meter: 47
We will check where is problem, but at that time when we added this model all worked well.
Maybe something wrong due to new updates of box firmware.
Old 11-23-2007, 13:45   #5 (permalink)
Member: 41167
Thanks Meter: 2
I have too problem unlock next 7390 ,pls resolve this bug ,thx
Old 11-23-2007, 13:56   #6 (permalink)
Cheater -Don't Deal with him-
.:GSM International:.'s Avatar
Member: 8879
Sonork: 100.84016
Thanks Meter: 327
Why dont u change your name to Zulea?
When new update of mx-key without bugs will be released? sahil2000ind MXKEY Nokia Flasher and Unlocker (by Alim Hape) 25 11-16-2009 12:39
When 5310 Xpress music will be supported for Unlock ? Hitec Wireless J.A.F. V-SPEC 7 08-24-2008 20:09
when bugs will be corected and new flash files uploaded? CLIFFORD25502 NSPRO 2 01-04-2007 16:54
When When When Boot Restore Option will be IMPLEMENTED for SENDO .... Aamir_Zia Multi-Box 9 12-04-2005 13:38
When DIV 8.1 will be Cracked? Xed Sony Ericsson 30 08-24-2003 11:45
Page generated in 0.25872 seconds with 9 queries
