02-23-2009, 17:27 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Madrid, ES. Age: 41
Member: 51153 Status: Offline Sonork: 100.113241 Thanks Meter: 3,682 | N95 8gb not unlock and phone startup failed now i make also backup i write back but still same problem, any hepl pls??? |
02-23-2009, 18:20 | #3 (permalink) |
Member: 51153 Status: Offline Sonork: 100.113241 Thanks Meter: 3,682 | still same problem after formart with HWk MCU SW : V 06wk41v51.3 13-02-08 RM-320 (c) Nokia APE Core: 20.0.016 APE Var : 20.0.01659.01 Prd.Code: 0558166 Bpr.Code: Prod.Sn : 0 HW Vers : APE HW : 1 APE Adsp: 256 EM VILMA: 16 EM BETTY: 22 RFIC Ver: 17141715 DSP Vers: mc_3131_ICPR62_2008w04 WLAN Id : 39324BFD22 IMEI : 356842-02-280460-8 SL Serv : SIMLOCK SERVER SL Conf : 000-00-00000000000 SL Stat : 0147196C00000000 SL Count: 00 00 Provider: Not Found |
02-23-2009, 18:50 | #5 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Yemen Age: 53
Member: 41256 Status: Offline Thanks Meter: 74 | Quote:
WBR | |
02-24-2009, 05:45 | #8 (permalink) |
Product Supporter Join Date: Oct 2002 Location: Philippines/Shenzhen, China Age: 58
Member: 16816 Status: Offline Sonork: 100.42691 Thanks Meter: 105 | try changing your bsi resistor value to make the phone in easy local mode then write pm, you can also try sysformat then flash again the phone. br nlogomaster ym id : nlogomaster sonork : 100.42691 ICQ : 222-111-888 Mobile : +8613424223932 email : nlogomaster[@]gmail.com, gsmtraders.jake[@]gmail.com MSN: nlogomaster[@]hotmail.com www.gsm-traders.com |
02-24-2009, 23:15 | #9 (permalink) |
No Life Poster Join Date: Sep 2007 Location: iPhone Age: 46
Member: 599385 Status: Offline Sonork: 100.1583205 Thanks Meter: 82 | N95 8GB and N96 All the time problem to unlock! Hi All, All the time when i get to unlock some N95 8Gb or N96 i cant unlock from first time,need to try sometimes about 1 phone 3 hours all the time i got Error:read pm data.I try on 2 PC and 3 different universal cables any why the same problem after 300 times i try than phone is unlocked. The JAF box read phone info ok to enter to local mode is no problem.But when i try to unlock this Error: read pm data. What can be the problem?Any body have any ideas?Cause Im geting sick of this 2 phone types.... Best Regards, |
02-25-2009, 00:49 | #10 (permalink) |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | personally i never faced problem with any phone...to get stable test mode, sometime have to plug usb cable to phone and Fbus cable of course... Perhaps u r getting a firmware like the one in movistar n78, that u need to flash phone.... Did u try to debrand and unlock..do u get the same problem??? Did u try make factory default before perform unlock process??... perhaps this can help u... PS: remember read backup before any unlock process in case things goes wrong, BR, |
02-25-2009, 09:27 | #11 (permalink) |
Member: 599385 Status: Offline Sonork: 100.1583205 Thanks Meter: 82 | I did not try debrand because I know that people dont have problem whit that software normaly that is Irish O2 Vodafone and Meteor.... I will try now to plug and usb cable to to the phone maybe that will help. Yes i do all the time factory default before to unlock.....And like phones E51 and other i try to unlock via FBUS and whit out any problem...I dont think my cables is not good.Just this 2 models all the time make trouble.But any way now will try whit usb and FBUS. Thanks,maybe some body have more solutions?:-) Best Regards, |
02-25-2009, 09:54 | #13 (permalink) |
Member: 51153 Status: Offline Sonork: 100.113241 Thanks Meter: 3,682 | Same problem after flash, pls give me solution the phone was fine i try to unlock via DK server now the phone start up failed ! i have good cable, go in local mode very well but how to fix this problem what can i do now ? JAF version 1.98.62 Detected PKEY: 9000C86A Card life counter: 99.99% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 20405, Library version: 30115 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-320\ Searching for default location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-320\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-320\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-320\RM-320_31.0.015_PR.C0R PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-320\RM-320_31.0.015_PR.C0R PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-320\RM-320_31.0.015_PR.v05 CNT Flash file: NONE APE Variant file: NONE Languages in ppm: English,German,Ukrainian,Russian,Bulgarian,Romania n Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-320\RM-320_31.0.015_PR.C0R PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-320\RM-320_31.0.015_PR.v05 CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-320\RM320_31.0.002_025_xxx_U01_uda.fpsx APE Variant file: NONE Languages in ppm: English,German,Ukrainian,Russian,Bulgarian,Romania n Backing up CRT data... Setting FLASH MODE FAST PHONE detected! Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 00350001 <=> SPANSION -> 72NS128N CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_algo.fg Loader version: 01.23.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready Reading CMT NPC certificate... Reading CMT VARIANT certificate... VARIANT CRT empty, skip save... Reading CMT CCC certificate... Reading CMT HWC certificate... Saved to C:\Program Files\ODEON\JAF\ProgData\35684202280460_CRT_backup _935252.rpl Backup CRT OK! Backing up SIMLOCK data... Setting local mode... Failed! Aborting! Failed to backup LCK... Manual mode selected, version can't be checked! Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 24200705 Asic Mode ID: 00 Asic Public ID: 78FC2531F86DA1FE393879B82AA65FCBDF100058 HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 ROM ID: 0000000000000000 CMT Boot Data: Asic ID: 000000010000022600010006400C192101031103 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 1CF0010821700052802213BA9F5EECB86737B721 HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE00000000 ROM ID: 4B9B75103E691FF8 CMT Boot File: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 00350001 <=> SPANSION -> 72NS128N CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_algo.fg Loader version: 01.23.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\omap2420_m1_2nd.fg Loader version: 01.27.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 004000EC <=> SAMSUNG (SEC) -> KAT00F00RA APE Flash Data: Not Available APE Loader: C:\Program Files\ODEON\JAF\Flash\teflon_sam_nand_xsr151_m1.fg Loader version: 01.34.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... APE Loader Ready... Operation took 0 minutes 7 seconds... Sending CNF Data... Sending CRT data... Erasing... Operation took 0 minutes 37 seconds... Writing... Stage 1 Sending APE HASH for X-LOADER Sending CMT HASH for NOLO Sending APE HASH for KEYS Sending CMT HASH for KEYS Sending APE HASH for PRIMAPP Sending CMT HASH for PRIMAPP Sending CMT HASH for PASUBTOC Sending APE HASH for X-LOADER Sending CMT PUB KEYS... Sending CMT HASH for UPDAPP Sending APE HASH for KEYS Sending APE HASH for PRIMAPP Sending CMT HASH for DSP0 Sending APE HASH for SOS+XZIP Sending APE HASH for PASUBTOC Sending APE PUB KEYS... Sending APE HASH for SOS+UPDAPP Sending CMT HASH for MCUSW Sending APE HASH for SOS+CORE Stage 2 Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 24200705 Asic Mode ID: 00 Asic Public ID: 78FC2531F86DA1FE393879B82AA65FCBDF100058 HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 ROM ID: 0000000000000000 CMT Boot Data: Asic ID: 000000010000022600010006400C192101031103 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 1CF0010821700052802213BA9F5EECB86737B721 HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE00000000 ROM ID: 4B9B75103E691FF8 CMT Boot File: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 00350001 <=> SPANSION -> 72NS128N CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_algo.fg Loader version: 01.23.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\omap2420_m1_2nd.fg Loader version: 01.27.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 004000EC <=> SAMSUNG (SEC) -> KAT00F00RA APE Flash Data: Not Available APE Loader: C:\Program Files\ODEON\JAF\Flash\teflon_sam_nand_xsr151_m1.fg Loader version: 01.34.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... APE Loader Ready... Operation took 0 minutes 6 seconds... Sending CNF Data... Sending CRT data... Stage 1 Stage 2 Sending APE HASH for SOS+ROFS Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 24200705 Asic Mode ID: 00 Asic Public ID: 78FC2531F86DA1FE393879B82AA65FCBDF100058 HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 ROM ID: 0000000000000000 CMT Boot Data: Asic ID: 000000010000022600010006400C192101031103 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 1CF0010821700052802213BA9F5EECB86737B721 HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE00000000 ROM ID: 4B9B75103E691FF8 CMT Boot File: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 00350001 <=> SPANSION -> 72NS128N CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_algo.fg Loader version: 01.23.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\omap2420_m1_2nd.fg Loader version: 01.27.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 004000EC <=> SAMSUNG (SEC) -> KAT00F00RA APE Flash Data: Not Available APE Loader: C:\Program Files\ODEON\JAF\Flash\teflon_sam_nand_xsr151_m1.fg Loader version: 01.34.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... APE Loader Ready... Operation took 0 minutes 7 seconds... Sending CNF Data... Sending CRT data... Stage 1 Stage 2 FAST MODE finish! Operation took 4 minutes 48 seconds... Reseting phone... PPM: C:\Program Files\Nokia\Phoenix\Products\RM-320\RM-320_31.0.015_PR.v05 Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 24200705 Asic Mode ID: 00 Asic Public ID: 78FC2531F86DA1FE393879B82AA65FCBDF100058 HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 ROM ID: 0000000000000000 CMT Boot Data: Asic ID: 000000010000022600010006400C192101031103 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 1CF0010821700052802213BA9F5EECB86737B721 HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE00000000 ROM ID: 4B9B75103E691FF8 CMT Boot File: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 00350001 <=> SPANSION -> 72NS128N CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_algo.fg Loader version: 01.23.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\omap2420_m1_2nd.fg Loader version: 01.27.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 004000EC <=> SAMSUNG (SEC) -> KAT00F00RA APE Flash Data: Not Available APE Loader: C:\Program Files\ODEON\JAF\Flash\teflon_sam_nand_xsr151_m1.fg Loader version: 01.34.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... APE Loader Ready... Operation took 0 minutes 7 seconds... Sending CNF Data... Erasing... Operation took 0 minutes 0 seconds... Writing... Sending APE HASH for SOS+ROFX Operation took 1 minutes 10 seconds... Reseting phone... CNT: C:\Program Files\Nokia\Phoenix\Products\RM-320\RM320_31.0.002_025_xxx_U01_uda.fpsx Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 24200705 Asic Mode ID: 00 Asic Public ID: 78FC2531F86DA1FE393879B82AA65FCBDF100058 HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 ROM ID: 0000000000000000 CMT Boot Data: Asic ID: 000000010000022600010006400C192101031103 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 1CF0010821700052802213BA9F5EECB86737B721 HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE00000000 ROM ID: 4B9B75103E691FF8 CMT Boot File: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 00350001 <=> SPANSION -> 72NS128N CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_algo.fg Loader version: 01.23.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\omap2420_m1_2nd.fg Loader version: 01.27.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 004000EC <=> SAMSUNG (SEC) -> KAT00F00RA APE Flash Data: Not Available APE Loader: C:\Program Files\ODEON\JAF\Flash\teflon_sam_nand_xsr151_m1.fg Loader version: 01.34.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... APE Loader Ready... Operation took 0 minutes 7 seconds... Erasing... Operation took 0 minutes 2 seconds... Writing... Booting phone... FAST PHONE detected! APE Boot Data: Asic ID: 24200705 Asic Mode ID: 00 Asic Public ID: 78FC2531F86DA1FE393879B82AA65FCBDF100058 HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 ROM ID: 0000000000000000 CMT Boot Data: Asic ID: 000000010000022600010006400C192101031103 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 1CF0010821700052802213BA9F5EECB86737B721 HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE00000000 ROM ID: 4B9B75103E691FF8 CMT Boot File: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 00350001 <=> SPANSION -> 72NS128N CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_algo.fg Loader version: 01.23.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\omap2420_m1_2nd.fg Loader version: 01.27.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 004000EC <=> SAMSUNG (SEC) -> KAT00F00RA APE Flash Data: Not Available APE Loader: C:\Program Files\ODEON\JAF\Flash\teflon_sam_nand_xsr151_m1.fg Loader version: 01.34.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... APE Loader Ready... Operation took 0 minutes 7 seconds... FAST MODE finished! Operation took 2 minutes 40 seconds... Reseting phone... Done! Total time: 9 Minutes, 44 Seconds DCT4/BB5 counter: 65083 After flash processing... Waiting for phone to boot... Failed! Aborting! Last edited by F@RUK S; 02-25-2009 at 09:59. |
02-25-2009, 10:10 | #14 (permalink) |
No Life Poster Join Date: May 2007 Location: barsoume
Member: 515559 Status: Offline Sonork: no Thanks Meter: 121 | use this methode , Part two- phone preparation 1. You must have Nokia data suit because Dejan soft using driver from data suit and to install TRK file 2. After this you need to install s60_3_1_app_trk_2_8_6.sisx or s60_3_1_app_trk_2_8_9.sisx . Which file need to install depending of phone software. First is for older second is for newer phones .You don't need to know joust try to install and one of this must pass instillation. 3. If you have installed data suit and phone connected with usb cable to PC, just click twice on s60_3_1_app_trk_2_8_6.sisx or s60_3_1_app_trk_2_8_9.sisx and installation will start automatically. Confirm all message on phone. 4. Find in your phne where is application installed and start the TRK application. Example in N81 8gb path is MENU/APPLICATION/TRK in some phone MENU/APPLICATION/MY OWN/TRK 5. When you start you will get message "activate blutooth in offline mode" press key NO. 6. Press OPTION button and select SETTINGS and in CONNECTION field change to USB and press button BACK. 7. Close TRK and start again 8. You must have screen like this. I copy this from Nokia N81 8GB: Welcome to TRK for Symbian OS Status: Connected PDD: NONE LDD:EUSBC CSY:ECACM Port number :1 Baud rate: 115200 Part three- unlocking phone. 1. Connect phone to PC with usb cable and start TRK application. 2. Start BB5_TRK_unlocker.exe 3. Clik on button "Read Phone" and you will get phone info on screen. 4. For safety reason click on button " Make Backup". If something goes wrong to have backup for phone. 5. Click on button " SP Unlock" . Wait until on screen not have message " If everything is OK,...." 6. On phone press key for OPTION select with cursor Hello World and confirm . 7. In few seconds you will have UNLOCKED PHONE !!!!!! |
02-25-2009, 12:29 | #15 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 627228 Status: Offline Sonork: 100.1577983 Thanks Meter: 155 | Try to use extra power becouse can be low Power Use some USB carger.... and conect to mini USB And if persist the Problem i think you need to erase the Phone http://forum.gsmhosting.com/vbb/show...87&postcount=1 BR, |
N95 8GB not unlocked - tried 3 times and 30 logs gone! | serjer | Cyclonebox | 9 | 01-13-2010 17:55 |
E61i and Phone Startup Failed | Fock3 | Nokia Base Band 5 ( BB-5 ) | 2 | 05-20-2009 20:00 |
N95 8gb not unlock lost mi sim card not valid | ruchito | Universalbox | 1 | 03-30-2009 19:55 |
6630 Sim not valid and Phone startup failed | ata_evanescence | Universalbox | 16 | 11-14-2007 20:37 |
