Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5 Box by D.K.
Old 12-26-2008, 14:19   #31 (permalink)
naturalsurfer's Avatar
Member: 113587
Thanks Meter: 16
Originally Posted by Raskal View Post
no, since the dk card will recognize the imei and will not charge you one credit again.
B.R.,
Raskal
That is not true because i have lost 3 credits trying to unlock it.....
Old 12-26-2008, 15:41   #32 (permalink)
Member: 162387
Sonork: 100.86669
Thanks Meter: 457
IMPOSSIBLE !!!
Give me your account user name and i am looking on the server for any possible error and will tell you after i check what is the matter.
Best Wishes,
Susan
www.gsm-traders.com
Old 12-26-2008, 15:48   #33 (permalink)
Member: 162387
Sonork: 100.86669
Thanks Meter: 457
Originally Posted by serjer View Post
Hello Problem was Movistar firmware on N78. I don't accept code, even it's originial and good.
I change productcode and update to generic firmware with Nokia Updater.
After that the code that I recieved earlier was NOW ACCEPTED and phone unlocked.
Very strange but true.
Only I loose 2 credits with dejan unlocker (and 17 euro for unlock via imei) so about 50 euro..
Hello,
what is your user name in server, so i can check the data. You saying the password calculated by dejan card was not correct even u was update the phone to generic firmaware.
Question: Have you try the after flashing the phone to use the calculated password to enter via JAF?
Question: Why have u lost 2 credits, u said you have 1 phone.
Post here the last 4 digits from phone's imei nr. Also post here the user name for your account.
Best Wishes,
Susan
www.gsm-traders.com
Old 12-26-2008, 18:14   #34 (permalink)
Member: 113587
Thanks Meter: 16
Originally Posted by gsm-traders.com View Post
IMPOSSIBLE !!!
Best Wishes,
Susan
www.gsm-traders.com
I am using dejan unlocker card with 55 logs pre-charged, but the fact is that I lost them,I saw counter decreassing three times and phone locked
Old 12-26-2008, 19:28   #35 (permalink)
Member: 563
Thanks Meter: 22,328
Ah i see, you are not using server. You using card direct.
Well i have backup in server for all unlock data, but also if you are using DK card than u have the calculated password inside the key folder, except you delete it. If you connect SAME PHONE WITH SAME IMEI, than you can do it this operation 1000 times and nothing will happens since it is recognized as UNLOCKED from Dejan's soft. But if you delete this data, sure you loose one more credit for same phone.
Since after reflasing the phone with generic software, you could simple insert code via jaf or if you press unlock button again on dejan soft it will take the saved data (password) and write it into phone, also.
So i can affirm, if is used how it should be, you can't loose any credit.
B.R.,
Raskal
Old 03-20-2009, 13:38   #36 (permalink)
turbosim_gr's Avatar
Member: 837424
Sonork: 100.1578933
Thanks Meter: 38
how to enter it via jaf the calculated code? just to know..
Old 06-27-2014, 15:49   #37 (permalink)
Member: 2199669
help
how you buy credit for bb5 software? and evrytime i open it it says range check error !please help.
Old 02-18-2017, 21:55   #38 (permalink)
mouhane's Avatar
Member: 2178934
Thanks Meter: 1,289
Originally Posted by ikrash View Post
bro before unlock n78 u should debrand it and then unlock w/o problem...i tested 4 pcs ..sucessfully done.....ikrash
its working bro ............
The Following User Says Thank You to mouhane For This Useful Post:
unable to unlock this phone.Password is not correct usaflex BB5 Box by D.K. 13 03-17-2009 23:40
Unable to unlock this phone... gsmcenter_pl BB5 Box by D.K. 4 01-11-2009 16:51
Error: Unable to unlock this phone. Password is not correct ! Nokiasimer Nokia Base Band 5 ( BB-5 ) 9 08-06-2008 23:51
Unable To Unlock This 02 Xda2 !!! albarka network HTC & PDA WM( With Touchscreen) 1 10-13-2007 15:46
Page generated in 0.17015 seconds with 9 queries
