11-18-2008, 07:39 | #1 (permalink) |
Freak Poster Join Date: Feb 2001
Member: 3354 Status: Offline Thanks Meter: 3,948 | Fixed BUG, new version 1.01 Only EXE file!!! Encryption works on N96 but since it was not locked phone it is not tested fully! Also, there is some phones that can NOT be unlocked by password!!! Click on "read phone". Look for first digit after "SP_F". In most cases it is 0 or 8 but if have values 3,7,B,F then that phone have disabled unlocking by password!(by keyboard and F-BUS) |
The Following 45 Users Say Thank You to Dejan Kaljevic For This Useful Post: |
11-18-2008, 07:43 | #2 (permalink) |
No Life Poster Join Date: Aug 2003 Age: 43
Member: 37237 Status: Offline Sonork: 100.1586809 Thanks Meter: 39 | So if its have disabled unlocking by key or Fbus.... that means it need test point solution only and thanks in advanced for the update.. |
The Following User Says Thank You to abuiesa For This Useful Post: |
11-18-2008, 07:47 | #3 (permalink) |
No Life Poster Join Date: Apr 2005 Location: X-Sim Philippines
Member: 141973 Status: Offline Sonork: 100.1579084 Thanks Meter: 4,002 | I hope i can test it....i have *******r have locked N96 phone.,i try to contact him..!!thanks Dejan for this update...!! br |
The Following User Says Thank You to Nonoyxp For This Useful Post: |
11-18-2008, 10:04 | #6 (permalink) |
Freak Poster Join Date: Feb 2004 Location: Vilnius,Lithuania Age: 41
Member: 53156 Status: Offline Thanks Meter: 15 | now all works fine!n95 8gb done.(was error:cant get pm size in previos version ) |
The Following User Says Thank You to romka21 For This Useful Post: |
11-18-2008, 14:29 | #7 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Melbourne , AUS Age: 47
Member: 40451 Status: Offline Sonork: 100.1580450 Thanks Meter: 73 | Its mean that all Hw version for N95 8gb are supported ?? |
The Following User Says Thank You to J-lock For This Useful Post: |
11-18-2008, 16:34 | #8 (permalink) | |
Banned Join Date: Jul 2005 Location: P.R.China Age: 40
Member: 162387 Status: Offline Sonork: 100.86669 Thanks Meter: 457 | Quote:
Best Wishes, Susan Last edited by acyl2000; 02-21-2009 at 09:09. Reason: advertising link removed | |
The Following User Says Thank You to gsm-traders For This Useful Post: |
11-19-2008, 12:10 | #9 (permalink) |
No Life Poster Join Date: Dec 2000 Location: las palmas ,spain
Member: 2800 Status: Offline Thanks Meter: 47 | Dejan please can you work in update that do not need JAF,maybe HWK or direct as TRK unlocker? |
The Following User Says Thank You to sonkar For This Useful Post: |
11-19-2008, 23:36 | #10 (permalink) |
Freak Poster Join Date: Dec 2004 Location: BiH Age: 43
Member: 100770 Status: Offline Thanks Meter: 57 | hello, N96, using JAF NK JIG, between bsi and ground are 68-70 k, on bsi tryed everythhing between 7.5 till 10 k, took the display off sometimes to...but no succes...... when phone is conected on JIG while pressing pwr on after 3-4 seconds phone goes to local mode and is stable there...can read the phone then,made back up and pressed sp unlock...soft made first step-calculated and saved the key and says done! After that it tryes to ge phone in local mode again to write the key (I guess), but that ant be done that fast and it shows the message "bad conection,blabla"....spent allmoust 4 hours today with that phone and I allways get the local mode at the beginning but when I try press sp unlock to write the stored key it doesnt switch so fast as it should...any experience or advice apriciated PS tomorrow I am going to put a potention meter on BSI so I can change the resistence by 1 ohm step by step...so if anybody has unlocked this phone...please share BR Mario |
The Following User Says Thank You to kaiserstumm For This Useful Post: |
11-20-2008, 03:16 | #11 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: Aus. melbourne Age: 45
Member: 20639 Status: Offline Thanks Meter: 233 | Quote:
very nice works i unlocked a few N95-8BG and N96 all works smoothly. thanks for the great software. | |
The Following 2 Users Say Thank You to MPhoneClinic For This Useful Post: |
11-20-2008, 03:35 | #12 (permalink) |
No Life Poster Join Date: Feb 2004 Location: ALGERIA
Member: 54116 Status: Offline Thanks Meter: 218 | i finished my small box dk2 in just 48h , and all unlocking was N95 8g , 55 pcs . hope new models will be add in short time , but now i must buy more than 100 unlock at one's . thanks for ur great product . wbr |
The Following User Says Thank You to SALIMUS For This Useful Post: |
11-20-2008, 15:34 | #13 (permalink) | |
Member: 100770 Status: Offline Thanks Meter: 57 | Quote:
1)found the allready created unlock key stored in C:\bb5_unlocker\key as imei.psw 2) copied the psw file on desktop (not remove, because you will need it if this doesnt works or your keypad counter is blocked) 3) rename the imei.psw file into imei.txt file and open it 4) now just enter the code like a regular provider code by keypad a and go to pub to get drunk by the money you earned BR Mario | |
cruise new version 10.01 released | david laborator | Cruiser Suite | 2 | 11-02-2006 10:36 |
New Version 1.20 bugs for 6630 | arunamobile | MT-BOX | 7 | 05-01-2006 14:54 |
When will be update witch fix bug in 7.1 can someone tell ?? | wgmmmx | Cruiser Suite | 11 | 12-16-2005 09:56 |
Congratulation Se-Fighter new version 3.01 was released!!!! | hakima | Cruiser Suite | 59 | 07-04-2004 03:02 |
