11-17-2007, 03:05 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Into the Unknown
Member: 121461 Status: Offline Thanks Meter: 49 | 5300b RM-147 and 5300b RM-146 at this link : http://forum.gsmhosting.com/vbb/showthread.php?t=464519 you quoated this line: 5300b RM-146 - 5.02 (ad0) i have a 5300b but its "RM-147" Now what i am concerned about is i have a RM-147 ver.5.02 can i flash the RM-147 with a RM-146 same version flash file to be able to unlock my phone? best regards |
11-17-2007, 03:59 | #2 (permalink) |
Freak Poster Join Date: Apr 2006 Location: the Bahamas Age: 33
Member: 264055 Status: Offline Thanks Meter: 6 | I too have a rm-147 5300b that i need to unlock! I thought it was supported until I got the message Version not supported Please advise if I can flash it with rm146 or wait until supported! B.R |
11-17-2007, 05:27 | #3 (permalink) |
Member: 264055 Status: Offline Thanks Meter: 6 | Hi I've searched everywhere I cant find a RM 146 5300b flash file(or a the phone for that matter). I dont suppose that the model "RM-146 5300b MCU 5.02) was put there by mistake. Could it be that RM-147 MCU 5.02 was acutually meant instead of "RM-146 5300b MCU 5.02" b.R |
11-17-2007, 09:20 | #4 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Facebook: Java John Age: 43
Member: 122246 Status: Offline Sonork: 100.50000 Thanks Meter: 4,993 | u can flash urs phone to 5300 rm146 ver v 4.70 and unlock or u can unlock it by flashing 5300b rm 147 v 5.02 5300b is rm 147 its mistake in typing i will edite that |
11-17-2007, 09:25 | #5 (permalink) |
Member: 121461 Status: Offline Thanks Meter: 49 | Thank you Mr. JavaJohn, however i am getting version not supported, here is log 16:11:2007 21:06 -> Changing mode...16:11:2007 21:06 -> Done! 16:11:2007 21:07 -> FILES SET FOR FLASHING: 16:11:2007 21:07 -> MCU Flash file: NONE 16:11:2007 21:07 -> PPM Flash file: NONE 16:11:2007 21:07 -> CNT Flash file: NONE 16:11:2007 21:07 -> APE Variant file: NONE 16:11:2007 21:07 -> Switching to serial... 16:11:2007 21:07 -> Powering the phone... 16:11:2007 21:08 -> Reading... 16:11:2007 21:08 -> MCU SW version: V 05.02 05-06-07 RM-147 (c) Nokia. 16:11:2007 21:08 -> HW version: 3003 16:11:2007 21:08 -> PCI version: 16:11:2007 21:08 -> RFIC version: 17211721 16:11:2007 21:08 -> DSP version: pb06w14v51 16:11:2007 21:08 -> PPM version: V 05.02 05-06-07 RM-146 (c) Nokia. NTM 16:11:2007 21:08 -> BT MCM version: 06cc-P9.1 16:11:2007 21:08 -> Retu version: 32 16:11:2007 21:08 -> Tahvo version: 53 16:11:2007 21:08 -> Content Pack version: Content: TMO v2 06-06-07 RM-147 (c) Nokia. 16:11:2007 21:08 -> Production serial number: RGI116718 16:11:2007 21:08 -> Product code: 0515264 16:11:2007 21:08 -> Module code: 0203052 16:11:2007 21:08 -> Basic production code: 0530539 16:11:2007 21:08 -> Flash code: 16:11:2007 21:08 -> Order number: 16:11:2007 21:08 -> Product specific data: 16:11:2007 21:08 -> Long production SN: 16:11:2007 21:08 -> ATO: 16:11:2007 21:08 -> Default SN type: 16:11:2007 21:08 -> IMEI plain: 354567013044888 16:11:2007 21:08 -> IMEI spare to net: 3A 45 65 07 31 40 84 08 16:11:2007 21:08 -> IMEI SV to net: 33 45 65 07 31 40 84 18 F0 16:11:2007 21:08 -> LOCK STATUS: CONFIG KEY: 3102000000000000 16:11:2007 21:08 -> Provider: T-Mobile;U.S.A. 16:11:2007 21:08 -> Key Code count: 1, FBUS Code count: 0 16:11:2007 21:08 -> Block 1: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310160 16:11:2007 21:08 -> Block 2: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310200 16:11:2007 21:08 -> Block 3: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310210 16:11:2007 21:08 -> Block 4: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310220 16:11:2007 21:08 -> Block 5: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310230 16:11:2007 21:08 -> Block 6: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310240 16:11:2007 21:08 -> Block 7: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310250 16:11:2007 21:08 -> Block 8: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310260 16:11:2007 21:08 -> Block 9: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310270 16:11:2007 21:08 -> Block 10: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310300 16:11:2007 21:08 -> Block 11: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310310 16:11:2007 21:08 -> Block 12: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310490 16:11:2007 21:08 -> Block 13: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310530 16:11:2007 21:08 -> Block 14: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310580 16:11:2007 21:08 -> Block 15: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310590 16:11:2007 21:08 -> Block 16: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310640 16:11:2007 21:08 -> Block 17: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310660 16:11:2007 21:08 -> Block 18: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310800 16:11:2007 21:08 -> 16:11:2007 21:08 -> Searching for saved ini... 16:11:2007 21:08 -> Checking for file C:\Program Files\ODEON\JAF\JAF_RM-147.ini 16:11:2007 21:08 -> Saved INI not found, loading INI list... 16:11:2007 21:08 -> Setting local mode... 16:11:2007 21:08 -> Reading product code... 16:11:2007 21:08 -> Product Code: 0515264 16:11:2007 21:08 -> 16:11:2007 21:08 -> No ini files found... 16:11:2007 21:08 -> FILES SET FOR FLASHING: 16:11:2007 21:08 -> MCU Flash file: NONE 16:11:2007 21:08 -> PPM Flash file: NONE 16:11:2007 21:08 -> CNT Flash file: NONE 16:11:2007 21:08 -> APE Variant file: NONE 16:11:2007 21:08 -> Done! 16:11:2007 21:08 -> Backup simlock data first... 16:11:2007 21:08 -> Setting local mode... 16:11:2007 21:08 -> Reading IMEI... 16:11:2007 21:08 -> C:\Program Files\ODEON\JAF\ProgData\RM-147_354567013044888_05.02_LCK_backup.pm 16:11:2007 21:08 -> Done! 16:11:2007 21:08 -> Detecting phone... 16:11:2007 21:08 -> Reading simlock... 16:11:2007 21:08 -> LOCK STATUS: CONFIG KEY: 3102000000000000 16:11:2007 21:08 -> Provider: T-Mobile;U.S.A. 16:11:2007 21:08 -> Key Code count: 1, FBUS Code count: 0 16:11:2007 21:08 -> Block 1: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310160 16:11:2007 21:08 -> Block 2: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310200 16:11:2007 21:08 -> Block 3: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310210 16:11:2007 21:08 -> Block 4: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310220 16:11:2007 21:08 -> Block 5: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310230 16:11:2007 21:08 -> Block 6: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310240 16:11:2007 21:08 -> Block 7: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310250 16:11:2007 21:08 -> Block 8: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310260 16:11:2007 21:08 -> Block 9: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310270 16:11:2007 21:08 -> Block 10: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310300 16:11:2007 21:08 -> Block 11: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310310 16:11:2007 21:08 -> Block 12: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310490 16:11:2007 21:08 -> Block 13: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310530 16:11:2007 21:08 -> Block 14: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310580 16:11:2007 21:08 -> Block 15: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310590 16:11:2007 21:08 -> Block 16: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310640 16:11:2007 21:08 -> Block 17: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310660 16:11:2007 21:08 -> Block 18: 16:11:2007 21:08 -> Lock 1: CLOSED -> Lock Data: 310800 16:11:2007 21:08 -> 16:11:2007 21:08 -> Reading phone...16:11:2007 21:08 -> Type: RM-147, Ver: 05.02 16:11:2007 21:08 -> Reading imei... 16:11:2007 21:08 -> Imei: 354567013044888 16:11:2007 21:08 -> Version Not supported! |
11-17-2007, 11:01 | #7 (permalink) |
Member: 264055 Status: Offline Thanks Meter: 6 | THATS WHAT MY LOG IS SAYING TOO! Version Not Supported! On RM-147 5.02. With ini file downloaded from your latest post of supported models! HELP PLEASE! |
11-17-2007, 12:57 | #8 (permalink) |
Member: 122246 Status: Offline Sonork: 100.50000 Thanks Meter: 4,993 | ok new update ready just use this new ini file just added 5200b now download this new ini and try unlock http:///vbb/showpo...77&postcount=6 |
11-17-2007, 20:23 | #9 (permalink) |
Member: 264055 Status: Offline Thanks Meter: 6 | Nope I still get: Reading phone...Type: RM-147, Ver: 05.02 Reading imei... Imei: 35XXXXXXXXXXXXX Version Not supported! I used the ini you just posted and still get that message! Please help. |
11-17-2007, 20:36 | #10 (permalink) | |
Member: 122246 Status: Offline Sonork: 100.50000 Thanks Meter: 4,993 | Quote:
because as u say from urs logs i dint see that u have connected v-spec | |
11-17-2007, 20:47 | #11 (permalink) | |
Member: 264055 Status: Offline Thanks Meter: 6 | Quote:
Reading phone...Type: RM-147, Ver: 05.02 Reading imei... Imei: 356433011431494 Version Not supported! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 3102000000000000 Provider: T-Mobile;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 310160 Block 2: Lock 1: CLOSED -> Lock Data: 310200 Block 3: Lock 1: CLOSED -> Lock Data: 310210 Block 4: Lock 1: CLOSED -> Lock Data: 310220 Block 5: Lock 1: CLOSED -> Lock Data: 310230 Block 6: Lock 1: CLOSED -> Lock Data: 310240 Block 7: Lock 1: CLOSED -> Lock Data: 310250 Block 8: Lock 1: CLOSED -> Lock Data: 310260 Block 9: Lock 1: CLOSED -> Lock Data: 310270 Block 10: Lock 1: CLOSED -> Lock Data: 310300 Block 11: Lock 1: CLOSED -> Lock Data: 310310 Block 12: Lock 1: CLOSED -> Lock Data: 310490 Block 13: Lock 1: CLOSED -> Lock Data: 310530 Block 14: Lock 1: CLOSED -> Lock Data: 310580 Block 15: Lock 1: CLOSED -> Lock Data: 310590 Block 16: Lock 1: CLOSED -> Lock Data: 310640 Block 17: Lock 1: CLOSED -> Lock Data: 310660 Block 18: Lock 1: CLOSED -> Lock Data: 310800 Reading phone...Type: RM-147, Ver: 05.02 Reading imei... Imei: 356433011431494 Version Not supported! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.02 05-06-07 RM-147 (c) Nokia. HW version: 3004 PCI version: RFIC version: 17211721 DSP version: pb06w14v51 PPM version: V 05.02 05-06-07 RM-146 (c) Nokia. NTM BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: TMO v2 06-06-07 RM-147 (c) Nokia. Production serial number: RNB857752 Product code: 0515264 Module code: 0203052 Basic production code: 0530539 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 35XXXXXXXXXXX IMEI spare to net: 3A 65 34 03 11 34 41 09 IMEI SV to net: 33 65 34 03 11 34 41 19 F0 LOCK STATUS: CONFIG KEY: 3102000000000000 Provider: T-Mobile;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 310160 Block 2: Lock 1: CLOSED -> Lock Data: 310200 Block 3: Lock 1: CLOSED -> Lock Data: 310210 Block 4: Lock 1: CLOSED -> Lock Data: 310220 Block 5: Lock 1: CLOSED -> Lock Data: 310230 Block 6: Lock 1: CLOSED -> Lock Data: 310240 Block 7: Lock 1: CLOSED -> Lock Data: 310250 Block 8: Lock 1: CLOSED -> Lock Data: 310260 Block 9: Lock 1: CLOSED -> Lock Data: 310270 Block 10: Lock 1: CLOSED -> Lock Data: 310300 Block 11: Lock 1: CLOSED -> Lock Data: 310310 Block 12: Lock 1: CLOSED -> Lock Data: 310490 Block 13: Lock 1: CLOSED -> Lock Data: 310530 Block 14: Lock 1: CLOSED -> Lock Data: 310580 Block 15: Lock 1: CLOSED -> Lock Data: 310590 Block 16: Lock 1: CLOSED -> Lock Data: 310640 Block 17: Lock 1: CLOSED -> Lock Data: 310660 Block 18: Lock 1: CLOSED -> Lock Data: 310800 Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-147.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0515264 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 3102000000000000 Provider: T-Mobile;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 310160 Block 2: Lock 1: CLOSED -> Lock Data: 310200 Block 3: Lock 1: CLOSED -> Lock Data: 310210 Block 4: Lock 1: CLOSED -> Lock Data: 310220 Block 5: Lock 1: CLOSED -> Lock Data: 310230 Block 6: Lock 1: CLOSED -> Lock Data: 310240 Block 7: Lock 1: CLOSED -> Lock Data: 310250 Block 8: Lock 1: CLOSED -> Lock Data: 310260 Block 9: Lock 1: CLOSED -> Lock Data: 310270 Block 10: Lock 1: CLOSED -> Lock Data: 310300 Block 11: Lock 1: CLOSED -> Lock Data: 310310 Block 12: Lock 1: CLOSED -> Lock Data: 310490 Block 13: Lock 1: CLOSED -> Lock Data: 310530 Block 14: Lock 1: CLOSED -> Lock Data: 310580 Block 15: Lock 1: CLOSED -> Lock Data: 310590 Block 16: Lock 1: CLOSED -> Lock Data: 310640 Block 17: Lock 1: CLOSED -> Lock Data: 310660 Block 18: Lock 1: CLOSED -> Lock Data: 310800 Reading phone...Type: RM-147, Ver: 05.02 Reading imei... Imei: 356433011431494 Version Not supported! | |
Nokia 1680 RM-490 and 2680s RM-500 | curtisbcm | Universalbox | 1 | 10-28-2009 15:56 |
8800 rm-13 and 8800d rm-165 | alex ong | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 07-18-2009 14:17 |
5310b RM-304 and 5300b RM-147 : is not possible? | djdownfawl | Genie Universal | 3 | 03-04-2009 21:42 |
5300b RM 147 and N73 softbank unlocked | amps_jas | BB5BOX | 1 | 10-25-2007 13:46 |
