Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > J.A.F - Just Another Flasher > J.A.F. By Jafsupport.com > J.A.F. V-SPEC
Old 07-09-2008, 22:39   #1 (permalink)
Member: 196126
Thanks Meter: 80
3/3 10/10 means how to unlock 3110c with v-spec
Hi all the problem is I have a 3110c for unlocking version 5,50 and 3/3 10/10 counter each attepmt to unlock this version finished with error 08 message after downgrading to 5,00 which I know v-spec likes much more I cannot unlock it as it cannot reset counter ... after flashing 5.50 version back I can keep on trying unlocking it but it doesnt make any sense Phone I ve received had allready all tries used so my pm backup is useless Ive discovered once after downgrading to 5,00 right after connecting to box it show 0 0 and I have 1 attempt left to unlock because after it still shows 3/3 10/10 Any advises BR
Old 07-09-2008, 22:42   #2 (permalink)
Member: 196126
Thanks Meter: 80
5,00
I meant 5.01 version sry
Old 07-09-2008, 22:44   #3 (permalink)
unlockingcrew's Avatar
Member: 233450
Sonork: 100.114140
Thanks Meter: 37
Say Clearly Bro,can U Reset Do U Have Original Back Up?
Old 07-09-2008, 22:49   #4 (permalink)
Member: 196126
Thanks Meter: 80
Re
No I dont have a backup got phone with 3/3 10/10 counter allready
Old 07-14-2008, 16:01   #5 (permalink)
Member: 196126
Thanks Meter: 80
Version 1.98.50
LOCK STATUS:
CONFIG KEY: 8000000000000000
PROVIDER KEY: 2600300000000000
Provider: IDEA Centertel;Poland
Key Code count: 3, FBUS Code count: 0
Block 1:
Lock 1: CLOSED -> Lock Data: 26003F
Reading phone...Type: RM-237, Ver: 05.01
Reading imei...
Imei: 358672012632430
Reading HW ID...1001
Found general data...
Waiting for TP confirmation...........Sending code...
Waiting for TP confirmation....Sending code...
Waiting for TP confirmation........Sending code...
Error unlocking! Code: 08
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 05.01
21-05-07
RM-237
(c) Nokia.
HW version: 1001
PCI version:
RFIC version:  17211721
DSP version:  pb06w14v51
PPM version: V 05.01
21-05-07
RM-237
(c) Nokia.
I
BT MCM version: 06cc-P9.1
Retu version: 32
Tahvo version: 53
Content Pack version: Content: i_ny
V 05.01
21-05-07
RM-237
(c) Nokia.
Production serial number: PBO309146
Product code: 0556976
Module code: 0203291
Basic production code: 0542523
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 358672012632430
IMEI spare to net: 3A 85 76 02 21 36 42 03
IMEI SV to net: 33 85 76 02 21 36 42 03 F8
LOCK STATUS:
Key Code count: 3, FBUS Code count: 3
Block 1:
Searching for saved ini...
Checking for file G:\Program Files\ODEON\JAF\JAF_RM-237.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0556976
MCU Flash file: G:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__04.91.mcusw
PPM Flash file: G:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__04.91.ppm_s
CNT Flash file: G:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__04.91.image_s
Languages in ppm: English,Bahasa Indonesia,Bahasa Malasia
Done!
Setting test mode...
Setting FULL FACTORY...
Operation took 0 minutes 5 seconds...
Done!
Backup simlock data first...
Reading IMEI...
Backup already done, skiping...
Detecting phone...
Reading simlock...
LOCK STATUS:
Block 1:
Reading imei...
Waiting for TP confirmation.....................Sending code...
Waiting for TP confirmation......Sending code...
Reading...
21-05-07
RM-237
(c) Nokia.
HW version: 1001
PCI version:
21-05-07
RM-237
(c) Nokia.
I
Retu version: 32
Tahvo version: 53
V 05.01
21-05-07
RM-237
(c) Nokia.
Flash code:
Order number:
Long production SN:
ATO:
Default SN type:
LOCK STATUS:
Key Code count: 3, FBUS Code count: 6
Block 1:
Done!
Reading IMEI...
Detecting phone...
Reading simlock...
LOCK STATUS:
Block 1:
Reading imei...
Detected P-KEY: 90000FE8
P-key nokia module version 01.02
I did restore a beckuped pm and now counter is ok but I cannot unlock the phone anyway any ideas TP cable is ok
Old 07-14-2008, 16:12   #6 (permalink)
hawks007's Avatar
Member: 621737
Thanks Meter: 87
Hi U Need To Upgread To V5.51 And Then Try To Unlock
Best Of Luck
Old 07-15-2008, 20:32   #7 (permalink)
Member: 196126
Thanks Meter: 80
The point
The point is I did make a backup phone came with 0 0 counter just version 1.98.51 using all tries in my case and counter is blocked we need to flash pm back and I cannot unlock version 5,51 after many tries downgrading to 1.98.50 causes soft is sending 3 tries each time 2 days ago I did unlocked E65 without special problems TP cable is ok I dunno is this a problem with phone is this a software ...
PS Sry to moderators if Im doubling posts last time about it Best regards
Old 07-21-2008, 23:10   #8 (permalink)
Member: 196126
Thanks Meter: 80
Solved
Phone unlocked by BB5 box Think unsupported flash chip or so Thread closed BR
how to flash 3110c with MT BOX Misbahullah MT-BOX 5 02-02-2010 19:42
how to unlock o2x1i with infinity with test point? ikram tabassum1 Infinity-Box 1 12-16-2009 08:06
to all experts how to unlock sl75 with mt with out testpoint [email protected] MT-BOX 1 05-24-2008 18:13
how to unlock 3110c nilan MT-BOX 2 12-24-2007 15:51
unable to unlock 3110c with Dejan box tgsm Nokia Base Band 5 ( BB-5 ) 0 10-03-2007 10:14
Page generated in 0.16420 seconds with 9 queries
