Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > J.A.F - Just Another Flasher > J.A.F. By Jafsupport.com > J.A.F. V-SPEC
Old 05-22-2008, 04:25   #1 (permalink)
gswireless's Avatar
Member: 276663
Thanks Meter: 39
JAF BB5 Box is not doing the job!!!
Dear JAF team I have JAF box and I have been using it for almost 2 years I decided to add on the BB5 box I'm doing every thing right unless I'm missing something, I'm using direct USB port no hubs and the blue light is ON and I try to unlock more that 3 deferent kind of Nokia BB5 is giving that error,by the way the box is brand new never used I haven't done not even one unlocking for BB5 yet,
GS Wireless wrote:
> *Every thing is connected promptly, even I thought there is some
thing
> wrong with the cable I just received my new shippment from you and
> used the new cable it's the same thing so the box defenatly is not
> working,*
> JAF version 1.98.47
> Detected PKEY: 900074FD
> Card life counter: 96.22%
> P-key nokia module version 01.01
> Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library
> version: 30107
> JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
> JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
> JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
> JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
> Changing mode...Done!
> FILES SET FOR FLASHING:
> MCU Flash file: NONE
> PPM Flash file: NONE
> CNT Flash file: NONE
> APE Variant file: NONE
> Switching to serial...
> Powering the phone...
> Failed! Aborting!
> JAF version 1.98.47
> Card life counter: 96.27%
> version: 30107
> Backup simlock data first...
> Setting local mode...
> Failed! Aborting!
> Can't backup simlock data!Abort!
Old 05-22-2008, 13:24   #2 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,993
first of all i suggest you to use new version of jaf 1.98.49
second think connect red wire to positive and yellow wire to BSI
thrid press power on button before proceed(till you can see local or test mode on screen)
follow this steps sure you will suceed
Old 05-23-2008, 06:48   #3 (permalink)
gswireless's Avatar
Member: 276663
Thanks Meter: 39
thanks for the help, I did exactly what you posted but the only thing I missed didn't press the power button before proceed, but and I will do that tomorrow and post the result after upgrading to the latest version 1.98.49
Old 05-23-2008, 19:43   #4 (permalink)
gswireless's Avatar
Member: 276663
Thanks Meter: 39
JAF BB5 box is not power on the phones
still doing the same, any other addvise? I have updated the box to the latest version 1.98.48 or you think the box defective?
Old 05-24-2008, 02:03   #5 (permalink)
Member: 374333
Thanks Meter: 18
Hi , after jaf updated did you update v-spec ini.file again ? Check here http://forum./showthread.php?t=464519
Old 05-25-2008, 16:09   #6 (permalink)
gswireless's Avatar
Member: 276663
Thanks Meter: 39
JAF BB5 Box problem
I really appreciate your help, I don't thing so I did update the V-spec ini file but I will do that on Tuesday and post the result, thanks
Old 05-27-2008, 22:50   #7 (permalink)
gswireless's Avatar
Member: 276663
Thanks Meter: 39
JAF BB5 is not doing any thing I gave up!!!
I did every possible steps and JAF BB5 Box keep giving me that error I gave up!!!
JAF version 1.98.48
Card life counter: 100.00%
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107
Failed! Aborting!
Failed! Aborting!
7290 is not do the unlock X-TRA BlackBerry (RIM) 3 10-09-2009 09:05
my bb5 box is not use in bb5 king jatin_1306 BB5KING for (BB5BOX) 0 12-14-2008 15:13
Can some boday support the 1200 1208 as GSMtrick with his stuped box is not do it yavar Nokia Digital Core Technology 4 ( DCT-4 ) 7 03-22-2008 12:02
JAF BOX is not in boot mode... Reconnect the box and try again mRoiZo83 J.A.F. By Jafsupport.com 0 11-18-2007 22:07
Page generated in 0.19174 seconds with 9 queries
