07-28-2008, 09:34 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Location: kadapa {A.P} Age: 43
Member: 151175 Status: Offline Sonork: 105497 Thanks Meter: 98 | n73 vodaphone unlocked sucessfully Detected PKEY: 9000334A Card life counter: 94.29% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B0, Driver version: 20405, Library version: 30115 JAF DCT4/BB5 LOADERS DIR: D:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: D:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: D:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: D:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Changing mode...Done! Booting phone... Error sync the phone... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05wk47v38.1 19-01-07 RM-133 (c) Nokia. HW version: 6020 PCI version: RFIC version: 17211721 DSP version: scarfe_05wk46v41 Retu version: 15 Tahvo version: 22 Production serial number: CNH067312 Product code: 0541044 Module code: 0202855 Basic production code: 0527006 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356438018737793 IMEI spare to net: 3A 65 34 08 81 37 77 09 IMEI SV to net: 33 65 34 08 81 37 77 09 F0 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2341500000000000 Provider: Vodafone;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23415F Block 2: Lock 1: CLOSED -> Lock Data: 23415F Searching for saved ini... Checking for file D:\Program Files\ODEON\JAF\JAF_RM-133.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0541044 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backup simlock data first... Setting local mode... Reading IMEI... D:\Program Files\ODEON\JAF\ProgData\RM-133_356438018737793_05wk47v38.1_LCK_backup.pm Done! Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2341500000000000 Provider: Vodafone;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23415F Block 2: Lock 1: CLOSED -> Lock Data: 23415F Reading phone...Type: RM-133, Ver: 05wk47v38.1 Reading imei... Imei: 356438018737793 Reading HW ID...6020 Found general data... Waiting for TP confirmation...................................... ...................................Detecting phone... failed! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05wk47v38.1 19-01-07 RM-133 (c) Nokia. HW version: 6020 PCI version: RFIC version: 17211721 DSP version: scarfe_05wk46v41 Retu version: 15 Tahvo version: 22 Production serial number: CNH067312 Product code: 0541044 Module code: 0202855 Basic production code: 0527006 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356438018737793 IMEI spare to net: 3A 65 34 08 81 37 77 09 IMEI SV to net: 33 65 34 08 81 37 77 09 F0 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2341500000000000 Provider: Vodafone;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23415F Block 2: Lock 1: CLOSED -> Lock Data: 23415F Searching for saved ini... Checking for file D:\Program Files\ODEON\JAF\JAF_RM-133.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0541044 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2341500000000000 Provider: Vodafone;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23415F Block 2: Lock 1: CLOSED -> Lock Data: 23415F Reading phone...Type: RM-133, Ver: 05wk47v38.1 Reading imei... Imei: 356438018737793 Reading HW ID...6020 Found general data... Waiting for TP confirmation......................FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05wk47v38.1 19-01-07 RM-133 (c) Nokia. HW version: 6020 PCI version: RFIC version: 17211721 DSP version: scarfe_05wk46v41 Retu version: 15 Tahvo version: 22 Production serial number: CNH067312 Product code: 0541044 Module code: 0202855 Basic production code: 0527006 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356438018737793 IMEI spare to net: 3A 65 34 08 81 37 77 09 IMEI SV to net: 33 65 34 08 81 37 77 09 F0 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2341500000000000 Provider: Vodafone;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23415F Block 2: Lock 1: CLOSED -> Lock Data: 23415F Searching for saved ini... Checking for file D:\Program Files\ODEON\JAF\JAF_RM-133.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0541044 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2341500000000000 Provider: Vodafone;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23415F Block 2: Lock 1: CLOSED -> Lock Data: 23415F Reading phone...Type: RM-133, Ver: 05wk47v38.1 Reading imei... Imei: 356438018737793 Reading HW ID...6020 Found general data... Waiting for TP confirmation..............................FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05wk47v38.1 19-01-07 RM-133 (c) Nokia. HW version: 6020 PCI version: RFIC version: 17211721 DSP version: scarfe_05wk46v41 APE SW Core version: V 3.0704.1.0.1 19-01-2007 RM-133 APE Variant version: V 3.0704.1.0.1-34 19-01-2007 RM-133 Retu version: 15 Tahvo version: 22 APE HW version: 1 APE ADSP SW version: 256 Camera version: 1 APE BT version: HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10. Production serial number: CNH067312 Product code: 0541044 Module code: 0202855 Basic production code: 0527006 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356438018737793 IMEI spare to net: 3A 65 34 08 81 37 77 09 IMEI SV to net: 33 65 34 08 81 37 77 29 F1 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2341500000000000 Provider: Vodafone;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23415F Block 2: Lock 1: CLOSED -> Lock Data: 23415F Searching for saved ini... Checking for file D:\Program Files\ODEON\JAF\JAF_RM-133.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0541044 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2341500000000000 Provider: Vodafone;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23415F Block 2: Lock 1: CLOSED -> Lock Data: 23415F Reading phone...Type: RM-133, Ver: 05wk47v38.1 Reading imei... Imei: 356438018737793 Reading HW ID...6020 Found general data... Waiting for TP confirmation....................Sending code... Unlock OK! Reading simlock data... LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2341500000000000 Provider: Vodafone;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Block 2: Lock 1: OPEN Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05wk47v38.1 19-01-07 RM-133 (c) Nokia. HW version: 6020 PCI version: RFIC version: 17211721 DSP version: scarfe_05wk46v41 APE SW Core version: V 3.0704.1.0.1 19-01-2007 RM-133 APE Variant version: V 3.0704.1.0.1-34 19-01-2007 RM-133 Retu version: 15 Tahvo version: 22 APE HW version: 1 APE ADSP SW version: 256 Camera version: 1 APE BT version: HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10. Production serial number: CNH067312 Product code: 0541044 Module code: 0202855 Basic production code: 0527006 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356438018737793 IMEI spare to net: 3A 65 34 08 81 37 77 09 IMEI SV to net: 33 65 34 08 81 37 77 29 F1 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2341500000000000 Provider: Vodafone;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Block 2: Lock 1: OPEN Searching for saved ini... Checking for file D:\Program Files\ODEON\JAF\JAF_RM-133.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0541044 No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! |
e710 vodaphone unlock | alanmar | Trident/AGERE Platform | 27 | 01-25-2008 09:10 |
N73 unlocked Sucessfully Without Micro here !! | .:Shorbagy Team:. | BB5BOX | 2 | 12-29-2007 00:59 |
N73 Unlock Sucessfully | .::KHURRAM::. | UID - Box | 1 | 10-19-2007 16:09 |
..::J220i Vodaphone Unlock TIPS::.. | sharaz191 | LG | 2 | 04-22-2007 11:37 |
30 v525 Netherland Vodaphone unlock | Gabidi | Motorola P2k | 0 | 03-04-2004 02:45 |
