12-01-2007, 21:51 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 51
Member: 133320 Status: Offline Thanks Meter: 0 | jaf v with 6131 failed this is a 50 items with jaf v-spec and 6131 but not unlock JAF version 1.98.42 Detected PKEY: 9000C30D Card life counter: 89.72% P-key nokia module version 01.00 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 06.10 16-02-07 RM-115 (c) Nokia. HW version: 1009 PCI version: RFIC version: 17211721 DSP version: dsp_mojito_05w46v48.1 PPM version: V 06.10 16-02-07 RM-115 (c) Nokia. A Retu version: 32 Tahvo version: 52 Production serial number: NH0609763 Product code: 0535003 Module code: 0202802 Basic production code: 0526012 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 352736013513356 IMEI spare to net: 3A 25 37 06 31 15 33 05 IMEI SV to net: 33 25 37 06 31 15 33 05 F7 LOCK STATUS: CONFIG KEY: 3102000000000000 Provider: T-Mobile;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 20416F Block 2: Lock 1: CLOSED -> Lock Data: 21630F Block 3: Lock 1: CLOSED -> Lock Data: 21901F Block 4: Lock 1: CLOSED -> Lock Data: 23001F Block 5: Lock 1: CLOSED -> Lock Data: 23102F Block 6: Lock 1: CLOSED -> Lock Data: 23203F Block 7: Lock 1: CLOSED -> Lock Data: 23430F Block 8: Lock 1: CLOSED -> Lock Data: 25001F Block 9: Lock 1: CLOSED -> Lock Data: 25502F Block 10: Lock 1: CLOSED -> Lock Data: 26002F Block 11: Lock 1: CLOSED -> Lock Data: 26201F Block 12: Lock 1: CLOSED -> Lock Data: 310160 Block 13: Lock 1: CLOSED -> Lock Data: 310200 Block 14: Lock 1: CLOSED -> Lock Data: 310210 Block 15: Lock 1: CLOSED -> Lock Data: 310220 Block 16: Lock 1: CLOSED -> Lock Data: 310230 Block 17: Lock 1: CLOSED -> Lock Data: 310240 Block 18: Lock 1: CLOSED -> Lock Data: 310250 Block 19: Lock 1: CLOSED -> Lock Data: 310260 Block 20: Lock 1: CLOSED -> Lock Data: 310270 Block 21: Lock 1: CLOSED -> Lock Data: 310280 Block 22: Lock 1: CLOSED -> Lock Data: 310300 Block 23: Lock 1: CLOSED -> Lock Data: 310310 Block 24: Lock 1: CLOSED -> Lock Data: 310580 Block 25: Lock 1: CLOSED -> Lock Data: 310660 Block 26: Lock 1: CLOSED -> Lock Data: 310800 Block 27: Lock 1: CLOSED -> Lock Data: 20416F Block 28: Lock 1: CLOSED -> Lock Data: 21630F Block 29: Lock 1: CLOSED -> Lock Data: 21901F Block 30: Lock 1: CLOSED -> Lock Data: 23001F Block 31: Lock 1: CLOSED -> Lock Data: 23102F Block 32: Lock 1: CLOSED -> Lock Data: 23203F Block 33: Lock 1: CLOSED -> Lock Data: 23430F Block 34: Lock 1: CLOSED -> Lock Data: 25001F Block 35: Lock 1: CLOSED -> Lock Data: 25502F Block 36: Lock 1: CLOSED -> Lock Data: 26002F Block 37: Lock 1: CLOSED -> Lock Data: 26201F Block 38: Lock 1: CLOSED -> Lock Data: 310160 Block 39: Lock 1: CLOSED -> Lock Data: 310200 Block 40: Lock 1: CLOSED -> Lock Data: 310210 Block 41: Lock 1: CLOSED -> Lock Data: 310220 Block 42: Lock 1: CLOSED -> Lock Data: 310230 Block 43: Lock 1: CLOSED -> Lock Data: 310240 Block 44: Lock 1: CLOSED -> Lock Data: 310250 Block 45: Lock 1: CLOSED -> Lock Data: 310260 Block 46: Lock 1: CLOSED -> Lock Data: 310270 Block 47: Lock 1: CLOSED -> Lock Data: 310280 Block 48: Lock 1: CLOSED -> Lock Data: 310300 Block 49: Lock 1: CLOSED -> Lock Data: 310310 Block 50: Lock 1: CLOSED -> Lock Data: 310580 Block 51: Lock 1: CLOSED -> Lock Data: 310660 Block 52: Lock 1: CLOSED -> Lock Data: 310800 Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-115.ini FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... Failed! Aborting! IMEI FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 06.10 16-02-07 RM-115 (c) Nokia. HW version: 1009 PCI version: RFIC version: 17211721 DSP version: dsp_mojito_05w46v48.1 PPM version: V 06.10 16-02-07 RM-115 (c) Nokia. A Retu version: 32 Tahvo version: 52 Production serial number: NH0609763 Product code: 0535003 Module code: 0202802 Basic production code: 0526012 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 352736013513356 IMEI spare to net: 3A 25 37 06 31 15 33 05 IMEI SV to net: 33 25 37 06 31 15 33 05 F7 LOCK STATUS: CONFIG KEY: 3102000000000000 Provider: T-Mobile;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 20416F Block 2: Lock 1: CLOSED -> Lock Data: 21630F Block 3: Lock 1: CLOSED -> Lock Data: 21901F Block 4: Lock 1: CLOSED -> Lock Data: 23001F Block 5: Lock 1: CLOSED -> Lock Data: 23102F Block 6: Lock 1: CLOSED -> Lock Data: 23203F Block 7: Lock 1: CLOSED -> Lock Data: 23430F Block 8: Lock 1: CLOSED -> Lock Data: 25001F Block 9: Lock 1: CLOSED -> Lock Data: 25502F Block 10: Lock 1: CLOSED -> Lock Data: 26002F Block 11: Lock 1: CLOSED -> Lock Data: 26201F Block 12: Lock 1: CLOSED -> Lock Data: 310160 Block 13: Lock 1: CLOSED -> Lock Data: 310200 Block 14: Lock 1: CLOSED -> Lock Data: 310210 Block 15: Lock 1: CLOSED -> Lock Data: 310220 Block 16: Lock 1: CLOSED -> Lock Data: 310230 Block 17: Lock 1: CLOSED -> Lock Data: 310240 Block 18: Lock 1: CLOSED -> Lock Data: 310250 Block 19: Lock 1: CLOSED -> Lock Data: 310260 Block 20: Lock 1: CLOSED -> Lock Data: 310270 Block 21: Lock 1: CLOSED -> Lock Data: 310280 Block 22: Lock 1: CLOSED -> Lock Data: 310300 Block 23: Lock 1: CLOSED -> Lock Data: 310310 Block 24: Lock 1: CLOSED -> Lock Data: 310580 Block 25: Lock 1: CLOSED -> Lock Data: 310660 Block 26: Lock 1: CLOSED -> Lock Data: 310800 Block 27: Lock 1: CLOSED -> Lock Data: 20416F Block 28: Lock 1: CLOSED -> Lock Data: 21630F Block 29: Lock 1: CLOSED -> Lock Data: 21901F Block 30: Lock 1: CLOSED -> Lock Data: 23001F Block 31: Lock 1: CLOSED -> Lock Data: 23102F Block 32: Lock 1: CLOSED -> Lock Data: 23203F Block 33: Lock 1: CLOSED -> Lock Data: 23430F Block 34: Lock 1: CLOSED -> Lock Data: 25001F Block 35: Lock 1: CLOSED -> Lock Data: 25502F Block 36: Lock 1: CLOSED -> Lock Data: 26002F Block 37: Lock 1: CLOSED -> Lock Data: 26201F Block 38: Lock 1: CLOSED -> Lock Data: 310160 Block 39: Lock 1: CLOSED -> Lock Data: 310200 Block 40: Lock 1: CLOSED -> Lock Data: 310210 Block 41: Lock 1: CLOSED -> Lock Data: 310220 Block 42: Lock 1: CLOSED -> Lock Data: 310230 Block 43: Lock 1: CLOSED -> Lock Data: 310240 Block 44: Lock 1: CLOSED -> Lock Data: 310250 Block 45: Lock 1: CLOSED -> Lock Data: 310260 Block 46: Lock 1: CLOSED -> Lock Data: 310270 Block 47: Lock 1: CLOSED -> Lock Data: 310280 Block 48: Lock 1: CLOSED -> Lock Data: 310300 Block 49: Lock 1: CLOSED -> Lock Data: 310310 Block 50: Lock 1: CLOSED -> Lock Data: 310580 Block 51: Lock 1: CLOSED -> Lock Data: 310660 Block 52: Lock 1: CLOSED -> Lock Data: 310800 Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-115.ini FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 06.10 16-02-07 RM-115 (c) Nokia. HW version: 1009 PCI version: RFIC version: 17211721 DSP version: dsp_mojito_05w46v48.1 PPM version: V 06.10 16-02-07 RM-115 (c) Nokia. A Retu version: 32 Tahvo version: 52 Production serial number: NH0609763 Product code: 0535003 Module code: 0202802 Basic production code: 0526012 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 352736013513356 IMEI spare to net: 3A 25 37 06 31 15 33 05 IMEI SV to net: 33 25 37 06 31 15 33 05 F7 LOCK STATUS: CONFIG KEY: 3102000000000000 Provider: T-Mobile;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 20416F Block 2: Lock 1: CLOSED -> Lock Data: 21630F Block 3: Lock 1: CLOSED -> Lock Data: 21901F Block 4: Lock 1: CLOSED -> Lock Data: 23001F Block 5: Lock 1: CLOSED -> Lock Data: 23102F Block 6: Lock 1: CLOSED -> Lock Data: 23203F Block 7: Lock 1: CLOSED -> Lock Data: 23430F Block 8: Lock 1: CLOSED -> Lock Data: 25001F Block 9: Lock 1: CLOSED -> Lock Data: 25502F Block 10: Lock 1: CLOSED -> Lock Data: 26002F Block 11: Lock 1: CLOSED -> Lock Data: 26201F Block 12: Lock 1: CLOSED -> Lock Data: 310160 Block 13: Lock 1: CLOSED -> Lock Data: 310200 Block 14: Lock 1: CLOSED -> Lock Data: 310210 Block 15: Lock 1: CLOSED -> Lock Data: 310220 Block 16: Lock 1: CLOSED -> Lock Data: 310230 Block 17: Lock 1: CLOSED -> Lock Data: 310240 Block 18: Lock 1: CLOSED -> Lock Data: 310250 Block 19: Lock 1: CLOSED -> Lock Data: 310260 Block 20: Lock 1: CLOSED -> Lock Data: 310270 Block 21: Lock 1: CLOSED -> Lock Data: 310280 Block 22: Lock 1: CLOSED -> Lock Data: 310300 Block 23: Lock 1: CLOSED -> Lock Data: 310310 Block 24: Lock 1: CLOSED -> Lock Data: 310580 Block 25: Lock 1: CLOSED -> Lock Data: 310660 Block 26: Lock 1: CLOSED -> Lock Data: 310800 Block 27: Lock 1: CLOSED -> Lock Data: 20416F Block 28: Lock 1: CLOSED -> Lock Data: 21630F Block 29: Lock 1: CLOSED -> Lock Data: 21901F Block 30: Lock 1: CLOSED -> Lock Data: 23001F Block 31: Lock 1: CLOSED -> Lock Data: 23102F Block 32: Lock 1: CLOSED -> Lock Data: 23203F Block 33: Lock 1: CLOSED -> Lock Data: 23430F Block 34: Lock 1: CLOSED -> Lock Data: 25001F Block 35: Lock 1: CLOSED -> Lock Data: 25502F Block 36: Lock 1: CLOSED -> Lock Data: 26002F Block 37: Lock 1: CLOSED -> Lock Data: 26201F Block 38: Lock 1: CLOSED -> Lock Data: 310160 Block 39: Lock 1: CLOSED -> Lock Data: 310200 Block 40: Lock 1: CLOSED -> Lock Data: 310210 Block 41: Lock 1: CLOSED -> Lock Data: 310220 Block 42: Lock 1: CLOSED -> Lock Data: 310230 Block 43: Lock 1: CLOSED -> Lock Data: 310240 Block 44: Lock 1: CLOSED -> Lock Data: 310250 Block 45: Lock 1: CLOSED -> Lock Data: 310260 Block 46: Lock 1: CLOSED -> Lock Data: 310270 Block 47: Lock 1: CLOSED -> Lock Data: 310280 Block 48: Lock 1: CLOSED -> Lock Data: 310300 Block 49: Lock 1: CLOSED -> Lock Data: 310310 Block 50: Lock 1: CLOSED -> Lock Data: 310580 Block 51: Lock 1: CLOSED -> Lock Data: 310660 Block 52: Lock 1: CLOSED -> Lock Data: 310800 Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-115.ini FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! it is failed box |
nokis 6131 failed to enter local/test mode | arafay | BB5BOX | 5 | 02-16-2008 18:36 |
problem with 6131 | TICTAC_M | MT-BOX | 3 | 07-19-2007 09:18 |
troubles with 6131 nokia | sauliux | Nokia Base Band 5 ( BB-5 ) | 2 | 12-01-2006 13:30 |
Problem with 6131 | sonkar | MT-BOX | 9 | 11-08-2006 07:19 |
