01-28-2008, 18:08 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Italy
Member: 329458 Status: Offline Thanks Meter: 153 | N95 Not Unlock Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 2341500000000000 Provider: Vodafone;United Kingdom Key Code count: 3, FBUS Code count: 1 Block 1: Lock 1: CLOSED -> Lock Data: 23415F Block 2: Lock 1: CLOSED -> Lock Data: 23415F Reading phone...Type: RM-159, Ver: 06wk41v31 Reading imei... Imei: 356962018144924 Waiting for TP confirmation......Failed! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 2341500000000000 Provider: Vodafone;United Kingdom Key Code count: 3, FBUS Code count: 1 Block 1: Lock 1: CLOSED -> Lock Data: 23415F Block 2: Lock 1: CLOSED -> Lock Data: 23415F Reading phone...Type: RM-159, Ver: 06wk41v31 Reading imei... Imei: 356962018144924 Waiting for TP confirmation...................................... .................................................. .................................................. ....Failed! Do you have a solution? |
01-31-2008, 02:04 | #8 (permalink) |
Freak Poster Join Date: May 2002 Location: portugal Age: 41
Member: 12340 Status: Offline Thanks Meter: 2 | i did one today with hw5900, at first shot unlocked.. i use external power for the phone, and made modifications for the cable. i was unlocking on v11 |
01-31-2008, 11:56 | #9 (permalink) |
Member: 329458 Status: Offline Thanks Meter: 153 | For external power you have used the original nokia charger? What is the modification that you have made on cable? My firmware is v12, and i try to downgrade, but failed... |
02-01-2008, 15:22 | #10 (permalink) |
Member: 12340 Status: Offline Thanks Meter: 2 | for external power i use a regulated power supply at 4v on the phone directly. On cable, i did remove all two test point wires and fuses. put CLK in Data place, and dessolder old cable from data testpoint and use a new one with better conductivity. and finally take out of the cable gnd and + wires because i use the power supply. |
N95 not unlock | abuiesa | BB5KING for (BB5BOX) | 6 | 01-22-2009 21:14 |
n95 not unlocked micro please help | oMeR_Rasheed | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 1 | 12-21-2008 15:20 |
help n95 not unlocked by bb5king | ali25 | BB5KING | 4 | 11-30-2008 09:38 |
nokia n95 not unlock | servisoft | BB5KING for (BB5BOX) | 3 | 11-27-2008 04:59 |
N95 not unlocking please help!!!!!!!!! | canny2 | UID - Box | 11 | 11-22-2007 12:30 |
