Have unlocking problems it might help U Hi all after many tries changing versions 198.50 51 52 changing ini files without luck I did succesfully unlock 6300 with spansion chip 6280 and few more phones with version 1.98.58 with its ini file from first try I hope it may stop part of our problems with unlocking with v-spec Best regards and GL to all users |
JAF version 1.98.61 Detected PKEY: 90013B74 Card life counter: 97.82% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 06.01 16-01-08 RM-217 (c) Nokia. HW version: 3021 PCI version: RFIC version: 17211721 DSP version: 06w14pb_07w39 PPM version: V 06.01 16-01-08 RM-217 (c) Nokia. E BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: bite_lt V 06.01 16-01-08 RM-217 (c) Nokia. Production serial number: KFS711436 Product code: 0567975 Module code: 0203166 Basic production code: 0555543 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 354860025743294 IMEI spare to net: 3A 45 68 00 52 47 23 09 IMEI SV to net: 33 45 68 00 52 47 23 19 F5 LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 3, FBUS Code count: 10 Block 1: Lock 1: CLOSED -> Lock Data: 23430F Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-217.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0567975 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-217\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\ Scanning ini files... Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-217\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__04.20.mcusw PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__04.20.ppm_w CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__04.20.image_ctv_india APE Variant file: NONE Languages in ppm: English,Chinese Trad,Chinese Simpl,Hindi Done! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 3, FBUS Code count: 10 Block 1: Lock 1: CLOSED -> Lock Data: 23430F All tries have been used.. restoring simlockdata! Setting local mode... Reading IMEI... Restoring C:\Program Files\ODEON\JAF\ProgData\RM-217_354860025743294_06.01_LCK_backup.pm Restarting phone... Done! Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23430F Reading phone...Type: RM-217, Ver: 06.01 Reading imei... Imei: 354860025743294 Reading HW ID...3021 Found general data... Waiting for TP confirmation.....Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... TP Failed... try again. Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 3, FBUS Code count: 10 Block 1: Lock 1: CLOSED -> Lock Data: 23430F All tries have been used.. restoring simlockdata! Setting local mode... Reading IMEI... Restoring C:\Program Files\ODEON\JAF\ProgData\RM-217_354860025743294_06.01_LCK_backup.pm Restarting phone... Done! Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23430F Reading phone...Type: RM-217, Ver: 06.01 Reading imei... Imei: 354860025743294 Reading HW ID...3021 Found general data... Waiting for TP confirmation...................Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... TP Failed... try again. Setting local mode... Reading IMEI... Restoring C:\Program Files\ODEON\JAF\ProgData\RM-217_354860025743294_06.01_LCK_backup.pm Restarting phone... Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 06.01 16-01-08 RM-217 (c) Nokia. HW version: 3021 PCI version: RFIC version: 17211721 DSP version: 06w14pb_07w39 PPM version: V 06.01 16-01-08 RM-217 (c) Nokia. E BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: bite_lt V 06.01 16-01-08 RM-217 (c) Nokia. Production serial number: KFS711436 Product code: 0567975 Module code: 0203166 Basic production code: 0555543 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 354860025743294 IMEI spare to net: 3A 45 68 00 52 47 23 09 IMEI SV to net: 33 45 68 00 52 47 23 19 F5 LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23430F Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-217.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0567975 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-217\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\ Scanning ini files... Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-217\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__04.20.mcusw PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__04.20.ppm_w CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__04.20.image_ctv_india APE Variant file: NONE Languages in ppm: English,Chinese Trad,Chinese Simpl,Hindi Done! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23430F Reading phone...Type: RM-217, Ver: 06.01 Reading imei... Imei: 354860025743294 Reading HW ID...3021 Found general data... Waiting for TP confirmation.....................Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... TP Failed... try again. Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 3, FBUS Code count: 10 Block 1: Lock 1: CLOSED -> Lock Data: 23430F All tries have been used.. restoring simlockdata! Setting local mode... Reading IMEI... Restoring C:\Program Files\ODEON\JAF\ProgData\RM-217_354860025743294_06.01_LCK_backup.pm Restarting phone... Done! Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23430F Reading phone...Type: RM-217, Ver: 06.01 Reading imei... Imei: 354860025743294 Reading HW ID...3021 Found general data... Waiting for TP confirmation...................Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... TP Failed... try again. Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 3, FBUS Code count: 10 Block 1: Lock 1: CLOSED -> Lock Data: 23430F All tries have been used.. restoring simlockdata! Setting local mode... Reading IMEI... Restoring C:\Program Files\ODEON\JAF\ProgData\RM-217_354860025743294_06.01_LCK_backup.pm Restarting phone... Done! Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23430F Reading phone...Type: RM-217, Ver: 06.01 Reading imei... Imei: 354860025743294 Reading HW ID...3021 Found general data... Waiting for TP confirmation............Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... TP Failed... try again. |
Well all we knows That 6,01 is not supported by v-spec in real downgrade to 5.00 and post results BR |
JAF version 1.98.61 Detected PKEY: 90013B74 Card life counter: 94.11% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05.00 27-04-07 RM-217 (c) Nokia. HW version: 3021 PCI version: RFIC version: 17211721 DSP version: pb06w14v51 PPM version: V 05.00 27-04-07 RM-217 (c) Nokia. W BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: ctv_india V 05.00 09-05-07 RM-217 (c) Nokia. Production serial number: KFS711436 Product code: 0567975 Module code: 0203166 Basic production code: 0555543 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 354860025743294 IMEI spare to net: 3A 45 68 00 52 47 23 09 IMEI SV to net: 33 45 68 00 52 47 23 09 F8 LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23430F Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-217.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0567975 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-217\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\ Scanning ini files... Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-217\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__04.20.mcusw PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__04.20.ppm_w CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__04.20.image_ctv_india APE Variant file: NONE Languages in ppm: English,Chinese Trad,Chinese Simpl,Hindi Done! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23430F Reading phone...Type: RM-217, Ver: 05.00 Reading imei... Imei: 354860025743294 Reading HW ID...3021 Found general data... Waiting for TP confirmation.....................Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... TP Failed... try again. Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 3, FBUS Code count: 10 Block 1: Lock 1: CLOSED -> Lock Data: 23430F All tries have been used.. restoring simlockdata! Setting local mode... Reading IMEI... Restoring C:\Program Files\ODEON\JAF\ProgData\RM-217_354860025743294_05.00_LCK_backup.pm Restarting phone... Done! Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23430F Reading phone...Type: RM-217, Ver: 05.00 Reading imei... Imei: 354860025743294 Reading HW ID...3021 Found general data... Waiting for TP confirmation......................Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... TP Failed... try again. Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 3, FBUS Code count: 10 Block 1: Lock 1: CLOSED -> Lock Data: 23430F All tries have been used.. restoring simlockdata! Setting local mode... Reading IMEI... Restoring C:\Program Files\ODEON\JAF\ProgData\RM-217_354860025743294_05.00_LCK_backup.pm Restarting phone... Done! Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23430F Reading phone...Type: RM-217, Ver: 05.00 Reading imei... Imei: 354860025743294 Reading HW ID...3021 Found general data... Waiting for TP confirmation..........Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... TP Failed... try again. Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 3, FBUS Code count: 10 Block 1: Lock 1: CLOSED -> Lock Data: 23430F All tries have been used.. restoring simlockdata! Setting local mode... Reading IMEI... Restoring C:\Program Files\ODEON\JAF\ProgData\RM-217_354860025743294_05.00_LCK_backup.pm Restarting phone... Done! Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2343000000000000 Provider: T-Mobile-One 2 One;United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 23430F Reading phone...Type: RM-217, Ver: 05.00 Reading imei... Imei: 354860025743294 Reading HW ID...3021 Found general data... Waiting for TP confirmation..............Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... Sending code... TP Failed... try again. |
Hmm reading problem? I DID POST IN FIRST POST TRY VERSION 1.98.51 IT DID help me |
