help with e65 i have try unlock e65 and nothing JAF version 1.98.57 Detected PKEY: 9000FF7C Card life counter: 97.64% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Programas\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Programas\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Programas\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Programas\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... Failed! Aborting! IMEI FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 2.0615.30 13-09-07 RM-208 (c) Nokia. HW version: 0810 PCI version: RFIC version: 17141715 DSP version: A06w14PB_07w32 Retu version: 15 Tahvo version: 22 Production serial number: SCN712868 Product code: 0563403 Module code: Basic production code: 0560030 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 358631xxxxxxxxx IMEI spare to net: 3A 85 36 01 01 07 14 08 IMEI SV to net: 33 85 36 01 01 07 14 28 F5 LOCK STATUS: CONFIG KEY: 0100000000000000 PROVIDER KEY: 2680600000000000 Provider: TMN;Portugal Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 26806F Block 2: Lock 1: CLOSED -> Lock Data: 26806F Searching for saved ini... Checking for file C:\Programas\ODEON\JAF\JAF_RM-208.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0563403 FILES SET FOR FLASHING: MCU Flash file: C:\Programas\Nokia\Phoenix\Products\RM-208\rm208_m128_h20_ka_prod_106331801_c00_combined. bin PPM Flash file: C:\Programas\Nokia\Phoenix\Products\RM-208\rm208_m128_h20_ka_prod_106331801_v01_variant.b in CNT Flash file: C:\Programas\Nokia\Phoenix\Products\RM-208\rm208_cp_2.0.fpsx APE Variant file: NONE Languages in ppm: English,French,German,Italian,Spanish,Portuguese Done! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 0100000000000000 PROVIDER KEY: 2680600000000000 Provider: TMN;Portugal Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 26806F Block 2: Lock 1: CLOSED -> Lock Data: 26806F Reading phone...Type: RM-208, Ver: 2.0615.30 Reading imei... Imei: 3586310xxxxxxxx Reading HW ID...0810 Found general data... Waiting for TP confirmation...................................... ...........Sending code... Communication lost... repower the phone and try again! some tips? thanks |
just keep trying and use easy tp good luck |
Itīs a trick... Communication lost... repower the phone and try again! Normally just change the GND to near the RAP or directly to conection cable board. and you iīll see that error dosen`t show again. and if havenīt help then change the wire and plug on TP cable. |
E65 Remove capasitor/s near TPs BR As I remember clock touches to ground removing capasitors makes unlocking much easier |
i donīt advise unless you donīt have problem in removing and put it again. just try and try ... and sometimes is better to close Jaf program and start again all that you are doing. is my best advise.... |
