Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > J.A.F - Just Another Flasher > J.A.F. By Jafsupport.com > J.A.F. V-SPEC
Old 06-11-2008, 12:52   #1 (permalink)
hawks007's Avatar
Member: 621737
Thanks Meter: 87
Exclamation bug 1.98.51
hi when i click for unlock 6234 v3.70 and conect clic its send code 13 time
quicly here is the log
JAF version 1.98.51
Detected PKEY: 900******xx
Card life counter: 96.55%
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107
JAF DCT4/BB5 LOADERS DIR: C:\Archivos de programa\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Archivos de programa\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Archivos de programa\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Archivos de programa\ODEON\JAF\Flash3\
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 03.70
15-05-06
RM-123
(c) Nokia
HW version: 1006
PCI version:
RFIC version:  17211721
DSP version:  pb05wk46v20
LCD version: SEIKO
PPM version: V 03.70
15-05-06
RM123_145_-
(c) Nokia
CVF
Retu version: 32
Tahvo version: 52
Content Pack version: Content: vg_es2
V 03.70
15-05-06
RM123_145_-
(c) Nokia
Production serial number: 2GJ333665
Product code: 0539254
Module code: 0202772
Basic production code: 0525641
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 359************x
IMEI spare to net: 3A 95 93 05 60 64 47 03
IMEI SV to net: 33 95 93 05 60 64 47 03 F3
LOCK STATUS:
CONFIG KEY: 8000000000000000
PROVIDER KEY: 2140100000000000
Provider: Vodafone / Airtel Movil;Spain
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: CLOSED -> Lock Data: 21401F
Searching for saved ini...
Checking for file C:\Archivos de programa\ODEON\JAF\JAF_RM-123.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0539254
MCU Flash file: C:\Archivos de programa\Nokia\Phoenix\Products\RM-123\rm123_145_30005.100.mcusw
PPM Flash file: C:\Archivos de programa\Nokia\Phoenix\Products\RM-123\rm123_145_3005.10.ppm_cvf
CNT Flash file: C:\Archivos de programa\Nokia\Phoenix\Products\RM-123\rm123_145_30005.10.image_vg_es2_v
Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese
Done!
Backup simlock data first...
Reading IMEI...
C:\Archivos de programa\ODEON\JAF\ProgData\RM-123_3593************_03.70_LCK_backup.pm
Done!
Detecting phone...
Reading simlock...
LOCK STATUS:
Block 1:
Reading phone...Type: RM-123, Ver: 03.70
Reading imei...
Imei: 3593************x
Reading HW ID...1006
Found general data...
Waiting for TP confirmation...................................... ..Sending code...
Sending code...
Sending code...
Sending code...
Sending code...
Sending code...
Sending code...
Sending code...
Sending code...
Sending code...
Sending code...
Sending code...
Sending code...
Error unlocking! Code: 08
Reading IMEI...
Backup already done, skiping...
Detecting phone...
Reading simlock...
LOCK STATUS:
Key Code count: 3, FBUS Code count: 10
Block 1:
All tries have been used.. restoring simlockdata!
Reading IMEI...
Restoring C:\Archivos de programa\ODEON\JAF\ProgData\RM-123_359395006467436_03.70_LCK_backup.pm
Restarting phone...
Done!
Detecting phone...
Reading simlock...
LOCK STATUS:
Block 1:
Reading imei...
Waiting for TP confirmation...................................... .......Sending code...
Unlock OK!
Reading simlock data...
LOCK STATUS:
Block 1:
Lock 1: OPEN
Done!
Old 06-11-2008, 18:32   #2 (permalink)
J.A.F.'s Avatar
Member: 71180
Thanks Meter: 811
Why you think this is a bug? You got your phone unlocked right?
JAF
Old 06-25-2008, 10:32   #3 (permalink)
lusomaco's Avatar
Member: 220414
Sonork: 100.1611916
Thanks Meter: 53
if the j.a.f 1.98.51 have a bug i hope that all updates have one bug, because now i can unlock all the phones supported
Old 06-25-2008, 12:16   #4 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,993
its no a bug its new implement in unlocking method that all remaining try are sent continuosly to the phone
Old 06-28-2008, 15:56   #5 (permalink)
Hitec Wireless's Avatar
Member: 268951
Thanks Meter: 46
Its not bug , what i think it is ,V-SPEC is trying different trigers like Advance Box does and if non worked gives ERROR 08 , Just Try it agane and it will work , i Just Unlocked E62-1 where Advansed Box didnt work for me as no trigers where found and it kept trying and trying , but V-SPEC did it right away , so i guess trigers in Jaf are different some times
Hitec
Old 06-29-2008, 12:36   #6 (permalink)
Member: 375139
Thanks Meter: 2
Well, I have N-95 locked and when I tryin' to unlock it (this is not my first phone) nothing happines. on earlier versions of JAF, i have seen if something goes wrong (error 08 etc), now i tryin' to unlock it (different firmware versions tested) and nothing happens
sending code...
sending code...
sending code...
sending code...only
Old 06-29-2008, 13:48   #7 (permalink)
Member: 375139
Thanks Meter: 2
Installed 1.98.47 and phone was unlocked after 3d try...tell me please what's the problem?!
Old 07-11-2008, 21:15   #8 (permalink)
Member: 196126
Thanks Meter: 80
Improvement?
JAF
http://forum.gsmhosting.com/vbb/showthread.php?t=563542
I went mad with 3110c 2 pieces which finally were given back to customer with tornado sim inside and so if its not a bug what can we expect from another updates?
3110c with 5.50 version supported hasnt been unlocked by me even once all the time i had to downgrade to 5.00 Best regards
PS 1.48.50 is ok if about it
Old 07-14-2008, 12:47   #9 (permalink)
Member: 255510
Thanks Meter: 15
hi you have any solution for this
JAF version 1.98.50
Detected PKEY: 9000BE00
Card life counter: 99.91%
FBUS INTERFACE NOT CONNECTED!!! please help my mail id is [email protected]
New update 1.98.51 discuss HERE!! gsmfun J.A.F. By Jafsupport.com 75 07-22-2008 15:58
09/06/2008 New JAF Setup 1.98.51 ready! gsmfun Service Products News & Updates 0 06-09-2008 16:41
Page generated in 0.21058 seconds with 10 queries
