Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > J.A.F - Just Another Flasher > J.A.F. By Jafsupport.com > J.A.F. V-SPEC
Old 02-25-2008, 18:43   #1 (permalink)
Member: 242985
Thanks Meter: 2
N73 Error Unlock : Code 07
JAF version 1.98.45
Detected PKEY: 90008F89
Card life counter: 99.21%
P-key nokia module version 01.00
Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107
JAF DCT4/BB5 LOADERS DIR: C:\Arquivos de programas\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Arquivos de programas\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Arquivos de programas\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Arquivos de programas\ODEON\JAF\Flash3\
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 05wk47v38.1
19-01-07
RM-133
(c) Nokia.
HW version: 7200
PCI version:
RFIC version:  17211721
DSP version: scarfe_05wk46v41
Retu version: 15
Tahvo version: 22
Production serial number: CFI389358
Product code: 0552871
Module code: 0202855
Basic production code: 0527006
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 358634019367089
IMEI spare to net: 3A 85 36 04 91 63 07 08
IMEI SV to net: 33 85 36 04 91 63 07 08 F0
LOCK STATUS:
CONFIG KEY: FFFFFFFFFFFFFFFF
Provider: Unknown provider
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: CLOSED -> Lock Data: 00101F
Searching for saved ini...
Checking for file C:\Arquivos de programas\ODEON\JAF\JAF_RM-133.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0552871
MCU Flash file: C:\Arquivos de programas\Nokia\Phoenix\Products\RM-133\N73_4.0736.3.2.1_western_C00_PRD_cc.fpsx
PPM Flash file: C:\Arquivos de programas\Nokia\Phoenix\Products\RM-133\N73_rofx_4.0736.3.2.1_PRD.V11
CNT Flash file: C:\Arquivos de programas\Nokia\Phoenix\Products\RM-133\N73_userarea_4.0736.3.2.1.U01
Languages in ppm: English,Simpl Chinese
Done!
Backup simlock data first...
Reading IMEI...
Backup already done, skiping...
Detecting phone...
Reading simlock...
LOCK STATUS:
Block 1:
Reading phone...Type: RM-133, Ver: 05wk47v38.1
Reading imei...
Imei: 358634019367089
Reading HW ID...7200
Found general data...
Waiting for TP confirmation..................Failed!
Failed! Aborting!
Can't backup simlock data!Abort!
Failed! Aborting!
Reading...
19-01-07
RM-133
(c) Nokia.
HW version: 7200
PCI version:
Retu version: 15
Tahvo version: 22
Flash code:
Order number:
Long production SN:
ATO:
Default SN type:
LOCK STATUS:
Block 1:
Done!
Reading IMEI...
Detecting phone...
Reading simlock...
LOCK STATUS:
Block 1:
Reading imei...
Waiting for TP confirmation...................................... .................................................. ........Sending code...
Error unlocking! Code: 07
Product supporter, please solved my problem......
Old 02-25-2008, 18:53   #2 (permalink)
SEMEN's Avatar
Member: 333494
Sonork: 100.1607053
Thanks Meter: 190
This byte response (07) you get only on phones from Telcel Mexico where entering codes is disabled.
More responses details:
08 - wrong code entered (in our case because of wrong TP cannot patch corectly flash on the fly)
0C - no more tries left (wrong counter at max. value)
55 - communication error (usualy when connect TP in wrong location
Old 02-25-2008, 19:03   #3 (permalink)
gsm8g's Avatar
Member: 126400
Thanks Meter: 24
is that all code errors
thanks
br
Old 02-26-2008, 06:10   #4 (permalink)
sharaz191's Avatar
Member: 249300
Sonork: 10101010
Thanks Meter: 569
SP data Corrupted..you must need rpl service
Old 02-26-2008, 22:17   #5 (permalink)
lusomaco's Avatar
Member: 220414
Sonork: 100.1611916
Thanks Meter: 53
in the 5300 and 5200 you can't mistake why Appears the error 08 ? because the flash?
Old 02-27-2008, 13:37   #6 (permalink)
Member: 252115
+1 corrupt certificates. Use ask\rpl service
Old 02-27-2008, 23:09   #7 (permalink)
Member: 282611
NOKIA - N73
Imei - 357651013470777
Virgin Mobile
Could You Pl Provide The Unlock Key
Old 02-28-2008, 21:20   #8 (permalink)
Registered User
Member: 115596
Thanks Meter: 1,127
LOCK STATUS:
CONFIG KEY: FFFFFFFFFFFFFFFF Daed
Old 03-05-2008, 17:22   #9 (permalink)
Member: 74379
Thanks Meter: 7
U need RPL to repair CONFIG KEY: FFFFFFFFFFFFFFFF
Key Code count: 0, FBUS Code count: 0ir
Use MT-Box to ask RPL, then unlock using your box. I think it will cost you 40 mt-box logs.
Old 03-05-2008, 20:36   #10 (permalink)
Registered User
Member: 143939
Thanks Meter: 264
Check if you have backup for phone before CONFIG KEY: FFFFFFFFFFFFFFFF
If not need rpl
Old 03-15-2008, 20:51   #11 (permalink)
fastlink Jogja's Avatar
Member: 192822
Thanks Meter: 18
i have same problem too.. 6280 from 3 mobile error 07 and when i check config key was FFFFFFF. my questions is why this could happen? because someone without knowledge and device trying to unlock or what? thanks for info
Old 03-17-2008, 06:25   #12 (permalink)
sharaz191's Avatar
Member: 249300
Sonork: 10101010
Thanks Meter: 569
Smile
Yes maybe some users damage SP datas of phone and maybe RAP damage.
Can a Nokia N73 be unlocked by code? thanks welshbhoy Phone Unlocking Codes & Maps 1 11-22-2009 03:42
N73 error unlock with bb5king_v109 Ros_GSM BB5KING 2 01-12-2009 18:41
Error unlocking code 07 siscel J.A.F. V-SPEC 11 02-13-2008 12:33
N73 error unlocking solved by .... tomi_no J.A.F. V-SPEC 1 01-26-2008 21:45
.:.All N73 Music Edition Product codes.:. alecandro_90 Nokia Base Band 5 ( BB-5 ) 2 11-26-2006 19:29
Page generated in 0.24360 seconds with 9 queries
