Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > J.A.F - Just Another Flasher > J.A.F. By Jafsupport.com > J.A.F. V-SPEC
Old 11-30-2007, 15:29   #1 (permalink)
ashok_kumar459's Avatar
Member: 202500
Thanks Meter: 234
nokia 6300 unlocked sucessfully after CONFIG KEY: FFFFFFFFFFFFFFFF
6300 SP DATA CURRUPTED
Provider: Unknown provider
Key Code count: 0, FBUS
abc Tiruppur: Block 1:
Lock 1: CLOSED -> Lock Data: 00101F
Reading phone...Type: RM-217, Ver: 05.00
Reading imei...
Imei: 354827014388696
Version Not supported!
MEAN rpl file is currupted with this phone.
need to buy rpl file from reseller.
how ? simply use dss software install and read .ask file its around 1kb file send it to reseller pay for it
u will get rpl file back
connect jaff with v-spec open CRT FOLDER IN BB5 REMOVE ALL THE TICK MARKED AND LOAD TO MOBILE .RPL RESELER GIVEN TO U
AFTER LOADING SUCESS READ INFO I.E.,
LOCK STATUS:
CONFIG KEY: 3027200000000000
Provider: Rogers AT&T Wireless;Canada
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: CLOSED -> Lock Data: 302370 Lock 2: CLOSED -> Lock Data: 302370
Block 2:
Lock 1: CLOSED -> Lock Data: 302720 Lock 2: CLOSED -> Lock Data: 302720
Reading imei...
NOW UNLOCK PHONE WITH V-SPEC THE RESULT IS
Block 1:
Lock 1: OPEN Lock 2: OPEN
Block 2:
Done!
abc Tiruppur: finally win the game
THANKS TO ALL
The Following User Says Thank You to ashok_kumar459 For This Useful Post:
Old 11-30-2007, 15:33   #2 (permalink)
moldovan's Avatar
Member: 23684
Sonork: 1582723
Thanks Meter: 684
Nothing new !
RPL rulez as always !!!
WBR!
Old 11-30-2007, 15:36   #3 (permalink)
Member: 202500
Thanks Meter: 234
This Might Help Those New To Entering Unlock Business Thanks For Ur Comments
Old 11-30-2007, 15:39   #4 (permalink)
Member: 202500
Thanks Meter: 234
Dss Software Is Here
Old 11-30-2007, 15:43   #5 (permalink)
erkan06us's Avatar
Member: 174769
Thanks Meter: 19
thanks for information
Old 11-30-2007, 15:49   #6 (permalink)
amitks_in's Avatar
Member: 111665
Sonork: 104250
Thanks Meter: 180
good ! nicely described ! will be helpfull for newbies !!
Old 11-30-2007, 15:56   #7 (permalink)
sharaz191's Avatar
Member: 249300
Sonork: 10101010
Thanks Meter: 569
But its not free service
Old 11-30-2007, 16:03   #8 (permalink)
Member: 137049
Thanks Meter: 7
nothing special......
Old 12-01-2007, 00:02   #9 (permalink)
ionelka's Avatar
Member: 204045
Thanks Meter: 7
15 Euro can solve many problems like RPL
Old 12-01-2007, 01:54   #10 (permalink)
Registered User
Member: 238519
Sonork: 100.1589249
Thanks Meter: 21
Old 12-01-2007, 11:34   #11 (permalink)
Afzaal's Avatar
Member: 128918
Thanks Meter: 282
if done after rpl
then nothing new
anyways thanks for shocking me
BR.
Old 12-01-2007, 12:05   #12 (permalink)
Tetouan Gsm's Avatar
Member: 190492
Sonork: 100.01010100
Thanks Meter: 190
i see that no news but ok good luck
Old 12-01-2007, 14:37   #13 (permalink)
Member: 187451
Thanks Meter: 163
i was shoked that he made the sp data curropted solution.but that guy is just sharing his experience.
Old 12-01-2007, 15:00   #14 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
yes it is ..............
At first Glance it looks like that VSPEC is now unlocking sp data corrupted ...
but its only the RPL
Old 12-11-2007, 17:32   #15 (permalink)
Member: 57254
Thanks Meter: 7
For ME, NOT WORKING !!!
This procedure DOES NOT WORK ALLWAYS !!!
CHECK THIS:
http://forum.gsmhosting.com/vbb/showthread.php?t=477752
>>> 6300 Config Key: FFFFFFFFFFFFFFFF REPAIRED <<< RNC_EBM BB5KING for (BB5BOX) 2 11-05-2008 10:58
Nokia 5200 Config Key: Ffffffffffffffff sandeepmtc J.A.F. By Jafsupport.com 3 01-08-2008 08:43
Nokia 5200 Config Key: Ffffffffffffffff sandeepmtc Nokia Base Band 5 ( BB-5 ) 8 01-08-2008 08:19
6131 Config Key: FFFFFFFFFFFFFFFF -> Unlock fail cbcelular BB5BOX 7 10-26-2007 12:05
Page generated in 0.20860 seconds with 10 queries
