12-31-2007, 20:55 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: CHINA Age: 34
Member: 320363 Status: Offline Sonork: 100.1578853 Thanks Meter: 3,938 | Not.... Working In Nokia 6086b Help jafsupport Reading... MCU SW version: V 15.04 30-08-07 RM-260 (c) Nokia. HW version: 1405 PCI version: RFIC version: 17211721 DSP version: pb06w14v50.1 PPM version: V 15.04 30-08-07 RM-260 (c) Nokia. IT BT MCM version: 06cc-P9.1 Retu version: 32 Tahvo version: 53 Content Pack version: Content: tmo_002 28-03-07 RM-260 (c) Nokia. Production serial number: PKF348373 Product code: 0544543 Module code: Basic production code: 0531929 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 353274002512450 IMEI spare to net: 3A 35 72 04 01 15 43 00 IMEI SV to net: 33 35 72 04 01 15 43 10 F1 LOCK STATUS: CONFIG KEY: 3102000000000000 Provider: T-Mobile;U.S.A. Key Code count: 3, FBUS Code count: 1 Block 1: Lock 1: CLOSED -> Lock Data: 310160 Block 2: Lock 1: CLOSED -> Lock Data: 310200 Block 3: Lock 1: CLOSED -> Lock Data: 310210 Block 4: Lock 1: CLOSED -> Lock Data: 310220 Block 5: Lock 1: CLOSED -> Lock Data: 310230 Block 6: Lock 1: CLOSED -> Lock Data: 310240 Block 7: Lock 1: CLOSED -> Lock Data: 310250 Block 8: Lock 1: CLOSED -> Lock Data: 310260 Block 9: Lock 1: CLOSED -> Lock Data: 310270 Block 10: Lock 1: CLOSED -> Lock Data: 310300 Block 11: Lock 1: CLOSED -> Lock Data: 310310 Block 12: Lock 1: CLOSED -> Lock Data: 310490 Block 13: Lock 1: CLOSED -> Lock Data: 310530 Block 14: Lock 1: CLOSED -> Lock Data: 310580 Block 15: Lock 1: CLOSED -> Lock Data: 310590 Block 16: Lock 1: CLOSED -> Lock Data: 310640 Block 17: Lock 1: CLOSED -> Lock Data: 310660 Block 18: Lock 1: CLOSED -> Lock Data: 310800 Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-260.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0544543 FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-260\rm260__15.04.mcusw.bin PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-260\rm260__15.04.ppm_it CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-260\rm260__15.04.image_i_tmobusa APE Variant file: NONE Done! Backup simlock data first... Setting local mode... Reading IMEI... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 3102000000000000 Provider: T-Mobile;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 310160 Block 2: Lock 1: CLOSED -> Lock Data: 310200 Block 3: Lock 1: CLOSED -> Lock Data: 310210 Block 4: Lock 1: CLOSED -> Lock Data: 310220 Block 5: Lock 1: CLOSED -> Lock Data: 310230 Block 6: Lock 1: CLOSED -> Lock Data: 310240 Block 7: Lock 1: CLOSED -> Lock Data: 310250 Block 8: Lock 1: CLOSED -> Lock Data: 310260 Block 9: Lock 1: CLOSED -> Lock Data: 310270 Block 10: Lock 1: CLOSED -> Lock Data: 310300 Block 11: Lock 1: CLOSED -> Lock Data: 310310 Block 12: Lock 1: CLOSED -> Lock Data: 310490 Block 13: Lock 1: CLOSED -> Lock Data: 310530 Block 14: Lock 1: CLOSED -> Lock Data: 310580 Block 15: Lock 1: CLOSED -> Lock Data: 310590 Block 16: Lock 1: CLOSED -> Lock Data: 310640 Block 17: Lock 1: CLOSED -> Lock Data: 310660 Block 18: Lock 1: CLOSED -> Lock Data: 310800 Reading phone...Type: RM-260, Ver: 15.04 Reading imei... Imei: 353274002512450 Waiting for TP confirmation...................................... ..Sending code... Error unlocking! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 3102000000000000 Provider: T-Mobile;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 310160 Block 2: Lock 1: CLOSED -> Lock Data: 310200 Block 3: Lock 1: CLOSED -> Lock Data: 310210 Block 4: Lock 1: CLOSED -> Lock Data: 310220 Block 5: Lock 1: CLOSED -> Lock Data: 310230 Block 6: Lock 1: CLOSED -> Lock Data: 310240 Block 7: Lock 1: CLOSED -> Lock Data: 310250 Block 8: Lock 1: CLOSED -> Lock Data: 310260 Block 9: Lock 1: CLOSED -> Lock Data: 310270 Block 10: Lock 1: CLOSED -> Lock Data: 310300 Block 11: Lock 1: CLOSED -> Lock Data: 310310 Block 12: Lock 1: CLOSED -> Lock Data: 310490 Block 13: Lock 1: CLOSED -> Lock Data: 310530 Block 14: Lock 1: CLOSED -> Lock Data: 310580 Block 15: Lock 1: CLOSED -> Lock Data: 310590 Block 16: Lock 1: CLOSED -> Lock Data: 310640 Block 17: Lock 1: CLOSED -> Lock Data: 310660 Block 18: Lock 1: CLOSED -> Lock Data: 310800 Reading phone...Type: RM-260, Ver: 15.04 Reading imei... Imei: 353274002512450 Waiting for TP confirmation...................................... ......Sending code... Error unlocking! HELP DEAR SIR HOW CAN I SOLV THISH PROBLEM WHAT WE HAVE NEED ANY MODIFICETION IN CABLE ? |
01-01-2008, 11:17 | #2 (permalink) |
Member: 320363 Status: Offline Sonork: 100.1578853 Thanks Meter: 3,938 | What The Wrong ..... WHER IS THE PRODUCT SUPPORTER I HAVE PROBLEM IN JAF V-SPEC EROOR IN UNLOCKING WHAT WE HAVE NEED ANY MODIFICETION IN CABLE ANSWER ME WHER ARE YOU WHAT MY CABLE IS FAIL PCS WHAT ME I MAKE CABLE BY SCHIMETICSH GIVE ME SCHIMETICSH WAIT ING TP...........................................FAIL. ...EROOR SENDING CODE |
Sx4 autorization not working in nokia tool | lovingazmee | Multi-Box | 1 | 11-29-2008 23:24 |
Universal Box not working in nokia 3110c | hc_nuck23 | Universalbox | 0 | 04-14-2008 18:53 |
3.6.9.# not working in nokia 1110i | slim2 | Nokia Hardware & Hardware Repair | 4 | 03-24-2008 07:16 |
bluetooth not work in nokia 7610 ???? | eng.hamdow | Nokia Hardware & Hardware Repair | 2 | 04-09-2005 12:59 |
