Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > J.A.F - Just Another Flasher > J.A.F. By Jafsupport.com > J.A.F. V-SPEC
Old 07-25-2008, 16:30   #1 (permalink)
mani_satcell's Avatar
Member: 65535
Thanks Meter: 451
Need help...
6300 5.50 spanison chip unlock error i downgrade to 5.0 still unlock error . lot of tries any solution for this pls need urgent any one help.......
Backup simlock data first...
Setting local mode...
Reading IMEI...
Backup already done, skiping...
Detecting phone...
Reading simlock...
LOCK STATUS:
CONFIG KEY: 8000000000000000
PROVIDER KEY: 2340000100000000
Provider: Virgin - SPECIAL CODE;United Kingdom
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: CLOSED -> Lock Data: 23430F Lock 2: CLOSED -> Lock Data: 23430F
Reading phone...Type: RM-217, Ver: 05.00
Reading imei...
Imei: 354835026707159
Reading HW ID...4007
Found general data...
Waiting for TP confirmation.....................................S ending code...
Sending code...
Sending code...
Sending code...
Sending code...
Sending code...
Sending code...
Sending code...
Sending code...
Sending code...
Sending code...
Sending code...
Sending code...
Error unlocking! Code: 08
Old 07-25-2008, 17:09   #2 (permalink)
Member: 59401
please read this topic...
http://forum.gsmhosting.com/vbb/showthread.php?t=537297
it ill help you.
Old 07-26-2008, 11:11   #3 (permalink)
Member: 557841
Thanks Meter: 22
it does not help.
for example 6300 HW ID 3019 and 3020 cannot be downgraded from 5.50 to 5.00 and cannot be unlocked by JAF as 5.50
Old 07-28-2008, 09:14   #4 (permalink)
tomi_no's Avatar
Member: 965
Thanks Meter: 36
You are wrong. 6300 hwid3019 ver.6.01 succesfully downgraded to ver.5.00
then unlocked
PROVIDER KEY: 2320700000000000
Provider: Telering ;Austria
Block 1:
Lock 1: CLOSED -> Lock Data: 23207F
Reading imei...
Imei: 35351102******x
Reading HW ID...3019
Waiting for TP confirmation..................................Send ing code...
Waiting for TP confirmation.......Sending code...
Unlock OK!
BR Tomi
Old 07-29-2008, 11:39   #5 (permalink)
Member: 15572
Me too, but only without GND (with gnd zero success).
then unlocked.
SPANSION 72 NS256NDOAJ8LG 801VVL29 C CHINA 4L1S
Log:
Reading imei...
Imei: 3541810******xx
Waiting for TP confirmation...............................Sending code...
Waiting for TP confirmation....................Sending code...
Unlock OK!
Reading simlock data...
LOCK STATUS:
PROVIDER KEY: 2600200000000000
Provider: ERA GSM ;Poland
Block 1:
Lock 1: OPEN
Done!
Old 09-22-2008, 01:43   #6 (permalink)
Registered User
Member: 329373
Thanks Meter: 11
explain more please
then unlocked.
Log:
Reading imei...
Unlock OK!
LOCK STATUS:
Block 1:
Lock 1: OPEN
Done!
did you mean make unlock without connecting gnd pince?
Old 09-22-2008, 01:50   #7 (permalink)
inside-d-saul's Avatar
Member: 581626
Thanks Meter: 184
this thread is old brother
The Following User Says Thank You to inside-d-saul For This Useful Post:
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP FuriouS TeaM FuriousGold 66 08-27-2010 13:20
samsung T429 T MOBILE FLASH I NEED HELP who_i UST Pro II 1 08-17-2010 14:30
need help master manole n95-8gb write screen restart haslyn MXKEY Nokia Flasher and Unlocker (by Alim Hape) 15 03-30-2010 10:56
2700 flashing need help ngaia MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-29-2010 11:48
nokia masters need help.............. ANILMPLY Nokia Hardware & Hardware Repair 0 03-29-2010 10:48
Page generated in 0.22928 seconds with 9 queries
