Problem unlocking 6300 version 5.00...also 5.52 Reading phone...Type: RM-217, Ver: 05.00 Reading imei... Imei: 359810016258575 Reading HW ID...4002 Found general data... Waiting for TP confirmation.................Failed! can you help me |
You can unlock this varsions by mtpro with out any problem |
v 5.00 best supported for nokia 6300 ya its true Ver: 05.00 best supported for 6300 unlocking LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 5050300014981890 Provider: Vodafone;Australia Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 50503F Block 2: Lock 1: CLOSED -> Lock Data: 50503F Reading phone...Type: RM-217, Ver: 05.00 Reading imei... Imei: *************** Reading HW ID...3009 Found general data... Waiting for TP confirmation...................................... Failed! Backup simlock data first... Setting local mode... Failed! Aborting! Can't backup simlock data!Abort! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 5050300014981890 Provider: Vodafone;Australia Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 50503F Block 2: Lock 1: CLOSED -> Lock Data: 50503F Reading phone...Type: RM-217, Ver: 05.00 Reading imei... Imei: ************** Reading HW ID...3009 Found general data... Waiting for TP confirmation....................Sending code... Unlock OK! wbr aksingh |
with V spec no problem but sometimes i find this problem with version 5.52 |
look hereCONFIG KEY: 8000000000000000 PROVIDER KEY: 2041600000000000 Provider: T Mobile - Ben ;Netherlands Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 20416F Reading phone...Type: RM-217, Ver: 05.52 Reading imei... Imei: 359810016297136 Reading HW ID...4002 Found general data... Waiting for TP confirmation........................Sending code... Unlock OK! Reading simlock data... LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2041600000000000 Provider: T Mobile - Ben ;Netherlands Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Done! guys everything ok with version 5.52 |
i think you have to post logs in successfully unlocked thread :) cool that you have done 220 peaces :D |
Reading phone...Type: RM-217, Ver: 05.50 Reading imei... Imei: 359812015733145 Reading HW ID...3011 Found general data... Waiting for TP confirmation.....................Sending code... Error unlocking! Code: 08 can anybody help with this problem??? |
Block 1: Lock 1: CLOSED -> Lock Data: 24601F Reading phone...Type: RM-145, Ver: 05.43 Reading imei... Imei: 3589750.................. Reading HW ID...1020 Found general data... Waiting for TP confirmation...................................... .....Sending code... Error unlocking! Code: 08 where is problem??? |
jaf team need your answer .and 6300 with spension flash support or no thanks |
thats not working so i put the newer version back and i have the same problem with n95 also error 08 so what stands 08 for? what kind of error is 08 |
Reading phone...Type: RM-217, Ver: 05.00 Reading imei... Imei: 359538017663960 Reading HW ID...3007 Found general data... Waiting for TP confirmation..................Failed! Backup simlock data first... Setting local mode... Reading IMEI... Backup already done, skiping... Detecting phone... Reading simlock... LOCK STATUS: CONFIG KEY: 8000000000000000 PROVIDER KEY: 2720300000000000 Provider: Meteor;Ireland Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 27203F Reading phone...Type: RM-217, Ver: 05.00 Reading imei... Imei: 359538017663960 Reading HW ID...3007 Found general data... Waiting for TP confirmation..........Failed! |
Try to ulock it without ground AND also remove fuse from ur tp cable |
